When and Why do we decrease MSS instead of MTU.
Pratyush Sinha
Community Member
Here is the question.
In the router that we can configure  both of them separately.
Suppose I have kept MSS as 1260.I have not made any changes to the MTU. Now if the TCP and the IP header do not have any options then they will be using 40 bytes( 20 TCP + 20 IP).
So does this mean that the MTU in this case is 1300.
Now the second scenario.
I decreased the MTU to 1300. I did not make any change to the MSS. Again there are no options in the TCP and IP options.
So does this mean that the MSS in this case is 1260.
If both the scenarios have same outcome then please help me understand the following.
  1. In which case should we decrease the MTU and leave MSS untouched ?
  2. In which case should we decrease the MSS and leave MTU untouched ?
Thank You
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Perhaps the following will help you understand a typical reason for reducing MSS but not MTU:
http://www.cisco.com/c/en/us/support/docs/ip/generic-routing-encapsulation-gre/25885-pmtud-ipfrag.html
