Will Cisco 2800 Router work with and ASUS switch?
mahesh18
Level 6
Level 6
Hi Everyone,
Client has cisco 2801 router connected to cisco 3550 switch and this switch 3550 died.
Switch has no warranty.
They bought new switch ASUS GX-D1241 V3 as replacemet for cisco switch.
THey have DMVPN connection to head office.
I am not physically at this site.
Need to confirm will this switch work with cisco router?
My thinking is no but need to confirm with you experienced people here?
MAhesh
Message was edited by: mahesh parmar
3 Accepted Solutions
Leo Laohoo
Just checked the specification sheet, and I don't see anything being mentioned about 802.1q.
If you are NOT doing any 802.1q Trunking then this should be fine.
According to Leo, that switch cannot trunk. Since the router interface is configured as a trunk, this switch will NOT work.
will it work now?
My opinion is, no.  This switch doesn't understand multiple VLANs.  Heck, I'm not even sure if this switch understands anything other than VLAN 1.
6 Replies 6
Leo Laohoo
Hi Leo,
Seems router has trunk with switch as router interface config is
erface FastEthernet0/1.250
description ** Data VLAN  **
encapsulation dot1Q  250
ip address 192.168.250.1  255.255.255.0
ip nat  inside
ip  virtual-reassembly
ip tcp adjust-mss  1300
interface  FastEthernet0/1.251
description ** Voice VLAN  **
encapsulation dot1Q  251
ip address 192.168.251.1  255.255.255.0
ip nat  inside
--More--                             ip virtual-reassembly
service-policy output  output-L3-to-L2
will it work now?
MAhesh
will it work now?
Hi Leo,
Thanks again for timely help.
That switch was not working as it was not configurable.
I will config the cisco switch and will advice the client.
Best regards
MAhesh
Thanks Mahesh.
