WS-C2960-48PST-S --vs-- WS-C2960-48PST-L
ennajibrahim
i want to know what is the differnet between IOS of the catalyset WS-C2960-48PST-S  and the IOS of catalyset WS-C2960-48PST-L.
a want to upgrad the IOS of a WS-C2960-48PST-S with the IOS of  WS-C2960-48PST-L (because this réference hase a LANBASE version of IOS).
thank you in advance.
siddhartham
Level 4
Level 4
Found the below post
Q. Can I upgrade or downgrade a Cisco Catalyst 2960 Switch between the LAN Base and LAN Lite IOS images?
A. No. Cisco Catalyst 2960 Series Switches cannot be upgraded from LAN  Lite to LAN Base and cannot be downgraded from LAN Base to LAN Lite.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_qas0900aecd80322c37.html
Siddhartha
siddhartham
Level 4
Level 4
Siddhartha
Thank you siddhartham for replaying to my question,
Exactly i'v 2960 LANLITE and I want to upgrad to LANBase because the LANLIT it support just 64 vlans,now it's impossible to do that,but i have to find a solution about the number of vlan supported in my catalyst 2960 LANLIT image,have you any solutions please?
thank you.
I believe the only way is to upgrade the hardware, if you need more than 64 VLANs.
Siddhartha
Thank you, I belive that there is more than a way(change hardware) for this problme.
