Which length of stacking cable should I use to connect 1-st and 8-th switches of my stack?
spankin01
Hi!
I have to stack 8 switches (C2960X-48TD-L). There is a cable being shipped with each of them. But these cables are only 0.5 meters long. Which length is enough, reasoning from the minimal bending radius of the cable.
I need to order the proper one.
Thank you!
6 Replies 6
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
There may be a special order cable (for additional length).  Or, you might be able to "interleave" (i.e. 1 to 3, 2 to 4, etc.) your switch connections.
Martin Moran
Level 3
Level 3
Hi @spankin01,
It depends on how far the switch will be from each other. It the switches are one under the other in the same rack, you can buy a 3 meter cable and it would be enough.
You can connect the switches like in the attached diagram.
Don't forget to rate. :D
Rgrds,
Martin, IT Specialist
Thank You, Martin!
And will it be enough to use 1,5 meter cable in case of 8 switches standing one under the other?
Rgrds,
Sergey
I recommend to buy the 3M cable just in case. Again, it depends how close will be each RU from the other.
If the RUs are very close from each other you can buy the 1.5 meter for sure.
Rgrds,
danish.rahman
Yup - nice image of what I described in my earlier post.
