WS-C3560X-24 reboots, no crash file and clean logging after reboot
good morning to you all,
i have a WS-C3560X-24 and attached to that are some 9 acces switches,
for some weeks now my 3560 reboots some time what couse that the other 9 switches are down for some minuts as well and i dont want this of course.
the reboot happens at random times and some times one week not and then like yesterday afternoon it rebooted again.
when i check the Flash directory there is no crash file and when i look at the logging its clean and just shows the startup.
it's not the powersuply it's redundend and more L3 switches are attached to this power source and they dont reboot.
does some one have a iedea what can couse this ?
Thanks allot!!
L3_AIM#sh version
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:57 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
L3_AIM uptime is 15 hours, 23 minutes
System image file is "flash:/c3560e-universalk9-mz.122-55.SE3/c3560e-universalk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1621P0XZ
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : A4:93:4C:F6:38:00
Motherboard assembly number     : 73-12554-05
Motherboard serial number       : FDO1621124L
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3560X-24T-S
Daughterboard assembly number   : 800-32786-01
Daughterboard serial number     : FDO1620134A
System serial number            : FDO1621P0XZ
Top Assembly Part Number        : 800-31331-02
Top Assembly Revision Number    : E0
Version ID                      : V02
CLEI Code Number                : COMJU00ARB
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       12.2(55)SE3           C3560E-UNIVERSALK9-M
InayathUlla Sharieff
Hi Michael,
Is there any possibility to provide the show tech from the device?
Inayath
yes i can provide a show tech.
and no it does noy have a 2 power supplys it has only one.
but 6 other 3560 are connected to the same power source and they don't power down these have one power suply as well.
here is my show tech:
L3_AIM#sh tech
------------------ show clock ------------------
*15:07:20.697 UTC Tue Mar 2 1993
------------------ show version ------------------
L3_AIM uptime is 1 day, 15 hours, 7 minutes
export@cisco.com.
Version ID                      : V02
Configuration register is 0xF
------------------ show running-config ------------------
Building configuration...
Current configuration : 5743 bytes
version 12.2
no service pad
service sequence-numbers
hostname L3_AIM
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
system mtu routing 1500
ip routing
ip dhcp excluded-address 105.103.95.1 105.103.95.100
ip dhcp pool Voice_244
   network 105.103.95.0 255.255.255.0
   default-router 105.103.95.1
   option 150 ip 105.103.247.4 105.103.247.5
crypto pki trustpoint TP-self-signed-1291204608
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1291204608
revocation-check none
rsakeypair TP-self-signed-1291204608
crypto pki certificate chain TP-self-signed-1291204608
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323931 32303436 3038301E 170D3933 30333031 30303031
  32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32393132
  30343630 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A3A8 B72D25DB 04788483 A4078BF0 6E4051BC B895B2F5 EDD6A6E9 5BBCE751
  6F365A28 EA83946F 839E6B29 4A1E3736 74924B01 A7F28B23 B8A7019B 089E8313
  A4B1B747 F8AEC6EF 9FA8494E 7794FC87 6EBB015D 6C2BA8EA 1F8D1B62 586D41FD
  32D6AE98 D1EE19CC 679328F2 8B308887 9BDF58E8 4F8C2784 D55703F5 64D77DCB
  DA350203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 074C335F 41494D2E 301F0603 551D2304 18301680 140185A3
  D7033CDC 7D93B23D 6139A805 89433D85 18301D06 03551D0E 04160414 0185A3D7
  033CDC7D 93B23D61 39A80589 433D8518 300D0609 2A864886 F70D0101 04050003
  8181002E EE8951A5 A522F326 78DD5FD4 9D85C971 9FE13791 BA7872F5 C16654BC
  31243047 FAC25F6C A00968BF 08CD756F 8F3BEDAA 64F68E69 57C18649 AFF077F2
  B82CFFF8 F47896B1 3386F573 B6D19DAD D82CC81F E633BCC7 9FCC6E62 547FD8BD
  B749FB8E 0F436CDD 549D6BC0 9D30AD13 2F30A687 68229C12 F6343A55 DD0F0475 88077E
  quit
spanning-tree mode pvst
spanning-tree vlan 40,244 priority 24576
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1
description [ * L3#1 Uplink * ]
no switchport
ip address 105.103.89.50 255.255.255.252
interface GigabitEthernet0/2
description [ * L3#2 Uplink * ]
no switchport
ip address 105.103.89.54 255.255.255.252
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet1/1
switchport mode trunk
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
interface Vlan40
description [* 2ndfloor-PBA/ProdOffice *]
ip address 105.103.103.1 255.255.255.0 secondary
ip address 105.103.40.1 255.255.255.0
no ip redirects
interface Vlan244
description [* IP Phone DHCP Range *]
ip address 105.103.95.1 255.255.255.0
