WRR QoS unused traffic classes
Peter Koltl
Level 7
Level 7
We are planning QoS for the enterprise LAN and MPLS core. At present, there are 5 traffic classes identified and no VoIP traffic. We could allocate resources and bandwidth for 5 queues and deploy such configs. But I guess it's worth defining all 8 classes and allocate queue limits and bandwidth to them. Later it will be easier to mark the new traffic and classify it into the unused queues without modifying the wrr config.
67xx 1p7q8t line card
Q3 and Q8(PQ) will not be used. 5+15% is allocated to them.
priority-queue queue-limit 15
wrr-queue queue-limit 30 15 5 10 15 5 5
wrr-queue bandwidth percent 30 15 5 10 15 5 5
I'm not sure if the allocated bandwidth and queue limit for the unused queues will affect  the existing traffic and limit the aggregated traffic quantity. Will the 5 classes be able to fill the bandwidth until there is no congestion? What happens in case of congestion? Can the traffic excess 80% or not? (For simplicity, 100% is regarded as a fraction of link capacity defined by max-reserved-bandwidth)
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Generally, unless you're shaping or policing, bandwidth sharing commands provide a minimum bandwidth guarantee, and unused bandwidth can be used by other queues.  Also when working with more than one queue, relative ratios are usually preserved.  So, for instance, if q1 was configured for 25%, q2 for 25% and q3 for 50%, if q2 had no traffic, and q1 and q3 wanted all they could have, they would split the bandwidth 1:2 or 1/3 to 2/3.
