Will removing one stackwise switch while hot affect traffic?
rafaelti1
Frequent Visitor
Frequent Visitor
I did some reading and I think it should be fine but I want to see if there is any feedback from the community...
We have two 3750's that are stacked and I want to remove the 2nd one. Both switches are online and running. If I remove the 2nd switch only from the stack while the stack is operational will it affect the rest of the traffic from the 1st switch (master)?
Will removing a switch from a stack while its hot affect any traffic? It should just detect the switch is no longer there and be fine?
Thanks.
shaps
Level 6
Level 6
yes you can remove one switch without affecting the rest of the stack,  obviously you would need to move over the connections to the other switches 🙂
rafaelti1
Frequent Visitor
Frequent Visitor
Thanks for the input, there will be no other switch added to the stack. Once we remove the 2nd switch, there will only be one.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It may, it depends whether the switch you want to deactivate is the master or not.  (If your 2nd switch is not master, you should be okay.)
acampbell
As always it is best to carry out network changes in the downtime window.
However sometimes we are not afforded this luxury.
Read this link:-
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#stack5
1)Make sure you know where the master is before starting
2) Power down the switch you want out
Follow the rest of the details in the link
Alex
Regards, Alex. Please rate useful posts.