router eigrp 105
network 105.0.0.0
passive-interface GigabitEthernet0/2
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 105.103.89.49
ip route 0.0.0.0 0.0.0.0 105.103.89.53 100
ip http server
ip http secure-server
ip sla enable reaction-alerts
snmp-server community RO
snmp-server community RW
banner motd ^CC
$                   W  A  R  N  I  N  G                              *
$  Unauthorized access will be punished by a Federal Law.            *
$  For a state of emergency contact below                            *
$   Tel : 82-2-5090-111    Global Network Control Center             *
$                                Global Network Operation            *
$                                SAMSUNG SDS Inc.                    *
^C
line con 0
line vty 0 4
password
login
line vty 5 15
login
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
4520/6000   hulc_flash init
5052/6000   MDFS LC IPC Init Process
5532/6000   CDP BLOB
8288/9000   IP Background
8504/9000   EEM ED RF
4164/6000   EEM Shell Director
5516/6000   MDFS Reload
9908/12000  master cfg mgr init process
5372/6000   vqpc_shim_create_addr_tbl
5360/6000   SPAN Subsystem
5508/6000   bulk config process
58796/60000  EEM Auto Registration Proc
4876/6000   hpm bulk_vlan_state process
5332/6000   REP LSL Hello PP Process
7700/12000  Init
5324/6000   SASL MAIN
5068/6000   LICENSE AGENT DEFAULT
10716/12000  Router Init
8520/9000   cdp init process
5184/6000   RADIUS INITCONFIG
5492/6000   Hulc Backup Interface Process
35068/36000  TCP Command
5480/6000   URPF stats
2532/3000   Rom Random Update Process
4756/6000   platform OBFL
8692/12000  Virtual Exec
19444/24000  hulc_techsupport_process
Interrupt level stacks:
Level    Called Unused/Size  Name
  1           0   9000/9000  Maxwell MACsec ISR
  4  1176665807   7452/9000  NETWORK INTERFACE CHIP
  5           0   9000/9000  SUPERVISOR EXCEPTIONS
  6        6311   8932/9000  NS16550 VECTOR
------------------ show interfaces ------------------
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is a493.4cf6.3840 (bia a493.4cf6.3840)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 2 interface resets
Vlan40 is up, line protocol is up
  Hardware is EtherSVI, address is a493.4cf6.3843 (bia a493.4cf6.3843)
  Description: [* 2ndfloor-PBA/ProdOffice *]
  Internet address is 105.103.40.1/24
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 3/75/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 17000 bits/sec, 23 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     1991089 packets input, 195562098 bytes, 0 no buffer
     Received 0 broadcasts (5280 IP multicasts)
     398727 packets output, 26101060 bytes, 0 underruns
Vlan244 is up, line protocol is up
  Hardware is EtherSVI, address is a493.4cf6.3844 (bia a493.4cf6.3844)
  Description: [* IP Phone DHCP Range *]
  Internet address is 105.103.95.1/24
  Last input 00:00:03, output 00:00:03, output hang never
     70219 packets input, 12032054 bytes, 0 no buffer
     70498 packets output, 5003266 bytes, 0 underruns
FastEthernet0 is down, line protocol is down
  Hardware is PowerPC405 FastEthernet, address is a493.4cf6.3837 (bia a493.4cf6.3837)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive not set
  Auto-duplex, Auto Speed, MII
  Output queue: 0/0 (size/max)
     0 watchdog
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3841 (bia a493.4cf6.3841)
  Description: [ * L3#1 Uplink * ]
  Internet address is 105.103.89.50/30
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  5 minute input rate 8008000 bits/sec, 1058 packets/sec
  5 minute output rate 2801000 bits/sec, 887 packets/sec
     170222052 packets input, 197487847362 bytes, 0 no buffer
     Received 36684 broadcasts (34327 IP multicasts)
     0 watchdog, 36681 multicast, 0 pause input
     115487154 packets output, 36995120807 bytes, 0 underruns
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3842 (bia a493.4cf6.3842)
  Description: [ * L3#2 Uplink * ]
  Internet address is 105.103.89.54/30
  Last input 00:00:04, output 00:00:07, output hang never
     32780 packets input, 3390002 bytes, 0 no buffer
     Received 32771 broadcasts (30415 IP multicasts)
     0 watchdog, 32769 multicast, 0 pause input
     16410 packets output, 1941350 bytes, 0 underruns
GigabitEthernet0/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3803 (bia a493.4cf6.3803)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
GigabitEthernet0/4 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3804 (bia a493.4cf6.3804)
GigabitEthernet0/5 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3805 (bia a493.4cf6.3805)
GigabitEthernet0/6 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3806 (bia a493.4cf6.3806)
GigabitEthernet0/7 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3807 (bia a493.4cf6.3807)
