What's a good way to mark DSCP values for a vlan in a 3750?
jkeeffe
Level 2
Level 2
On a 3750 switch I want to mark all packets on our data vlan, vlan 10, to dscp '0', before they get to the upstream router. I'm having trouble finding the right commands to do this....something that will both match on a vlan #, and also be able to 'set dscp 0'.
What is the best way to do this?
2 Accepted Solutions
wochanda
Level 4
Level 4
policy-map Vlan10
class class-default
set ip dscp 0
interface gi0/1
mls qos vlan-based
interface Vlan10
service-policy input Vlan10
For more info:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swqos.htm#wp1552680
Will
Friend,
You can modify the class-map i suggested and mark the vocie packets to DSCP EF
ip access-list extended data
permit ip any
ip access-list extended voice
permit ip any range 16384 32767
class-map match-all set-dscp
match access-group name data
class-map match-all set-dscp-voice
match access-group name voice
policy-map upstream-QoS
class set-dscp-voice
set ip dscp ef
class set-dscp
set ip dscp 0
apply this policy inbound to the switch ports
int g0/1
service-pollicy input upstream-QoS
HTH, rate if it does
Narayan
wochanda
Level 4
Level 4
policy-map Vlan10
class class-default
set ip dscp 0
interface gi0/1
mls qos vlan-based
interface Vlan10
For more info:
Will
There is another way to do it though the method suggested by Will is more suited
Since the data vlan will be having a seperate subnet you can also match that subnet and set the DSCP to 0
permit ip any
class set-dscp
set ip dscp 0
int g0/1
Narayan
When I apply your suggestion, it removes the interface command 'mls qos trust dscp' which I need to trust the dscp values of the phone.
Here is what I originally have on the interface:
interface FastEthernet1/0/11
description IP Phone and PC
switchport access vlan 10
switchport mode access
switchport voice vlan 910
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust dscp
auto qos voip trust
spanning-tree portfast
end
Here is the config after applying the vlan-based Qos:
description Phone/PC w/o trunk to lab PBX
speed 100
duplex full
mls qos vlan-based
auto qos voip trust
end
How would I make sure that the DSCP values of the IP phone were kept intact?
Friend,
permit ip any
set ip dscp ef
class set-dscp
set ip dscp 0
int g0/1
Narayan
