udldEmpEC - Empty echo issue
pabene
Frequent Visitor
Frequent Visitor
One of our trunk links between switches has the following port status:   udldEmpEc
Anyone ever see this?  Thoughts?
5 Replies 5
pabene
Frequent Visitor
Frequent Visitor
Thank you.  What is the resolution to such a port status?
Ensure to eliminate all physical issues by checking SFP's, fiber patch cords, switch ports. Check interface status for errors, CRC
If you are using UDLD aggressive, I would suggest using UDLD normal mode because there is high probability of false positive.
pabene
Frequent Visitor
Frequent Visitor
antonio202211
Frequent Visitor
Frequent Visitor
I had the same issue and solved only doing shutdown and no shutdown
