08-26-2010
04:57 PM
- last edited on
03-25-2019
04:11 PM
by
ciscomoderator
CORE# show env fan
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
I wanted to see what the html version showed and in this format we have FAN 4 Failure Alerts. Please see attached. Can anyone tell me if there is or should be a FAN 4 to begin with?
Pleases see the attached image
Solved! Go to Solution.
08-26-2010 04:59 PM
Fan 4 is should be coming from the redundant Power Supply. If you don't have a redundant power supply option installed, then please disregard this.
If you do, then contact Cisco TAC and request for an RMA of the faulty component.
Please don't forget to rate useful posts. Thanks.
08-26-2010 05:15 PM
Thanks for the ratings. It doesn't report a "failure", per se. It just says that it can't detect the fan for the redundant PS.
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
TEMPERATURE is OK
Temperature Value: 25 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
2A C3KX-PWR-350WAC LIT14170SEW OK Good Good 350/0
2B Not Present
SW Status RPS Name RPS Serial# RPS Port#
2 Not Present <>
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
TEMPERATURE is OK
1A C3KX-PWR-350WAC LIT14170SDS OK Good Good 350/0
1B C3KX-PWR-350WAC LIT14140RF6 OK Good Good 350/0
2B Not Present
1 Not Present <>
2 Not Present <>
08-26-2010 04:59 PM
08-26-2010 05:07 PM
This was useful and I will provide the feed back, thanks.
My quesiton still remains though and that is why the HTML interface displays 4 fan as in a failure state?
08-26-2010 05:15 PM
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
TEMPERATURE is OK
2B Not Present
2 Not Present <>
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
TEMPERATURE is OK
2B Not Present
1 Not Present <>
2 Not Present <>
08-26-2010 06:23 PM
Thanks for the ratings. Glad to be of some useful assistance.