GigabitEthernet0/8 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3808 (bia a493.4cf6.3808)
GigabitEthernet0/9 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3809 (bia a493.4cf6.3809)
GigabitEthernet0/10 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.380a (bia a493.4cf6.380a)
GigabitEthernet0/11 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.380b (bia a493.4cf6.380b)
GigabitEthernet0/12 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.380c (bia a493.4cf6.380c)
GigabitEthernet0/13 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.380d (bia a493.4cf6.380d)
GigabitEthernet0/14 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.380e (bia a493.4cf6.380e)
GigabitEthernet0/15 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.380f (bia a493.4cf6.380f)
GigabitEthernet0/16 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3810 (bia a493.4cf6.3810)
GigabitEthernet0/17 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3811 (bia a493.4cf6.3811)
GigabitEthernet0/18 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3812 (bia a493.4cf6.3812)
GigabitEthernet0/19 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3813 (bia a493.4cf6.3813)
GigabitEthernet0/20 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3814 (bia a493.4cf6.3814)
GigabitEthernet0/21 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3815 (bia a493.4cf6.3815)
GigabitEthernet0/22 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3816 (bia a493.4cf6.3816)
GigabitEthernet0/23 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3817 (bia a493.4cf6.3817)
GigabitEthernet0/24 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3818 (bia a493.4cf6.3818)
GigabitEthernet1/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a493.4cf6.3819 (bia a493.4cf6.3819)
     reliability 255/255, txload 2/255, rxload 1/255
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  5 minute input rate 2895000 bits/sec, 941 packets/sec
  5 minute output rate 8077000 bits/sec, 1069 packets/sec
     121680127 packets input, 38464318496 bytes, 0 no buffer
     Received 5344205 broadcasts (3458804 multicasts)
     0 watchdog, 3458804 multicast, 0 pause input
     171108722 packets output, 198448468792 bytes, 0 underruns
GigabitEthernet1/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.381a (bia a493.4cf6.381a)
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is Not Present
GigabitEthernet1/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.381b (bia a493.4cf6.381b)
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
GigabitEthernet1/4 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is a493.4cf6.381c (bia a493.4cf6.381c)
  Keepalive not set
TenGigabitEthernet1/1 is down, line protocol is down (notconnect)
  Hardware is not present
  Hardware is Ten Gigabit Ethernet, address is a493.4cf6.381d (bia a493.4cf6.381d)
  Keepalive not set
TenGigabitEthernet1/2 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is a493.4cf6.381e (bia a493.4cf6.381e)
  Keepalive not set
------------------ show controllers ------------------
     Transmit FastEthernet0                   Receive
            0 Bytes                                0 Bytes
            0 Unicast frames                       0 Unicast frames
            0 Multicast frames                     0 Multicast frames
            0 Broadcast frames                     0 Broadcast frames
            0 Too old frames                       0 Unicast bytes
            0 Deferred frames                      0 Multicast bytes
            0 MTU exceeded frames                  0 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames                   0 Minimum size frames
            0 8 collision frames                   0 65 to 127 byte frames
            0 9 collision frames                   0 128 to 255 byte frames
            0 10 collision frames                  0 256 to 511 byte frames
            0 11 collision frames                  0 512 to 1023 byte frames
            0 12 collision frames                  0 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
            0 64 byte frames                       0 Valid frames, too small
            0 127 byte frames
            0 255 byte frames                      0 Too old frames
            0 511 byte frames                      0 Valid oversize frames
            0 1023 byte frames                     0 System FCS error frames
            0 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
     Transmit GigabitEthernet0/1              Receive
   2635722415 Bytes                       4214691504 Bytes
    115453255 Unicast frames               170186114 Unicast frames
        34635 Multicast frames                 36681 Multicast frames
            4 Broadcast frames                     3 Broadcast frames
