WS-C3560X-24 Packet drops and High latency issues
Anil M
We have a Cisco L3 WS-C3560X-24 switch configured as a gateway for our internal network. For last one week, we are seeing high latenct issues to the internal hosts and public hosts. (When I checked the logs, there are continuous messages on flapping between 2 interfaces), I have verified for any network loops, there is nothing,
Disconnected all the switches, and connected only L3, Sophos, and a wifi access point(Cisco 2900 mobility express). still the latency issue persists it goes to <100ms from 3ms >, ping drops after 20-30 requests and comes back normal.
I am unable to figure out wether the switch should be replaced or configurations has to be changed.
I have attached the tech-support and interfaces output files as well. Please suggest what should be done to resolve the issues.
IOS version: c3560e-ipbasek9-mz.150-2.SE
- This L3 is acting as a core router, we have Sophos XGS4300 at the perimeter level.
The CPU usage is high, But there are no high-consuming processes, please refer below
L3switch12#show processes cpu sorted
CPU utilization for five seconds: 14%/2%; one minute: 14%; five minutes: 14%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  83      211568       41538       5093  2.08%  1.92%  1.83%   0 RedEarth Tx Mana
  12      114563      198143        578  1.43%  1.01%  1.01%   0 ARP Input
171      116799        9518      12271  1.27%  0.71%  0.72%   0 HL3U bkgrd proce
  53        6214         180      34522  0.63%  0.07%  0.02%   0 Per-minute Jobs
  82       43759       56857        769  0.47%  0.38%  0.42%   0 RedEarth I2C dri
232        6885       50393        136  0.31%  0.13%  0.08%   0 Spanning Tree
139         796         125       6368  0.31%  0.06%  0.11%   1 SSH Process
  89        1608        4228        380  0.15%  0.02%  0.00%   0 Adjust Regions
214       16544       41366        399  0.15%  0.20%  0.19%   0 IP Input
  42        1493       14213        105  0.15%  0.02%  0.00%   0 Net Background
346         981      331026          2  0.15%  0.01%  0.00%   0 MMON MENG
180       17534        2138       8201  0.15%  0.15%  0.15%   0 HQM Stack Proces
   4      184671        8196      22531  0.00%  2.03%  1.64%   0 Check heaps
  11           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  10       24088         178     135325  0.00%  0.18%  0.17%   0 Licensing Auto U
  13         156       11179         13  0.00%  0.00%  0.00%   0 ARP Background
  14           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  15           0           9          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  19           0        2132          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  16           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  21           0         179          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  17          17           7       2428  0.00%  0.00%  0.00%   0 Entity MIB API
   8           0         210          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  18           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  20          16       10365          1  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  27          95        2677         35  0.00%  0.00%  0.00%   0 IPC Seat Manager
  28           0         611          0  0.00%  0.00%  0.00%   0 IPC Check Queue
   6           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  24           0       10365          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  32          34        2132         15  0.00%  0.00%  0.00%   0 IPC Loadometer
  33          33           4       8250  0.00%  0.00%  0.00%   0 PrstVbl
  34           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  35           8           1       8000  0.00%  0.00%  0.00%   0 Exception contro
  36          17       10617          1  0.00%  0.00%  0.00%   0 GraphIt
   9           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  38           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  39           0           1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  40          66       10594          6  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  41           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
   7           0           2          0  0.00%  0.00%  0.00%   0 Timers
  25           8       10365          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  44           0         211          0  0.00%  0.00%  0.00%   0 Logger
  26           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  46           0           3          0  0.00%  0.00%  0.00%   0 CTS CORE
Appreciate the help. Thanks.
5 Replies 5
Leo Laohoo
@Anil M wrote:
I have some chatgpt suggestions based on the CPU history and show interfaces command outputs.
Anil M
can anyone help, please?
Suggestion - in the future, ask for help and provide information, especially as requested, w/o including Chat/gpt analysis.  My guess, most not much interest in debugging it.
BTW, I'm not slightly Chat/gpt, but similar situation if you posted Larry says "x" or I "know" the cause is "x".  I.e. general such is just an impediment to analysis.
balaji.bandi
1. what IOS code running?
2. post - show version and show run
3. Can you post example high latency output here ?
4. how is your ping responce from PC to switch gateway ?
5. how is your network diagram looks like ?
6. have you checked the interface connected to ISP side any packet drops ?
7. what kind of bandwidth you have, what % it was used.
8 you have attached the output information - you have not mentioned how these are connected in the network (post diagram)
example - we see output packet drops here  on below - after reload they not there .
GigabitEthernet0/1
GigabitEthernet0/5
GigabitEthernet0/19
GigabitEthernet0/23
BB
Leo Laohoo
If ChatGPT can spat out useless drivel based on one sentence alone, then "good luck".
