Bookmark
Subscribe
4918
wired 802.1x guest vlan test
tianwen.zhao
Hi everyone,
I have a 802.1x problem here.
I hoped  the PC while authentication fail dynamically allocating to guest vlan
But it turned to be drop not be assigned to the dedicated guest vlan
c3560#sho mac add int fa0/13
Mac Address Table
Vlan Mac Address Type Ports
21 68f7.2802.73d4 DYNAMIC Drop
c3560#sho authentication sessions interface fastEthernet 0/13
Interface: FastEthernet0/13
MAC Address: 68f7.2802.73d4
IP Address: Unknown
User-Name: UNRESPONSIVE
Status: Running
Domain: DATA
Security Policy: Should Secure
Security Status: Unsecure
Oper host mode: multi-auth
Oper control dir: both
Session timeout: N/A
Idle timeout: N/A
Common Session ID: 0A50016E00000042012CFA50
Acct Session ID: 0x00000056
Handle: 0x14000042
Runnable methods list:
Method State
dot1x Running
Here are the configuration of interface,It should be allocated to vlan 31
interface FastEthernet0/13
description dot1x
switchport access vlan 21
switchport mode access
authentication event no-response action authorize vlan 31
authentication host-mode multi-auth
authentication port-control auto
authentication periodic
authentication timer reauthenticate 60
dot1x pae authenticator
spanning-tree portfast
end
How can I troubleshoot this ?
Thank your for any replies.
Thanks again..
multi-auth and multi-domain auth are not equal. This is not supported on the 3560:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/sw8021x.html#34343
As you can see, starting in this release, while you could do RADIUS-Assigned VLANs on a multi-auth port, additional hosts had to match, and guest/auth-fail VLANs couldn't work as the switch doesn't have a way to put 2 machines on 2 different VLANs that was -not- a trunk port.
9 Replies 9
Seb Rupik
HI there,
Is the PC connected to this switch 802.1x capable? If it is and fails the authC process is will be denied access.
cheers,
Seb.
Thank you for your reply
Yes ,I disabled the PC's IEEE 802.1x Identity authentication. Because I wanted the PC assigned to the guest vlan
If I open it , PC will assigned to data vlan
Thank you Seb.
Do you mean to say that you have completely disabled the 802.1x supplicant on the interface?
I mean I have disabled the 802.1x on the PC not interface,because I wanted the PC authenticate fail so that the PC would be assigned to guest vlan
the configuration of interface as below:
So, 802.1x is enabled on the interface.But I don't know why the PC is dropping not assigned to vlan 31
Did you plug in the machine after you disabled 1X on it?
With the config below, the switch will try to seek a supplicant after something plugs in.
90-sec later, 1X will time out, and session should move into VLAN-31.
DHCP might have timed out by then, so consider shortening the overall timeout.
Look to shorten [tx-period]. Default is 30-sec before retransmission, and switch will retransmit twice before giving up on 1X.
Thank you for your reply.
I have shorten [tx-period] ,but didn't work .It still dropping
description dot1x
dot1x timeout quiet-period 5
dot1x timeout tx-period 5
dot1x timeout supp-timeout 5
Mac Address Table
Thank you
What code rev on the 3560 is this? Try to disable multi-auth:
[no] authentication host-mode multi-auth
When I changed host-mode from multi-auth to multi-domain or single-host .It could moved into vlan 31.
What difference between multi-auth and multi-domain ?What cause it be droped When useing multi-auth.
As my knowledge, if use multi-domain normally, It supported the same as using multi-auth
