Wher to configure Stackwise-Virtual on catalyst 9606R supervisor Engineer or Line Card
Bazoka
I am going to replace an order for two switches 9606R with two supervisor engines, Signal 40 GE line cards, and a single 10 GE line card for each switch and I am planning to configure StackWise virtual between them.
The question which ports I have to use for SVL and DAD? on the supervisor engines to the line cards?
If on the supervisor engines i have two on each switch, which SUP i have to configure?
Ahmed,
You cannot use the management port for regular data traffic or for SVL. These ports are just for Out of Band management purposes:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9600/hardware/install/b-c9600-sup-note.html#id_103889
DAD and SVL must be on interfaces on the line cards in a 9606. Please reference the StackWise Virtual chapter of the configuration guide:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9600/software/release/17-3/configuration_guide/ha/b_173_ha_9600_cg/configuring_cisco_stackwise_virtual.htmlv
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
balaji.bandi
SVL always on SUP cards, DAD can be on Line Cards.(check the priority Line cards)
10G and 40GB both supported.
example ( quad one still valid)
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9600-series-switches/215627-catalyst-9600-migration-to-quad-superv.html
BB
On the SUP I can see a single mgt port 10 GE SFP+
Ahmed,
Cheers,
Scott Hodgdon
