3750g and 3750x High Memory Utilization
Rich Rangel
We had a stack of 4 qty 3750g running IP base on ver 12.2.32, then installed a 3750x to the stack and upgraded the whole stack to 15.0.2 SE3. In doing so, we noticed that the memory utilization jumped from 60-70% to 83-84%.
We had the same issue occur when upgrading to 15.0.2 SE3 on another stack that was 6 qty 3750g running ip-services, but this one jumped to 90%.  On the 6 qty stack, we downgraded to 12.2.55 and the memory util went back down to 60-70%.
On the mixed stack, we replaced the 3750x with another 3750g and downgraded the whole stack to 12.2.55, however, the memory utilization did not drop down.  As far as I can tell, no config changes have changed from the original IOS.  Any thoughts or directions that you can think of to try would be greatly appreciated.  Thank you.
5 Replies 5
InayathUlla Sharieff
HI Rich,
As we are keep on posting/updating that kindly dont upgrade the software to
We are requesting the users on this forum to upgrade the Cisco 3560/3750 devices to 12.2(55)SE7 which is quite stable and works like a champ.Untill unless you require new featues which you are looking for you then you can thing of
15.0(2)SE2 version.
NOTE:Kindly as of now dont think of upgrading to 15.0(2)SE3 as few issues been seen and we are currently working on it.
Plz see this thread:https://supportforums.cisco.com/thread/2221688?tstart=0
Inayath
*********PLZ RATE THIS POST IF THIS IS HELPFULL AND MARK AS CLOSED IF THIS ANSWERD YOUR QUERY****
Leo Laohoo
I agree with Inayath.  Stay away from 15.0(2)SE3.
Use 12.2(55)SE7.
Post the output to the command "sh version".
sh version
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:16 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
uptime is 2 days, 12 minutes
System restarted at 22:26:59 CDT Mon Jun 10 2013
System image file is "flash:/c3750-ipbasek9-mz.122-55.SE7/c3750-ipbasek9-mz.122-55.SE7.bin"
Configuration register is 0xF
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750G-48PS     12.2(55)SE7           C3750-IPBASEK9-M
     2 52    WS-C3750G-48PS     12.2(55)SE7           C3750-IPBASEK9-M
     3 52    WS-C3750G-48PS     12.2(55)SE7           C3750-IPBASEK9-M
     4 52    WS-C3750G-48PS     12.2(55)SE7           C3750-IPBASEK9-M
     5 52    WS-C3750G-48PS     12.2(55)SE7           C3750-IPBASEK9-M
Good way to go. All the devices in stack are on safe software.
So are you facing any issues currently?
Inayath
I am also experiencing a high memory load. I'm using software: Version 15.0(2)SE2, RELEASE SOFTWARE (fc1) on a WS-C3750G-24TS-1U.
I looked at current IOS versions for this device and it looks like: c3750-ipservicesk9-mz.150-2.SE5.bin is the latest. Does anyone know if this would fix the memory usage issue?
