06-02-2013 12:56 PM - edited 03-07-2019 01:41 PM
I am interesting in 2 bundles (WS-C4507RE+96V+ and WS-C4510RE-S7+96V+) which described in the FAQ of New Cisco Catalyst 4500 E-Series Redundant Chassis (question 9 and 10):
WS-C4507R+E and WS-C4510R+E. They say, that both bundles have installed:
I have some questions about this:
Solved! Go to Solution.
06-02-2013 01:39 PM
If you want to get an accurate configuration, use the dynamic configuration tool
https://apps.cisco.com/qtc/config/html/configureHomeGuest.html
Power supplies dont included in bundle and I should order its separately?
That is correct, usually you add the power supply to your order. It does not come with the chassis.
How about SMARTnet part number(s) on bundle if I'll order some more modules/cards (i.e. redundant supervisor of right type and 10G fiber line cards)?
The same here. SmarNet is usually separate.
Retail GPL price for any bunlde is lower (~30%) than separately parts costs total. Is it ok?
Sometimes, bundle is cheaper, but after you put some configs together using the above link, talk to you sales person. It also depends on the discount level you get.
06-02-2013 04:30 PM
Is it normal that bundle costs (by GPL price) more cheaper than the same parts separately ?
Yes, usually that is the case.
Now, that you have a pretty good config, talk to you sales rep to make sure you get the proper discount, correct SmartNet contract, etc..
06-02-2013 01:39 PM
06-02-2013 03:14 PM
Nice tool, thank you. My configuration is:
| WS-C4507RE+96V+ WS-C4507R+E Chassis, two WS-X4648-RJ45V+E, Sup7L-E, LAN Base | 1 | |
| PWR-C45-1300ACV Catalyst 4500 1300W AC Power Supply (Data and PoE) | 1 | |
| PWR-C45-1300ACV/2 Catalyst 4500 1300W AC Power Supply (Data and PoE) | 1 | |
| CAB-CEE77-C19-EU CEE 7/7 to IEC-C19 13ft Europe | 2 | |
| C4500E-S7L-DEFAULT Default WS-X45-SUP7L-E with WS-X4648-RJ45V+E Bundle | 1 | |
| WS-X45-SUP7L-E/2 Catalyst 4500 E-Series Supervisor 7L-E, 520Gbps redundant | 1 | |
| WS-X4648-RJ45-E Catalyst 4500 E-Series 48-Port 10/100/1000 (RJ45) | 1 | |
| WS-X4606-X2-E Catalyst 4500 E-Series 6-Port 10GbE (X2) | 1 | |
| X2-10GB-LRM 10GBASE-LRM X2 Module | 3 | |
| S45EUK9-33-1511SG CAT4500e SUP7-E/SUP7L-E Universal Crypto Image | 1 | |
| Included: WS-X4648-RJ45V+E Catalyst 4500 E-Series 48-Port PoE+ Ready 10/100/1000(RJ45) | 2 | |
| Included: WS-X45-SUP7L-E Catalyst 4500 E-Series Supervisor 7L-E, 520Gbps | 1 | |
| Included: C4500E-IPB Paper IP Base License | 1 | |
It included IP BASE license (cost 0) which be able to use SSO feature for failover supervisors.
06-02-2013 03:35 PM
Hmmmm ... I would recommend you wait for the next few weeks (after Cisco Live).
There's a new supervisor card about to come out.
06-02-2013 04:30 PM
06-02-2013 05:00 PM
How about SMARTnet contracts? I found only
| CON-SNT-C4507REV | SMARTNET 8X5XNBD WS-C4507R+E Chassis,2 WS-X4648-RJ45V+E |
but supervisor, line cards not included. How to cover rest parts by smartnet?
06-02-2013 05:27 PM
SMARTnet covers the entire chassis, whcih will include Supervisor cards, line cards, fan trays, power supply.
06-02-2013 05:44 PM
Correct. As Leo also said it correctly, the SmartNet covers the entire chassis which includes all the parts.
06-02-2013 07:11 PM
Reza, PM sent.
06-02-2013 07:21 PM
Go it.
Thanks Leo!!
Reza
06-02-2013 06:23 PM
Thanks to all for answers
