Write to SPAN port possible?
swain9063058
Hi All,
What I'm asking might be a stupid question, but what I'm wanting to know is whether it's possible to communicate with the switch when the PC is connected to a SPAN interface?
For context I have my switch (3750) configured for use with SNMP, my SNMP monitoring PC receives the SNMP trap messages when a port becomes up/down (as configured). However when I configure the switch port interface my SNMP monitoring PC is connected to as a SPAN port, I no longer receive the SNMP trap message. (not sure why)
I was hoping that by setting up a dedicated VLAN e.g. 999 with an IP Address on the switch I could use the ingress vlan x parameter as part of the monitor session x destination command i'd then be able to communicate directly with the switch, without being able to communicate with other traffic on the network.
Mark Elsen
 - Not possible ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
