What's difference between uptime and %SYS-5-RESTART ?
henrybb
Level 6
Level 6
When I issue "sh ver", it is that "System restarted at 04:18:42 CHINA Sun Jun 3 2007 ",but when I see "sh log", it is that "*Sep 12 09:01:38: %SYS-5-RESTART: System restarted " .
What's difference between these ?
thanks for your comments.
My router 7304 has following information:
RT7304#sh ver
IOS (tm) 7300 Software (C7300-IS-M), Version 12.2(20)S6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 29-Oct-04 14:27 by ccai
Image text-base: 0x40008BF4, data-base: 0x42338000
ROM: System Bootstrap, Version 12.1(12r)EX1, RELEASE SOFTWARE (fc1)
Currently running ROMMON from ROM 0
BOOTLDR: 7300 Software (C7300-IS-M), Version 12.2(20)S6, RELEASE SOFTWARE (fc4)
RT7304 uptime is 18 weeks, 1 day, 12 hours, 6 minutes
System image file is "disk0:c7300-is-mz.122-20.S6.bin"
cisco 7300 (NSE100) processor (revision E) with 491520K/32768K bytes of memory.
Processor board ID SCA0842005G
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
4 slot midplane, Version 67.49
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
PXF processor tmc0 'system:pxf/ucode1' is running ( v4.1 ).
PXF processor tmc1 'system:pxf/ucode1' is running ( v4.1 ).
1 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
1 Packet over SONET network interface(s)
509K bytes of non-volatile configuration memory.
31168K bytes of ATA compact flash in bootdisk (Sector size 512 bytes).
62592K bytes of ATA compact flash in disk0 (Sector size 512 bytes).
RT7304#sh log
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes,
0 overruns)
Console logging: level debugging, 43 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 43 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 48 message lines logged
Log Buffer (4096 bytes):
-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
00:00:23: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Sep 12 09:01:37: %SYS-5-CONFIG_I: Configured from memory by console
*Sep 12 09:01:38: %SYS-5-RESTART: System restarted --
*Sep 12 09:01:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0,
*Sep 12 09:01:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEtherne
*Sep 12 09:01:39: %LINK-5-CHANGED: Interface FastEthernet0, changed state to adm
inistratively down
*Sep 12 09:01:39: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to
up
*Sep 12 09:01:40: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to
up
*Sep 12 09:01:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEtherne
t0/0, changed state to up
spremkumar
Level 11
Level 11
As far as i know %SYS-5-RESTART is an informational message which comes up during the final initialisation phase.
Once your device is booted up and all your interfaces are intitialised you will get this message and regarding the uptime its the time the router is up and functioning since last reboot.
regds
thanks for your reply.
You mean that %SYS-5-RESTART would be later about few minutes than uptime. But my router's uptime is Jun 3 2007,and %SYS-5-RESTART is Sep 12. They are very different. I don't understand what reason will reset %SYS-5-RESTART and DON'T reset uptime.
thanks!
