WS-C2960G-24TC-L IOS question.
jamesmpoplar
Hey everyone, this should be a quick once.
I was under the impression that c2960-lanbasek9-mz.122-40.SE.bin should be okay to load onto the WS-C2960G-24TC-L,
but when I tftped the file over to my switch and setup the boot sequence like so:
BOOT path-list : flash:/c2960-lanbasek9-mz.122-40.SE.bin;flash:/c2960-lanbase-mz.122-25.SEE3/c2960-lanbase-mz.122-25.SEE3.bin
It starts to load the new IOS, says it has an error loading, and starts my older version up just fine.
So...did I just not read well enough and attempt to load on an invalid image?
If not...any suggestions on how to get it to load right would be handy.
5 Replies 5
JORGE RODRIGUEZ
Level 10
Level 10
James, if in doubt best is to go to software advisory and do a search by platform c2960 which will point you to right codes..if the one you downloded is the correct version delete it and tftp it again, it may have gotten currupted .
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
CCO required / under software tools pick Software advisory - the software by platform
http://www.cisco.com/public/sw-center/
Jorge
Jorge Rodriguez
Well, I've reloaded the .bin a couple of times, and the verify command says that the image is good.
As far as I can tell...this SHOULD load on this switch with no issues.
glen.grant
If you do a "dir flash: do both show up ? Looks like the old one is in a directory . Does the 2960 have enough room for 2 images ? I know the older 2950's could only hold 1 image at a time . Verify you have a complete new ios file .
Well, dir flash: shows them both:
32514048 bytes total (20805632 bytes free)
PASASW0007#dir flash:
Directory of flash:/
2 -rwx 1216 Feb 28 1993 17:01:07 -07:00 vlan.dat
3 -rwx 27 Sep 17 2007 11:08:05 -06:00 private-config.text
4 -rwx 3991596 Sep 17 2007 13:02:45 -06:00 c2960-lanbasek9-mz.122-40.SE.bin
5 drwx 192 Feb 28 1993 17:06:31 -07:00 c2960-lanbase-mz.122-25.SEE3
621 -rwx 4165 Sep 17 2007 11:08:05 -06:00 config.text
And they are both the same size, from the UNIX TFTP server to the flash itself.
The .bin file should be all I need. It appears the directory is there mostly because the HTTP is enabled on the old image.
It gets about this far:
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:/c2960-lanbasek9-mz.122-40.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Error loading "flash:/c2960-lanbasek9-mz.122-40.SE.bin"
Ha!
The problem was that the version on the tftp server was actually a different version of IOS, but renamed funny when it was sftped to the tftp server.
Therefor it would verify just fine. :) Works fine now. Thanks for all the possible solutions.
