WLC HA Pair,Virtual WLC  N+1
Hi, what roles do the following do in the link below? (pages 27,29)
N+1
http://www.cisco.com/en/US/netsol/ns656/networking_solutions_design_guidances_list.html#anchor2
Thanks in advance
Cristian Matei
     The provided link points me to the Genral Page of Design Guide. You can have two different type of HA with WLC, these being mutually exclusive:
              - HA wit AP SSO: https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-7/High_Availability_DG.html
              - HA with N+1 WLC: https://www.cisco.com/c/en/us/td/docs/wireless/technology/hi_avail/N1_High_Availability_Deployment_Guide/N1_HA_Overview.html
Cristian Matei.
Thanks professor, I've attached a scenario, I'd be gratitude if you answer it as well. I wish to know configuration needed to establish connectivity between clients of my topology.
Thanks again
   Not sure how the initial question related to WLC HA, relates to your attached diagram. As you have VLAN's spanned across switches, you would need the links between switches to be trunk (ideally portchannel not independent links), and have the default gateway for all VLAN's in the middle switch, via SVI's.
Cristian Matei.