            0 Too old frames              4210700023 Unicast bytes
            0 Deferred frames                3991289 Multicast bytes
            0 MTU exceeded frames                192 Broadcast bytes
            0 7 collision frames            17302106 Minimum size frames
            0 8 collision frames             8837439 65 to 127 byte frames
            0 9 collision frames             8973488 128 to 255 byte frames
            0 10 collision frames            3526107 256 to 511 byte frames
            0 11 collision frames            2884244 512 to 1023 byte frames
            0 12 collision frames          128699414 1024 to 1518 byte frames
     68312472 64 byte frames                       0 Valid frames, too small
     13061437 127 byte frames
      9038392 255 byte frames                      0 Too old frames
      4704189 511 byte frames                      0 Valid oversize frames
      2975699 1023 byte frames                     0 System FCS error frames
     17395705 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
     Transmit GigabitEthernet0/2              Receive
      1941350 Bytes                          3390080 Bytes
        14055 Unicast frames                       9 Unicast frames
         2351 Multicast frames                 32770 Multicast frames
            4 Broadcast frames                     2 Broadcast frames
            0 Too old frames                     576 Unicast bytes
            0 Deferred frames                3389376 Multicast bytes
            0 MTU exceeded frames                128 Broadcast bytes
            0 7 collision frames                  11 Minimum size frames
            0 8 collision frames               30416 65 to 127 byte frames
            0 10 collision frames               2354 256 to 511 byte frames
        14056 64 byte frames                       0 Valid frames, too small
            3 127 byte frames
         2351 511 byte frames                      0 Valid oversize frames
            0 Too large frames
     Transmit GigabitEthernet0/3              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/4              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/5              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/6              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/7              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/8              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/9              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/10             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/11             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/12             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/13             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/14             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/15             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/16             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/17             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/18             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/19             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/20             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/21             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/22             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/23             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet0/24             Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet1/1              Receive
    880888193 Bytes                       4104924850 Bytes
    170805782 Unicast frames               116336862 Unicast frames
       208469 Multicast frames               3458825 Multicast frames
        95659 Broadcast frames               1885423 Broadcast frames
            0 Too old frames              2894414068 Unicast bytes
            0 Deferred frames              525695807 Multicast bytes
            0 MTU exceeded frames          198681005 Broadcast bytes
            0 5 collision frames                   1 Collision fragments
            0 7 collision frames               74872 Minimum size frames
            0 8 collision frames            85893046 65 to 127 byte frames
            0 9 collision frames             9945486 128 to 255 byte frames
            0 10 collision frames            5019209 256 to 511 byte frames
            0 11 collision frames            3064628 512 to 1023 byte frames
            0 12 collision frames            2022939 1024 to 1518 byte frames
            0 VLAN discard frames           15660930 Valid frames, too large
            0 Excess defer frames                  1 Invalid frames, too small
