why is trunk not showing vlan membership?
ADAman
I setup corectly a LACP etherchannel with all VLANS allowed. This interface is called Po10.
Then I set up another one, Po20, consisting of interfaces 33 and 34, but this time restricting VLANs to only VLAN 20 (all config is below).
But when I do a sh int trunk and sh vlan brief, it only shows vlans for Po10. Is this because nothing is connected to the new port-channel, yet?
And what about the "no shut" command. I have not run this command. I thought I had to run this command, since all ports are shut per default in a Cisco switch? The config does not show this for any of my ports (I might have done this for the working port-channel).
Here is the config:
3750G-A#sh run int gi1/0/33
Building configuration...
Current configuration : 228 bytes
interface GigabitEthernet1/0/33
description iSCSI LACP interface
switchport trunk allowed vlan 20
switchport mode trunk
channel-group 20 mode active
spanning-tree portfast trunk
end
3750G-A#sh run int gi1/0/34
interface GigabitEthernet1/0/34
end
3750G-A#sh run int po20
Current configuration : 202 bytes
interface Port-channel20
description LACP Port-Channel for VNX iSCSi
end
3750G-A#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Po10        on               802.1q         trunking      1
Port        Vlans allowed on trunk
Po10        1-4094
Port        Vlans allowed and active in management domain
Po10        1,3,20,30,40,50,60,99
Port        Vlans in spanning tree forwarding state and not pruned
3750G-A#sh vlan brief
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/6, Gi1/0/7, Gi1/0/8
                                                Gi1/0/9, Gi1/0/10, Gi1/0/11
                                                Gi1/0/12, Gi1/0/13, Gi1/0/14
                                                Gi1/0/15, Gi1/0/16, Gi1/0/19
                                                Gi1/0/20, Gi1/0/21, Gi1/0/22
                                                Gi1/0/23, Gi1/0/24, Gi1/0/25
                                                Gi1/0/26, Gi1/0/27, Gi1/0/28
                                                Gi1/0/29, Gi1/0/30, Gi1/0/31
                                                Gi1/0/32, Gi1/0/33, Gi1/0/34
                                                Gi1/0/35, Gi1/0/36, Gi1/0/37
                                                Gi1/0/38, Gi1/0/39, Gi1/0/40
                                                Gi1/0/41, Gi1/0/42, Gi1/0/43
                                                Gi1/0/44, Gi1/0/45, Gi1/0/46
                                                Gi1/0/47, Gi1/0/48, Gi1/0/49
                                                Gi1/0/50, Gi1/0/51, Gi1/0/52
3    Management                       active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5
20   iscsi-A                          active
30   iscsi-B                          active
40   vMotion                          active
yes you right, if the ports are not connected then they will show only the default (NATIVE VLAN:).
sh vlan brief will show the vlan is active or not not the port.
Hope this helps.
Please rate if it helps.
6 Replies 6
Sandeep Choudhary
Hi Atle,
No shut command is used to make port avilability to up otherwise port will be in shutdown status.
If you will not connect a device on these ports then it will not show the trunk ports.
run this command: sh int status
and paste the output.
REgards
3560-B#sh int status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/1     Management interfa notconnect   3            auto   auto 10/100/1000BaseTX
Gi0/2     management vlan 3  notconnect   3            auto   auto 10/100/1000BaseTX
Gi0/3     Mangement switch   notconnect   3            auto   auto 10/100/1000BaseTX
Gi0/4                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/5     VNX Management     notconnect   3            auto   auto 10/100/1000BaseTX
Gi0/6                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/7                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/8                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/9                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/10                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/11                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/12                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/13                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/14                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/15                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/16                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/17    UCS FI-B uplinks   connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/18    UCS FI-B uplinks   connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/19                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/20                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/21                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/22                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/23                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/24                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/25                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/26                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/27                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/28                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/29                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/30                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/31                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/32                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/33    iSCsi fra VNX      notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/34    iSCsi fra VNX      notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/35                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/36                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/37                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/38                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/39                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/40                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/41                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/42                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/43                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/44                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/45                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/46                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/47                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/48                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/49                       notconnect   1            auto   auto Not Present
Gi0/50                       notconnect   1            auto   auto Not Present
Gi0/51                       notconnect   1            auto   auto Not Present
Gi0/52                       notconnect   1            auto   auto Not Present
Po10      Port-channel for U connected    trunk      a-full a-1000
Po20      iSCSi LACP Port-ch notconnect   unassigned   auto   auto
yes.. according to your output:
both ports are not connected .
ok, so if not connected, the ports do not show up as member of vlans if if they are configured as member of vlans? sh vlan brief only says "active"
Hope this helps.
Because interfaces g0/33 & g0/34 aren't *in* the VLAN - they're *trunking* the VLAN.
You won;t get anything in the "sh vlan brief" output for vlan 20 unless and until you put an ACCESS port into this VLAN. Trunk ports aren't members of VLAN's, and both the ports you mention as being in the etherchannel are trunks, not access ports.
Cheers.
