Wireless Packets Question
Iluvnetwork
Level 3
Level 3
Is it possible to capture other people's wireless packets? Because compared to wire packets, wireless packets are just flying around right? If possible, how can I capture? Also how can I prevent other people capturing my wireless packets?
johnd2310
Level 11
Level 11
Yes, you can. That is why you should use wireless encryption (wpa2/aes). You should also be careful when using open wireless networks,
You can capture wireless traffic using wireshark and aircap .
 https://www.riverbed.com/au/products/steelcentral/steelcentral-riverbed-airpcap.html
you cannot really prevent others from capturing your traffic. You only protection is to ensure you encrypt sensitive traffic
thank
John
**Please rate posts you find helpful**