         4684 64 byte frames                       0 Valid frames, too small
     26454751 127 byte frames
      9280023 255 byte frames                      0 Too old frames
      3634115 511 byte frames                      0 Valid oversize frames
      2908031 1023 byte frames                     0 System FCS error frames
     29201595 1518 byte frames                     0 RxPortFifoFull drop frame
     99626711 Too large frames
     Transmit GigabitEthernet1/2              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet1/3              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit GigabitEthernet1/4              Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit TenGigabitEthernet1/1           Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
     Transmit TenGigabitEthernet1/2           Receive
            0 Bytes                                0 Bytes
            0 127 byte frames
            0 Too large frames
ASIC    Rxbiterr   Rxunder    Fwdctfix   Txbuflos   Rxbufloc   Rxbufdrain
ASIC0     0          0          0          0          0          0
ASIC1     0          0          0          0          0          0
HOL Fix Counts
No Fixes:          0 Added:          0 In Use:          0 Both:          0
CPU Heartbeat Statistics
Tx Success Tx Fail    1st Thr    2nd Thr    Unthr      RetryCtMax
   2795806          0          0          0          0          1
Rx Delay
         0          1          2          3          4
   2795806          0          0          0          0
AddlDelay AdvanceCnt
         0          0
Rx Retries by RetryCount
         0          1          2          3          4          5          6
   2795806          0          0          0          0          0          0
         7          8          9
         0          0          0
AddlRetry
cpu-queue-frames  retrieved  dropped    invalid    hol-block  stray
rpc               1          0          0          0          0
stp               2597631    0          0          0          0
ipc               0          0          0          0          0
routing protocol  894190     0          0          0          0
L2 protocol       11971      0          0          0          0
remote console    0          0          0          0          0
sw forwarding     198455     0          0          0          0
host              355799     0          0          0          0
broadcast         1880876    0          0          0          0
cbt-to-spt        0          0          0          0          0
igmp snooping     185865     0          0          0          0
icmp              615830     0          0          0          0
logging           0          0          0          0          0
rpf-fail          0          0          0          0          0
dstats            0          0          0          0          0
cpu heartbeat     2795806    0          0          0          0
cpu-queue         static inuse static added
rpc               0            0
stp               0            0
ipc               0            0
routing protocol  0            0
L2 protocol       0            0
remote console    0            0
sw forwarding     0            0
host              0            0
broadcast         0            0
cbt-to-spt        0            0
igmp snooping     0            0
icmp              0            0
logging           0            0
rpf-fail          0            0
dstats            0            0
cpu heartbeat     0            0
Supervisor ASIC receive-queue parameters
queue 0 maxrecevsize 0 pakhead 0 paktail 0
queue 1 maxrecevsize 7E0 pakhead 47A9DCC paktail 47A6B44
queue 2 maxrecevsize 7E0 pakhead 474D26C paktail 474FA20
queue 3 maxrecevsize 7E0 pakhead 495F8E4 paktail 4960754
queue 4 maxrecevsize 7E0 pakhead 47AD8D0 paktail 47AD534
queue 5 maxrecevsize 7E0 pakhead 0 paktail 0
queue 6 maxrecevsize 7E0 pakhead 4948778 paktail 49483DC
queue 7 maxrecevsize 7E0 pakhead 48C3104 paktail 48E0D74
queue 8 maxrecevsize 7E0 pakhead 48ECA68 paktail 48EAD88
queue 9 maxrecevsize 7E0 pakhead 48382FC paktail 48382FC
queue A maxrecevsize 7E0 pakhead 481CE18 paktail 481C6E0
queue B maxrecevsize 7E0 pakhead 4977C5C paktail 49778C0
queue C maxrecevsize 7E0 pakhead 484438C paktail 48479B0
queue D maxrecevsize 7E0 pakhead 48347F8 paktail 4837E1C
queue E maxrecevsize 0 pakhead 0 paktail 0
queue F maxrecevsize 7E0 pakhead 480DF04 paktail 480DB68
Supervisor ASIC exception status
Receive overrun    00000000   Transmit overrun 00000000
FrameSignatureErr  00000000   MicInitialize    00000002
BadFrameErr        00000000   LenExceededErr   00000000
BadJumboSegments   00000000
Supervisor ASIC Mic Registers
MicDirectPollInfo               80000200
MicIndicationsReceived          00000000
MicInterruptsReceived           00000003
MicPcsInfo                      0000001F
