WS-C2960X-24PS-L ports administratively shutdown after failed POST in Inline Power test
Moses Munguti
I have a Cisco switch(WS-C2960X-24PS-L) that powers up then administratively shuts down only the first four ports. All the remaining 20 ports function as normal access ports without any errors.
Below is the error according to the switch log :
Oct  1 10:58:43.637 GMT: %PLATFORM_ENV-3-ILP_PORT_POST_ERR: Gi1/0/1 can't be brought up because it failed POST in Inline Power test.
Oct  1 10:58:43.651 GMT: %PLATFORM_ENV-3-ILP_PORT_POST_ERR: Gi1/0/2 can't be brought up because it failed POST in Inline Power test.
Oct  1 10:58:43.665 GMT: %PLATFORM_ENV-3-ILP_PORT_POST_ERR: Gi1/0/3 can't be brought up because it failed POST in Inline Power test.
Oct  1 10:58:43.697 GMT: %PLATFORM_ENV-3-ILP_PORT_POST_ERR: Gi1/0/4 can't be brought up because it failed POST in Inline Power test.
CSW-XX-01#sh ip int br
GigabitEthernet1/0/1   unassigned      YES unset  administratively down down
GigabitEthernet1/0/2   unassigned      YES unset  administratively down down
GigabitEthernet1/0/3   unassigned      YES unset  administratively down down
GigabitEthernet1/0/4   unassigned      YES unset  administratively down down
Kindly assist
Probably a permanent issue then unfortunately. Hopefully you have Smartnet or can live with it. Though I'd be cautious that it won't happen to the others.
Thomas Johnston
Most of what I'm seeing is potential ASIC issues although one thing you could try is to disable PoE on those interfaces (power inline never) and then try to "no shut" them to see if they can be brought online. You would at least get switching but no PoE if that works.
I tried a shut and a no shut on the ports but still they are administratively shutdown.
Also a reset(default) of the interfaces and a no shut could not bring up the ports.
Disabling PoE on the ports also could not bring up the ports.
