08-02-2022 02:48 AM
I have a 4500 with 2 supervisor engines "WS-X4516-10GE". One of them in rommon because of not having the same ios as the active one. My question is when i copy the same ios and bring it up how do i make sure it doesn't become primary and active as for sure it will have wrong or empty config?
08-02-2022 04:18 AM
- It won't come up as primary , and it will sync the configuration from the primary automatically (make sure the running-config is saved on an external repository too). That way restoring becomes easy in case of problems.
M.
08-02-2022 10:16 PM
what about after booting up the second supervisor with the same version things didn't work and i had to reboot the switch? how do i know which supervisor will take priority and become primary?
08-02-2022 11:10 PM
- Current primary will remain in effect
M.
08-02-2022 11:32 PM
but how do i know the current working supervisor is the primary? what if it was the secondary before the other supervisor went down?
