12-26-2012 11:14 PM - edited 03-07-2019 10:47 AM
Hello guys!
We have a customer who uses about 20 x c2960's switches for access layer and 2 x c3560e for distribution layer. C2960's uses C2960-LANLITEK9-M , Version 12.2(58)SE1. Everything was working fine. Now we got information, that sometimes there are problems with connectivity. Customer tries to reach internet.
SW11#sh int fa0/18
FastEthernet0/18 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is e8ba.806a.4412 (bia e8ba.806a.4412)
Description: Bilietu kasos
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 132218
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
7947681 packets input, 1048599076 bytes, 0 no buffer
Received 323439 broadcasts (238935 multicasts)
0 watchdog, 238935 multicast, 0 pause input
19465465 packets output, 20732928366 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
With #show logging command , we can see that interface was flapping:
Dec 26 15:58:59.607: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to up
Dec 26 18:54:34.283: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to down
Dec 26 18:54:36.296: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to up
Dec 26 19:03:35.406: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to down
Dec 26 19:03:37.410: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to up
Dec 26 19:03:40.724: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to down
Dec 26 19:03:42.729: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to up
Dec 26 20:12:57.166: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to down
Dec 26 20:12:59.180: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to up
Maybe you have some ideas how we can troubleshoot this issue?
12-27-2012 01:12 AM
Make sense. Firstly, the output drops is caused by the switch trying it's best to send 100 Mbps worth of data down the "tube". Unfortunately, whatever is connected to this is having some kind of issue. So instead of accepting the data, the data is being "dropped" by the switch because the remote end's connection has gone down.
Your 2960 has two Gig ports. Is any one of those NOT used to do a simple TDR?
12-27-2012 02:15 AM
Thank you very much for your answer Leo.
All the switches uses both Gig ports for Uplink connection. Topology looks like this:
These switches are online for about 500days. Maybe it is time for a reload?
12-27-2012 03:25 AM
The problem is not as simple as a reload.
Whatever is connected to this port is having major issues.
This is why I'm asking if you have a GigabitEthernet port to run TDR. I'm suspecting the client connected to this port has a failing NIC card.
12-27-2012 06:16 AM
Not related...but
>> 1 interface resets
Does this mean layer 1 is dropping or layer 2? I thought when the line protocol went up / down this caused the reset counter to go up...but looks like it a layer 1 stat...is this correct?
12-27-2012 03:39 PM
1 interface reset is very, very common. I have no idea how this counter works but I tend to ignore interface resets if it ain't >10.
12-27-2012 08:42 PM
Just saw this link:
http://www.cisco.com/en/US/docs/ios/12_3/interface/command/reference/int_s3g.html
Number of times an interface has been completely reset. This can happen if packets that were queued for transmission were not sent within several seconds. On a serial line, this can be caused by a malfunctioning modem that is not supplying the transmit clock signal or by a cable problem. If the system notices that the carrier detect line of a serial interface is up, but the line protocol is down, it periodically resets the interface in an effort to restart it. Interface resets can also occur when an interface is looped back or shut down."
12-28-2012 01:05 AM
Thanks guys. I will check it again in a few days. Maybe there is a problem from ISP side. I will let you know
