write erase accidentally
amit bhatnagar
Level 3
Level 3
hello ,
I have given command on switch write erase accidentally , but not reloaded the switch , just wated to now will there any impact .
Thanks for help
2 Accepted Solutions
John Blakley
If you did a write erase, but didn't reload the switch, you should be able to do a write command and save it back. If the switch reloads now, there will be no config on it.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Jon Marshall
Amit
As long as you haven't reloaded the switch you will be fine. The write erase deletes the startup configuration not the running configuration.
You need to do a "wr mem" or a "copy run start" to save the current running config to the startup configuration.
Then do a "sh startup-config" to make sure it has been saved properly.
Jon
John Blakley
HTH,
John
Jon Marshall
Amit
Jon