MicPlbMasterConfiguration       00000000
MicRxFifosAvailable             00000000
MicRxFifosReady                 0000BFFE
MicTimeOutPeriod:       FrameTOPeriod: 00000EA6 DirectTOPeriod: 00004000
MicTransmFramesCopied           00000003
MicTxFifosAvailable             00000006
MicConfiguration:       Conf flag: 00000110     Interrupt Flag: 00000008
MicReceiveFifoAssignmen Queue 0 - 7: 22222222   Queue 8 - 15:22222222
MicReceiveFramesReady:  FrameAvailable: 00000081        frameAvaiMask: 00000000
MicException:
        Exception_flag  00000000
        Message-1       00000000
        Message-2       00000000
        Message-3       00000000
MicIntRxFifo:
        ReadPtr         00000C98        WritePtr        00000C98
        WHeadPtr        00000C98        TxFifoDepth     C0000800
MicIntTxFifo:
        ReadPtr         00000750        WritePtr        00000750
        WHeadPtr        00000750        TxFifoDepth     C0000800
MicDecodeInfo:
Fifo0:  address:        03FF4000 asic_num:      00000100
Fifo1:  address:        03FF4400 asic_num:      00000101
MicTransmitFifoInfo:
Fifo0:   StartPtrs:     0E17E800        ReadPtr:        0E17EF00
        WritePtrs:      0E17EF00        Fifo_Flag:      8A800800
        Weights:        001E001E
Fifo1:   StartPtrs:     0E027400        ReadPtr:        0E0275A0
        WritePtrs:      0E0275A0        Fifo_Flag:      89800400
        Weights:        000A000A
MicReceiveFifoInfo:
Fifo0:  StartPtr:       0E17E760        ReadPtr:        0E17E760
        WritePtrs:      0E17E768        Fifo_Flag:      04000018
        writeHeaderPtr: 0E17E768
Fifo1:  StartPtr:       0E365C00        ReadPtr:        0E365C00
        WritePtrs:      0E365C00        Fifo_Flag:      89800400
        writeHeaderPtr: 0E365C00
Fifo2:  StartPtr:       0E027300        ReadPtr:        0E027360
        WritePtrs:      0E027300        Fifo_Flag:      86000020
        writeHeaderPtr: 0E027300
Fifo3:  StartPtr:       0E4E1400        ReadPtr:        0E4E1770
        WritePtrs:      0E4E1770        Fifo_Flag:      89800400
        writeHeaderPtr: 0E4E1770
Fifo4:  StartPtr:       0E3AD200        ReadPtr:        0E3AD218
        WritePtrs:      0E3AD218        Fifo_Flag:      88800200
        writeHeaderPtr: 0E3AD218
Fifo5:  StartPtr:       0E027970        ReadPtr:        0E027970
        WritePtrs:      0E027970        Fifo_Flag:      82800008
        writeHeaderPtr: 0E027970
Fifo6:  StartPtr:       0E499C00        ReadPtr:        0E499DB8
        WritePtrs:      0E499DB8        Fifo_Flag:      89800400
        writeHeaderPtr: 0E499DB8
Fifo7:  StartPtr:       0E409400        ReadPtr:        0E4096C0
        WritePtrs:      0E4096C8        Fifo_Flag:      890003F8
        writeHeaderPtr: 0E4096C8
Fifo8:  StartPtr:       0E473A00        ReadPtr:        0E473B60
        WritePtrs:      0E473B60        Fifo_Flag:      88800200
        writeHeaderPtr: 0E473B60
Fifo9:  StartPtr:       0E190CD8        ReadPtr:        0E190CD8
        WritePtrs:      0E190CD8        Fifo_Flag:      82800008
        writeHeaderPtr: 0E190CD8
Fifo10: StartPtr:       0E3D3000        ReadPtr:        0E3D3048
        WritePtrs:      0E3D3048        Fifo_Flag:      88800200
        writeHeaderPtr: 0E3D3048
Fifo11: StartPtr:       0E473900        ReadPtr:        0E473930
        WritePtrs:      0E473930        Fifo_Flag:      86800080
        writeHeaderPtr: 0E473930
Fifo12: StartPtr:       0E365A80        ReadPtr:        0E365A80
        WritePtrs:      0E365A80        Fifo_Flag:      86800080
        writeHeaderPtr: 0E365A80
Fifo13: StartPtr:       0E365980        ReadPtr:        0E365980
        WritePtrs:      0E365980        Fifo_Flag:      86800080
        writeHeaderPtr: 0E365980
Fifo14: StartPtr:       00000000        ReadPtr:        00000000
        WritePtrs:      00000000        Fifo_Flag:      00800000
        writeHeaderPtr: 00000000
Fifo15: StartPtr:       0E3AD100        ReadPtr:        0E3AD110
        WritePtrs:      0E3AD110        Fifo_Flag:      84800020
        writeHeaderPtr: 0E3AD110
Complete Board Id:0x00B8
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*  1 vty 0                idle                 00:00:02 105.103.24.110
  Interface      User        Mode                     Idle     Peer Address
------------------ show file systems ------------------
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
           -           -    opaque     ro   bs:
*   57671680    38633984     flash     rw   flash:
           -           -    opaque     rw   system:
           -           -    opaque     rw   tmpsys:
      524288      514801     nvram     rw   nvram:
           -           -    opaque     rw   null:
           -           -    opaque     ro   tar:
           -           -   network     rw   tftp:
           -           -    opaque     ro   xmodem:
