why i am not able to ping 20.0.0.1 in below toplogy after configring d
krahulbgp
why i am not able to ping 20.0.0.1 in below topology after configuring a default route on R10
yes that is correct
Jitendra
11 Replies 11
post your zipped Packet Tracer project file...
Nicola A
reboot packet tracer
Jitendra Kumar
Add a route on static router9 ( on 20.0.0.2 )
ip route 192.168.10.0 255.255.255.0 20.0.0.1
Add a route on ISR 4321 ( on 20.0.0.1 )
ip route 192.168.10.0 255.255.255.0 20.0.0.2
and ping them you will able to ping
Jitendra
in that way i can do   can not  we use this command to reach 20.0.0.1
#R10   ip route 0.0.0.0 0.0.0.0 192.168.10.1
you have to let the router know the networks or default route should the there.
on the router 20.0.0.1
ip route 0.0.0.0 0.0.0.0 20.0.0.2
on the router 20.0.0.2
ip route 0.0.0.0 0.0.0.0 20.0.0.1
Jitendra
attaching a ZIP file does not work ?
Hope your query has been answered
Jitendra
krahulbgp
yes ,conclusion is that forward & revers default route we  have to apply  is it correct?
yes that is correct
Jitendra
krahulbgp
Dear jitendra
one question in my mind can i use default route (forward,reverse) instead of redistributing ospf & eigrp vice versa
each routing protocol has there own purpose for the use you have to understand what is topology and what protocol is required for routing traffic.
however, you can use in packet tracer for learning purposes in your lab for connectivity. how ever you should have to learn each protocol separately
Jitendra
