11-14-2007 09:13 PM - edited 03-05-2019 07:26 PM
I have a 2610XM router. On the router, I have only one fastethernet port and two blank WIC slots and one blank network module slot. When it starts, a error message says:
Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate
Then I bought a WIC-1B-U card and installed it on W0 slot, the error message remains there.
Here are my questions:
(1). none of the LED(B1,B2,NT1) on the WIC card is on. Is this normal? Does this mean that my router can not recognize the card?
(2). I checked the documents before I bought the WIC. It seems that WIC-1B-U does work with 2610XM. Can anyone confirm this issue?
(3). Is it a possible reason that corresponding configuration need to be set on the router to make it work? If so, what configuration do I need?
Joe
11-20-2007 02:42 PM
Disable the " network-clock-participate "command
11-21-2007 08:50 AM
The simplest way to find out whether the WIC-1BU has been detected and accpted on a router is to go through the sh version output.
You should be seeing something similar to this:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(23), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 28-Jan-04 17:48 by kellmill
Image text-base: 0x8000808C, data-base: 0x81118968
ROM: System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
Router uptime is 0 minutes
System image file is "flash:c2600-is-mz.122-23.bin"
cisco 2620 (MPC860) processor (revision 0x600) with 61440K/4096K bytes of memory.
Processor board ID JAD053604N6 (1074245753)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s) <= WIC-1BU Interface
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Router#
Hope that helps,
Please rate all helpful posts.
Kind Regards,
Wilson Samuel
11-21-2007 07:38 PM
Thanks to both of you.
To owillins:
Thanks but this does not work.I tried:
no network-clock-participate slot 1
no network-clock-participate wic 0
The error remains and all the LED are off.
To Wilson:
My start up output does have the message of
Hmmm, this prove that 2610XM does work with the card.
To both of you and all:
It turns out I made a stupid mistake--I choose the wrong card. My internet connection is not ISDN based.
I'm trying to set up a subnetwork and using the 2610xm router (and a 2950 switch) to connect it with an university campus network. I think I should use an ethernet card(e.g. WIC-1ENET), am I right?
However, I found that, in the document, WIC-1ENET is not mentioned to be work with 2610XM. Can you guys give me a confirmation about the new choice? Or do you have better suggestion.
I've maken a mistake on buying the wrong card, which wasted money and time. I don't want to make the same mistake again. It would be very nice if someone with the similar experience can give me advice.
Joe
