WS-C2960S-48FPS-L stack port DOWN
jguandalini
Hello guys, I'm trying to configure a stack between two WS-C2960S-48FPS-L but does not working.
The switch port is always Down.
I tried to change de module and cables.
I tried to make a loop in one of two switches and the ports always down.
IOS: 12.2(55)SE5
#show switch stack-ports
  Switch #    Port 1       Port 2
    1          Down         Down
Anyone could help me please?
Thanks in advance.
Ohhhhh ... THAT error message.  Now it makes sense.  LOL
Power down your switch, remove the stacking module.
GIVE IT A FEW SLAP and put it back in.
15 Replies 15
Reza Sharifi
Can you check to make sure you have LAN Base image installed?
Yes, lanbase is OK.
show license
Index 1 Feature: lanlite
        Period left: 0  minute  0  second
Index 2 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
IOS file: c2960s-universalk9-mz.122-55.SE5.bin
Post the output to the command "sh inventory raw".
Hi leolaohoo,
I saw this error on my logging now:
Mar 15 11:14:15.458: %ILET-1-DEVICE_AUTHENTICATION_FAIL: The FlexStack Module inserted in this switch may not have been manufactured by Cisco or with Cisco's authorization. If your use of this product is the cause of a support issue, Cisco may deny operation of the product, support under your warranty or under a Cisco technical support program such as Smartnet.  Please contact Cisco's Technical Assistance Center for more information.
If I reload the switch, this error don't appear again.
follow the results:
show inventory raw
NAME: "C29xx Stacking", DESCR: "Catalyst C29xx Switch Stack"
PID:                   , VID:      , SN:
NAME: "1", DESCR: "WS-C2960S-48FPS-L"
PID: WS-C2960S-48FPS-L , VID: V03  , SN:
NAME: "Switch 1 - Fan Container", DESCR: "Fan Container"
PID:                   , VID:      , SN:
NAME: "Switch 1 - Power Supply Container", DESCR: "Power Supply Container"
PID:                   , VID:      , SN:
NAME: "Switch 1 - RPS Container", DESCR: "RPS Container"
PID:                   , VID:      , SN:
NAME: "Switch 1 - WS-C2960S-48FPS-L - Power Supply 0", DESCR: "Switch 1 - WS-C2960S-48FPS-L - Power Supply 0"
PID:                   , VID:      , SN:
NAME: "Switch 1 - WS-C2960S-48FPS-L - Fan 0", DESCR: "Switch 1 - WS-C2960S-48FPS-L - Fan 0"
PID:                   , VID:      , SN:
NAME: "Switch 1 - WS-C2960S-48FPS-L - Sensor 0", DESCR: "Switch 1 - WS-C2960S-48FPS-L - Sensor 0"
PID:                   , VID:      , SN:
NAME: "Switch 1 - WS-C2960S-48FPS-L - Fixed Module 0", DESCR: "Switch 1 - WS-C2960S-48FPS-L - Fixed Module 0"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/49 Container", DESCR: "GigabitEthernet Container"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/49", DESCR: "1000BaseSX SFP"
PID: Unspecified       , VID:      , SN:
NAME: "GigabitEthernet1/0/50 Container", DESCR: "GigabitEthernet Container"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/51 Container", DESCR: "GigabitEthernet Container"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/52 Container", DESCR: "GigabitEthernet Container"
PID:                   , VID:      , SN:
NAME: "StackPort1", DESCR: "StackPort1"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/1", DESCR: "GigabitEthernet1/0/1"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/2", DESCR: "GigabitEthernet1/0/2"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/3", DESCR: "GigabitEthernet1/0/3"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/4", DESCR: "GigabitEthernet1/0/4"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/5", DESCR: "GigabitEthernet1/0/5"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/6", DESCR: "GigabitEthernet1/0/6"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/7", DESCR: "GigabitEthernet1/0/7"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/8", DESCR: "GigabitEthernet1/0/8"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/9", DESCR: "GigabitEthernet1/0/9"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/10", DESCR: "GigabitEthernet1/0/10"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/11", DESCR: "GigabitEthernet1/0/11"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/12", DESCR: "GigabitEthernet1/0/12"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/13", DESCR: "GigabitEthernet1/0/13"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/14", DESCR: "GigabitEthernet1/0/14"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/15", DESCR: "GigabitEthernet1/0/15"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/16", DESCR: "GigabitEthernet1/0/16"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/17", DESCR: "GigabitEthernet1/0/17"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/18", DESCR: "GigabitEthernet1/0/18"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/19", DESCR: "GigabitEthernet1/0/19"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/20", DESCR: "GigabitEthernet1/0/20"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/21", DESCR: "GigabitEthernet1/0/21"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/22", DESCR: "GigabitEthernet1/0/22"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/23", DESCR: "GigabitEthernet1/0/23"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/24", DESCR: "GigabitEthernet1/0/24"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/25", DESCR: "GigabitEthernet1/0/25"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/26", DESCR: "GigabitEthernet1/0/26"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/27", DESCR: "GigabitEthernet1/0/27"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/28", DESCR: "GigabitEthernet1/0/28"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/29", DESCR: "GigabitEthernet1/0/29"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/30", DESCR: "GigabitEthernet1/0/30"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/31", DESCR: "GigabitEthernet1/0/31"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/32", DESCR: "GigabitEthernet1/0/32"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/33", DESCR: "GigabitEthernet1/0/33"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/34", DESCR: "GigabitEthernet1/0/34"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/35", DESCR: "GigabitEthernet1/0/35"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/36", DESCR: "GigabitEthernet1/0/36"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/37", DESCR: "GigabitEthernet1/0/37"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/38", DESCR: "GigabitEthernet1/0/38"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/39", DESCR: "GigabitEthernet1/0/39"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/40", DESCR: "GigabitEthernet1/0/40"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/41", DESCR: "GigabitEthernet1/0/41"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/42", DESCR: "GigabitEthernet1/0/42"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/43", DESCR: "GigabitEthernet1/0/43"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/44", DESCR: "GigabitEthernet1/0/44"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/45", DESCR: "GigabitEthernet1/0/45"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/46", DESCR: "GigabitEthernet1/0/46"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/47", DESCR: "GigabitEthernet1/0/47"
PID:                   , VID:      , SN:
NAME: "GigabitEthernet1/0/48", DESCR: "GigabitEthernet1/0/48"
PID:                   , VID:      , SN:
NAME: "Switch 1 - FastEthernet0", DESCR: "FastEthernet0"
PID:                   , VID:      , SN:
Did the flex stack module/cable come with the switch or you purchased it separately?
I buyed with the stack module.
Ok, I will try to do this, but this switch in production now. I can't do this now.
Ok.  I've seen this before and this is how I've fixed issues/error messages like that.
I had restarted this switch before, and this message does not appeared and the stack does not worked.
This message appeared after I try to remove and put the stackmodule with switch powered.
Even without this message the stack port always Down.
Judging from the serial number, I say you purchased the switch after April 2012.  So if you still can't get it to work, get Cisco to RMA you a new stacking module.
Just want to let you know that you can stack UP TO four 2960S in a stack.  You can't stack five or more.
Ok, thanks. I'm trying stack 2 switches only.
I agree with Leo,  If you have warranty on this switch, just open a ticket with TAC and RMA to Cisco.  Let them take care of their defective product.
