Which IOS for Catalyst 3750
markus.forrer
Level 4
Level 4
Hi together
Which IOS would you recomment for the Catalyst 3750.
Only need OSPF on L3 Device and on L2 nothing special. Should be a stable one and the command ip tacacs source-interface should work (not working in 12.2(44)SE.
Thanks for your hints.
Markus
SED1 is more stable :)
5 Replies 5
Edison Ortiz
c3750-advipservicesk9-mz.122-25.SED1.bin should be good. Make sure you've purchased the correct licenses for this feature set.
HTH,
__
Edison.
Thank you for the fast reply. I need only ipbase (l2) and ipservice (l3).
Markus
c3750-ipservices-mz.122-25.SED1.bin instead.
Thanks Edison. But I know how to handle IOS service categories. :)
I had just upgraded some switches to 12.2.44SE before and the tacacs source-interface command was gone...
But by the way, why not the 12.2.25.SEE4 ?