           -           -    opaque     ro   ymodem:
           -           -    opaque     wo   syslog:
           -           -   network     rw   rcp:
           -           -   network     rw   http:
           -           -   network     rw   ftp:
           -           -   network     rw   scp:
           -           -   network     rw   https:
           -           -    opaque     ro   cns:
------------------ show file descriptors ------------------
File Descriptors:
   FD  Position  Open  PID  Path
  No open file descriptors
------------------ show flash: ------------------
Directory of flash:/
    2  -rwx        2776   Mar 1 1993 00:01:18 +00:00  vlan.dat
    3  -rwx        1940   Mar 2 1993 15:20:11 +00:00  private-config.text
    4  -rwx        4423   Mar 2 1993 15:20:11 +00:00  config.text
  444  -rwx        3096   Mar 1 1993 00:01:04 +00:00  multiple-fs
    6  drwx         512   Mar 1 1993 00:09:05 +00:00  c3560e-universalk9-mz.122-55.SE3
57671680 bytes total (38633984 bytes free)
------------------ dir nvram: ------------------
Directory of nvram:/
  504  -rw-        4423                      startup-config
  505  ----        1940                      private-config
    1  ----          35                      persistent-data
    2  -rw-           0                      ifIndex-table
    3  -rw-         579                      IOS-Self-Sig#3838.cer
524288 bytes total (514801 bytes free)
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor    3C60778   190124040    30900564   159223476   158055312   141738768
      I/O    E000000    16777216     5574268    11202948    11171020    11170092
Driver te    2400000     4194304          44     4194260     4194260     4194260
------------------ show process memory ------------------
Processor Pool Total:  190124040 Used:   30899572 Free:  159224468
      I/O Pool Total:   16777216 Used:    5574172 Free:   11203044
Driver te Pool Total:    4194304 Used:         40 Free:    4194264
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   51918872   24132012   24677380          0          0 *Init*
   0   0      14028   66845064      14028          0          0 *Sched*
   0   0   10827232    9437904    3207540    5661700     421352 *Dead*
   1   0       5044       3088      12096          0          0 Chunk Manager
   2   0        180        180       4052          0          0 Load Meter
   3   0          0          0       7104          0          0 DHCPD Timer
   4   0          0          0       7104          0          0 Check heaps
   5   0       1228     151636       7052        260      40316 Pool Manager
   6   0        180        180       7052          0          0 Timers
   7   0        284        728       7052          0          0 License Client N
   8   0 2162234272 2162234272       7136          0          0 Licensing Auto U
   9   0    1502796    1503080       7052          0          0 Image License br
  10   0     986984    2496500     697748          0          0 ARP Input
  11   0          0          0       7068          0          0 CEF MIB API
  12   0          0          0       7052          0          0 AAA_SERVER_DEADT
  13   0        180        180       7060          0          0 AAA high-capacit
  14   0          0          0      13052          0          0 Policy Manager
  15   0     137012      53808      90348          0          0 Entity MIB API
  16   0          0          0       7052          0          0 IFS Agent Manage
  17   0          0          0       7100          0          0 IPC Dynamic Cach
  18   0          0          0       7052          0          0 IPC Zone Manager
  19   0          0          0       7052          0          0 IPC Periodic Tim
  20   0          0          0       7052          0          0 IPC Managed Time
  21   0          0          0       7052          0          0 IPC Deferred Por
  22   0       5232          0      12284          0          0 IPC Seat Manager
  23   0          0          0       7052          0          0 IPC Session Serv
  24   0     537552     532788      12444          0          0 PrstVbl
  25   0          0          0      25052          0          0 Crash writer
  26   0        180        180       7052          0          0 GraphIt
  27   0        180        180       7052          0          0 SMART
  28   0        180        180      13052          0          0 XML Proxy Client
  29   0          0          0       7052          0          0 ARP Snoop
  30   0          0          0       7052          0          0 Dynamic ARP Insp
  31   0          0          0       7104          0          0 Critical Bkgnd
  32   0      32796       4160      13460          0          0 Net Background
  33   0          0          0      13052          0          0 IDB Work
