Wireless Config
smarshalek
I have a Cisco 871W in a home office environment. My problrem is my wifi laptop cannot reach the internet.
I have the router configured with auto configuration and DHCP and the laptop is pulling the correct IP(I compared the IP to my working tower). and I cab browse to the router via IP(which is also my default gateway. I just can't get beyond that i.e. google.com, etc.
I have excellent signal strenght. I think it may be a router config issue. Please advise. Thank you.
10 Replies 10
Jon Marshall
Stan
It may well be a router config issue as you say but we can't tell because you haven't supplied the config
Can you post the config, it could well be a NAT issue ?
With your DHCP setup are you handing out a valid DNS server ?
From the router can you ping an internet IP ?
Jon
Hi Jon.
As I stated - I compared the DNS to my working tower and it is correct. The host IP is correct. No I cannot PING anything on the internet.
Current configuration : 3924 bytes
version 12.4
no service pad
service timestamps log datetime localtime show-timezone
hostname SJMRouter
boot-start-marker
boot-end-marker
logging buffered 16384 informational
enable secret 5 $1$L595$KHbJKC0kS3Nb0h2u92ojf.
no aaa new-model
clock timezone EST -5
clock save interval 8
crypto pki trustpoint TP-self-signed-3636220250
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3636220250
revocation-check none
rsakeypair TP-self-signed-3636220250
crypto pki certificate chain TP-self-signed-3636220250
certificate self-signed 01
  3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33363336 32323032 3530301E 170D3032 30373139 30313133
  32385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36333632
  32303235 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CF48 90F82435 DBE17A1F F5029D03 ED3B34CB 4ED603E2 6DAACB5E 12517DFD
  7CF44AC3 F69DD671 CF72F4D6 C736C7E3 E7D5297C 6F87EBD4 4F7255DF 09B30998
  7C40916A 325338F2 FF43717B 6D6B7598 186931A2 A6E97688 FC691B1C F9420E15
  92579F6E 89AB7D96 9A4F2380 310A3CD0 59C4C5DC E044ABE6 646E2992 0BDB18AC
  069B0203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
  551D1104 19301782 15534A4D 526F7574 65722E63 6F6D6361 73742E6E 6574301F
  0603551D 23041830 1680144F 249744C1 828F85DD F4ABD9F3 698EE514 9B0B3F30
  1D060355 1D0E0416 04144F24 9744C182 8F85DDF4 ABD9F369 8EE5149B 0B3F300D
  06092A86 4886F70D 01010405 00038181 00864127 E9D5E8C9 5C3AB322 33A336DB
  1C0CACDC E5138E1B AA194C60 0AA661C5 C9594EFA 686B96B9 EB1F4A19 B07D0F54
        quit
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool LANDHCP
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 68.87.77.134 68.87.72.134
   lease 3
ip domain name comcast.net
archive
log config
  hidekeys
ip ssh version 2
interface Loopback0
no ip address
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description INTERNET WAN PORT
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
description WLAN Port
no ip address
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip nat inside
ip tcp adjust-mss 1452
ip default-gateway 76.112.248.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
logging source-interface Loopback0
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
banner motd ^C
This is a secure router, unauthorized logins
are restricted.
line con 0
exec-timeout 30 0
logging synchronous
login
no modem enable
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 20 0
privilege level 15
logging synchronous
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Stan
Yes, you did say you had a working DNS server, apologies.
You need to modify your config ie. - you need to bridge the internal wired network and the wireless network. So most of the config below is new but you need to move the IP address from vlan 1 to the bvi interface -
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description Internal Network
no ip address
ip nat inside
bridge-group 1
interface BVI1
description Bridge to Internal Network
ip nat inside
Jon
Thanks Jon. Does this config replace anything or should I just copy paste into the running config?
Stan
It doesn't replace anything but you need to look at the vlan 1 config on the router and what i have posted and modify accordingly ie. remove the IP and put it under the bvi interface and add the "brige group 1" command under the vlan 1 interface.
Jon
Thst looks like it is included in your config list. Is that correct? I am a newbie to the Cisco environment. Thanks.
Hi Jon - this is my boot information after I pasted your commands. The one thing I noticed was the BV1 state is down.
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
[OK]
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Right
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(15)T9, RE
LEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 29-Apr-09 05:52 by prod_rel_team
Image text-base: 0x8002007C, data-base: 0x81A77A68
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Installed image archive
Cisco 871W (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of mem
ory.
Processor board ID FHK124920CF
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
1 802.11 Radio
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
SETUP: new interface NVI0 placed in "shutdown" state
% There may not be enough space available to collect the complete crashinfo
% It would be advisable to have 280755 bytes free space on flash:crashinfo
Press RETURN to get started!
*Mar  1 00:00:10.879: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Initialized
*Mar  1 00:00:10.883: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Enabled
*Mar  1 00:00:13.639: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar  1 00:00:13.639: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to
up
*Mar  1 00:00:14.639: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
are restricted.
User Access Verification
Password: WN: Line protocol on Interface FastEthernet4, changed state to up
*Mar  1 00:00:16.239: USB init complete.
*Feb 28 19:00:17 EST: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:
00:17 UTC Fri Mar 1 2002 to 19:00:17 EST Thu Feb 28 2002, configured from consol
e by console.
*Feb 28 19:00:18 EST: %SYS-5-CONFIG_I: Configured from memory by console
*Oct  5 03:09:33 EST: %SYS-5-RESTART: System restarted --
*Oct  5 03:09:33 EST: %SNMP-5-COLDSTART: SNMP agent on host SJMRouter is undergo
ing a cold start
*Oct  5 03:09:33 EST: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Oct  5 03:09:33 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0,
changed state to up
*Oct  5 03:09:33 EST: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning freque
ncies for 19 seconds
*Oct  5 03:09:33 EST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Oct  5 03:09:33 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chan
ged state to down
*Oct  5 03:09:33 EST: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Oct  5 03:09:34 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
*Oct  5 03:09:34 EST: %LINK-5-CHANGED: Interface NVI0, changed state to administ
ratively down
*Oct  5 03:09:34 EST: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to
up
*Oct  5 03:09:34 EST: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to
up
*Oct  5 03:09:34 EST: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to
up
*Oct  5 03:09:34 EST: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Oct  5 03:09:35 EST: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Oct  5 03:09:35 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et3, changed state to down
et2, changed state to down
et1, changed state to down
et0, changed state to down
*Oct  5 03:09:53 EST: %DOT11-6-FREQ_USED: Interface Dot11Radio0, frequency 2427
selected
*Oct  5 03:09:53 EST: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  5 03:09:54 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Oct  5 03:10:04 EST: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Oct  5 03:10:05 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
% Password:  timeout expired!
Password:
Full reset of the LAN. Still cannot access Internet via Wifi....
Stan
Can you post new config + the output of "sh ip int brief"
Jon
Hi Jon -
SJMRouter#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES DHCP   up                    down
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.1              unassigned      YES unset  up                    up
Vlan1                      unassigned      YES NVRAM  up                    down
Loopback0                  unassigned      YES NVRAM  up                    up
NVI0                       unassigned      YES unset  administratively down down
BVI1                       192.168.1.1     YES NVRAM  up                    up
SJMRouter#
