Why can I not run packet capture on C2960x Switch port?
rweir0001
I have a C2960x Switch running IOS Version 15.2(2)E3. I have a PC that is plugged into an IP phone, and the phone is plugged into a jack connected to interface gi1/0/28 on the switch. Because the PC is dropping a lot of pings I want to run a capture on the switch port so I can see the packets. I plan to send the output to Wireshark, but even though I believe my capture configuration is correct, I am not seeing any packets being captured as I ping the host. I have made sure to activate my capture point....but it isn't working. Below is the configuration I used. Can anyone tell me what I am doing wrong?
STACK1(config)#ip access-list extended cap
STACK1(config-ext-nacl)#permit ip any any
STACK1(config-ext-nacl)#exit
STACK1#monitor capture buffer buff circular
STACK1#monitor capture buffer buff filter access-list cap
STACK1#monitor capture point ip cef trace gi1/0/28 both
STACK1#monitor cap point associate trace buff
STACK1#show monitor capture buffer buff param
Capture buffer buff (circular buffer)
Buffer Size : 1048576 bytes, Max Element Size : 68 bytes, Packets : 0
Allow-nth-pak : 0, Duration : 0 (seconds), Max packets : 0, pps : 0
Associated Capture Points:
Name : trace, Status : Active
Configuration:
monitor capture point associate trace buff
Milos Megis
Level 3
Level 3
Try use commands:
monitor session number source....
and
monitor session number destination....
Thanks, Milos. That is what I actually ended up doing...configuring SPAN and having the packets mirrored on another port...but I'm still curious as to why I can't get the embedded packet captures to work.
