Nexus 93180LC-EX
aukhadiev
Looking more detailed info (no aviabled detailed datasheet in cisco.com) about Nexus 93180LC-EX...
1) does it support NX-OS operating system ore only run in ACI mode?
2) does it support FEX?
3) does all 40G port are breakout capable, so in this port template (28p 40/50G + 4p 40/100G) by breakout cable we achive 112p 10G + 4p 40/100G?
Thanks in advance.
alfrram2
Hello
1) yes, it supports NX-OS and ACI mode.
2) yes also supports FEX
3) no, the Uplinks are the only port that supports the breakout mode.
rsua
Just for clarification on Question#3.
For ACI mode, breakout transceivers are supported on access ports (downlinks) of the leaf switch.  Depending on the transceiver used, only a subset of ports is supported for breakout.  Also, it is important to note that as of today, it is not supported in ACI to further breakout a breakout subport.
For full 40G transceiver compatibility matrix, check the following documentation:
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/40GE_Tx_Matrix.html#_Toc492384769
