WS-C2960C-8TC-L Network Navigator, configuration problem
Muehlental
Hello everybody,
I have problems commissioning a WS-C2960C-8TC-L using Network Navigator.
Initial setup was sucessful, but when trying to configure VLAN(s) I do not get a dialogue for configuring address range etc. (see screenshots in the attached document).
1) Can you help me please?
2) Network Navigator is discontinued. Is there a successor product?
Thank you very much in advance!
M02@rt37
Hello @Muehlental
You are on L2 configuration, no ip address here.
Go to Devices properties. Since your VLAN_USER is vlan id 2, configure subnet under vlan 2.
Best regards
13 Replies 13
Mark Elsen
             - Configure the device , using the CLI instead ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for your answer, but somebody from Cisco is giving me a solution using Network assistant.
balaji.bandi
Never used any GUI to configure 2960 back in days, best and simple is Cli.
BB
Thank you for your answer, but somebody from Cisco is giving me a solution using Network Assistant.
       >..., but somebody from Cisco is giving me a solution using Network Assistant.
   - Strange because Network Assistant is obsolete , get familiar with the CLI too , useful
 M.
       Beauty and terror
      Just keep going
       No feeling is final
M02@rt37
Hello @Muehlental
Best regards
New problem, see attachment. I read the documentation but unfortunately do no seem to be able to solve the issue. My electronics and software provider has a lot of knowledge about VLANs but usually configures hp switches and thus was not able to solve the issue either. Thank you very much in advance!
 Hello @Muehlental
where is the DHCP configuration ? It should be hosted on a dedicated server or in a L3 equipment (router/L3 Switch) or on your C2960 !
Best regards
I have a DSL-Modem/WLAN-Router/LAN-Switch (192.168.100.1) for the 192.168.0.x network. The C2960 is connected to the LAN-Switch and I configured as Gateway 192.168.100.1. Is that correct? How do I configure the DHCP on the C2960 for the VLANs??
Thank you in advance.
@Muehlental
Which models for the LAN-Switch and the WAN-Router ?
Best regards
LAN-Switch and WAN-Router are non-Cisco products.
In the attached document the values I want to apply and I assume are correct and how I configure them using Netwark Assistant. Thank you in advance for your help!
Muehlental
Thank you very much, I found it. I will now try to proceed by myself.
