What switch to replace 6509 ?
carl_townshend
We are looking at a core upgrade over the next 12 months, currently we have a 6509 with mix of 48 port rj45, SFP gigabit modules as well as a 12 port 10gig module in each.
I am not sure about the 6800 as I hear it has not taken off that well etc.
The Nexus is just too much to invest as we dont require high throughput etc.
What would be a good switch to look at, approx 7-8 year lifespan
cheers
balaji.bandi
If you looking to go with new models, cisco have new models Catalyst 9000 for Core and Distribution for Campus LAN
Have a look at the models.
https://www.cisco.com/c/en_uk/products/switches/catalyst-9000.html
BB
Leo Laohoo
9400 or 9500 replaces the 6500.
balaji.bandi
BB
mateens
Level 5
Level 5
@carl_townshend I would recommend 9407R . Cheaper than the 6800s. Get a pair or run 2 sups in one unit for some redundancy. You can use stackwise virtual feature if you get a pair with sup1XL which is like (VSS) and run multi chasis etherchannel to your endpoints to get more bandwidth. more than good investment for next 10 years
