what will happen if sw1 is configured with PVSTP +  & sw 2 is configur
krahulbgp
what will happen if sw1 is configured with PVSTP +  & sw 2 is configured with mst
As Rapid PVST + is having high cpu/memory utilization  while MSTP + is having low  cpu/memory utilization
balaji.bandi
Most of the use case - we do this in the part of mygration from one to other - finally you run any one of them, but some scenario you need to run, then that required to take some consideration, always  make sure root bridge on one device as major step need to consider.
some good explanation here for you to understand :
https://networklessons.com/cisco/ccie-routing-switching-written/mst-pvst-interoperability
BB
can you more elaborate ?
are you ask about interoperability ?
