What key sequence to go into ROMMON from the console port for VSS with VS-S720-10G?
ditti.tech
What key sequence to go into ROMMON mode from the console port for VSS system with 2 VS-S720-10G?
You need to have console connected to redundant SUP. Once it will be start rebooting and show first symbols you can type Ctrl+Break continiously to break into rommon.
Hope this helps,
Nik
HTH,
Niko
ditti.tech
I'd like to go to ROMMON mode for the standby supervisor card.
After the redundancy reload peer comande
#redundancy reload peer
Hope this helps,
Nik
HTH,
Niko
Thank you, the serial port of Supervisors is connected to a Cyclades console server.
The break séquance is:
%break and "Carriage return"
