WLC 5508 configuration, 3650 switch conf and Aircap AP's.
JanWan
Hi all.
Im pretty new with cisco so i need help. Thanks alot :)
So here is my case:
I have 2 cisco 5508 WLC's, Catalyst 3650 and Aircap AP's
First of all. I have all specs (ip's etc).
Do i have to connect WLC together via redundancy before i start to configure first WLC? After boot does configuration automaticly move to secondary WLC configuration?
How do i connect WLC's to a switch? (Physical cabling?)
Do i have to log on 3650 and create vlans?
Where i connect all the ap's? How do i stage ap's?
Those are very noob questions. I have a clue how to do this but i need a confirm that im doing it right.
So if anyone can do a step By step guide to a cisco beginner i would be more than happy :)
indeed if you connect both WLCs via the redundancy port, the configuration will be synchronized from the Active to the Standby WLC.
If you are looking to start everything from scratch, the below document might be a good starting point:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/High_Availability_DG.html#pgfId-43357
