Why must port role be set to Access Point for a Wifi AP to work?
xrper
I have a Cisco switch into which is plugged a Cisco Aironet. Unless the port role is set to access point traffic from wireless clients is 9 times out of 10 not passed through the switch. Why is this, what exacly does port roles change?
7 Replies 7
not sure if I understand what you are asking, but actually, the switchport connected to the AP should be set to trunk mode. Do you have different VLANs configured on the AP ?
Can you post the configs of both devices ?
xrper
The switch is an ESW 500 series Small Business Switch, as far as I can tell it only has a web GUI, I cant see any way of getting a CLI on it.
The config on the Wifi AP is as follows:
version 15.2
no service pad
service password-encryption
hostname ap1142_1
logging rate-limit console 9
enable secret 5 $1$VaPA$HN1vIlgnlRYgkQiABiacQ.
aaa new-model
aaa group server radius rad_eap
 server name 192.168.253.206
aaa group server radius rad_mac
aaa group server radius rad_pmip
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa session-id common
no ip cef
ip domain name wrinehillvilla.local
ip name-server 192.168.253.254
dot11 syslog
dot11 ssid 7 Bishops Wood
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa version 2
   guest-mode
   no ids mfp client
dot11 arp-cache optional
dot11 guest
username Cisco password 7 01300F175804
username admin secret 5 $1$3fMG$1YwEpxe4qt7I4fX2M8AjQ1
ip ssh version 2
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm
 encryption mode ciphers aes-ccm
 ssid 7 Bishops Wood
 antenna gain 0
 packet retries 128
 station-role root
 rts threshold 1024
 rts retries 128
 world-mode dot11d country-code GB both
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 shutdown
 antenna gain 0
 peakdetect
 no dfs band block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
no ip address
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 192.168.253.250 255.255.255.0
 ipv6 address dhcp
 ipv6 address autoconfig
ip default-gateway 192.168.253.254
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
radius-server attribute 32 include-in-access-req format %h
radius server 192.168.253.206
 address ipv4 192.168.253.206 auth-port 1812 acct-port 1646
 key 7 095F460C0B1516
bridge 1 protocol ieee
bridge 1 route ip
line con 0
 exec-timeout 0 0
 logging synchronous
line vty 0 4
 length 0
transport input ssh
line vty 5 15
 transport input ssh
sntp server 85.199.214.99
sntp broadcast client
end
you have only one Vlan (Vlan 1, the default) configured. The ESW500 indeed does not have a CLI command line.
In the 'Smart Port Settings Wizard - Access Point'  (page 25 step 3 of the attached user guide) do you have the 'Trunk Native VLAN ID' set to 1 (Vlan 1) ?
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/esw500/administration/guide/ESW_500_Administration_Guide.pdf
Julio E. Moisa
Please correct me if I understand wrong the question, but usually the access mode is used when you have 1 VLAN in few workds a SSID, now if you have configured multiple SSIDs and they have been assigned to specific VLANs you need to use trunk mode to pass multiple VLANs through the port, also is required configure a native VLAN once you are using Trunk, on the AP you need to create the native vlan and specifiy it.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes the native /default VLAN is set to 1 on the switch.
is your question about the Smart Ports for Access Points ? When configured as access point, a QoS policy is implemented, that might be the issue.
I usually dont use the vlan 1, but have you configured the vlan 1 as native on the AP?