  34   0        180        180      13052          0          0 Logger
  35   0        180        516      10052          0          0 TTY Background
  36   0   31949272    1540712      23900          0          0 Per-Second Jobs
  37   0          0          0       7052          0          0 Per-minute Jobs
  38   0      48560      40044      55612          0          0 IF-MGR control p
  39   0          0          0       7052          0          0 IF-MGR event pro
  40   0          0          0       4052          0          0 Inode Table Dest
  41   0          0          0       7052          0          0 AggMgr Process
  42   0          0       1976       7052          0          0 Transport Port A
  43   0          0          0       7052          0          0 HC Counter Timer
  44   0          0          0       7052          0          0 SFF8472
  45   0      32104        600      41556          0          0 EEM ED Identity
  46   0       4980          0      15032          0          0 EEM ED MAT
  47   0       4904    7987104      14956          0          0 EEM ED ND
  48   0     146808      17528      86228          0          0 USB Startup
  49   0        180        180       7052          0          0 DownWhenLooped
  50   0          0          0       7052          0          0 HULC PBR Tcam Me
  51   0          0          0       7052          0          0 HULC ACL Tcam Me
  52   0          0          0       7052          0          0 Hulc Warm Upgrad
  53   0          0          0       7052          0          0 HRPC lpip reques
  54   0        180        180       7052          0          0 HLPIP Sync Proce
  55   0          0          0       7052          0          0 HRPC EnergyWise
  56   0          0          0       7052          0          0 HRPC actual powe
  57   0          0          0       7052          0          0 HUSB Console
  58   0        180        180       7052          0          0 SM RBCP Monitor
  59   0          0          0       7052          0          0 HULC QM Tcam Mem
  60   0     872416     851804      20196          0          0 X2 HAMM detect p
  61   0          0          0       7080          0          0 Net Input
  62   0        180        180       7052          0          0 Compute load avg
  63   0          0          0       4052          0          0 Madmax Process
  64   0          0          0       7052          0          0 HRPC asic-stats
  65   0          0          0       7112          0          0 RedEarth I2C dri
  66   0   84225264   87295632       7052          0          0 RedEarth Tx Mana
  67   0   43995748   81023016       7052          0          0 RedEarth Rx Mana
  68   0    9192316        180       7052          0          0 HULC Thermal Pro
  69   0          0          0       4052          0          0 HRPC hsm request
  70   0          0          0      13052          0          0 Stack Mgr
  71   0     452640      27436     343752          0          0 Stack Mgr Notifi
  72   0    5656104    5656104      10052          0          0 Adjust Regions
  73   0       3684          0       7052        780          0 hrpc -> response
  74   0          0          0       7052          0          0 hrpc -> request
  75   0       3688    5008448       7052          0          0 hrpc <- response
  76   0          0          0       7052          0          0 HRPC hcomp reque
  77   0        180        180       7052          0          0 yeti2_emac_proce
  78   0        508        180       7052          0          0 HULC Device Mana
  79   0         68         68       7052          0          0 HRPC hdm non blo
  80   0        176        176       7052          0          0 HRPC hdm blockin
  81   0          0          0      13052          0          0 HIPC bkgrd proce
  82   0        180        676       7052          0          0 Hulc Port-Securi
  83   0          0          0       7052          0          0 HRPC hpsecure re
  84   0          0          0       7052          0          0 HRPC hfbm reques
  85   0        216          0       7320          0          0 DHCPD Database
  86   0          0          0       7052          0          0 HRPC hlfm reques
  87   0      70596        180      77468          0          0 HLFM address lea
  88   0        180        180       7052          0          0 HLFM aging proce
  89   0        180        180       7052          0          0 HLFM address ret
  90   0      85556        420      92188      53760          0 HRPC emac reques
  91   0          0          0       7052          0          0 HRPC isis reques
  92   0          0          0       7052          0          0 HRPC hulc misc r
  93   0          0          0      13052          0          0 HVLAN main bkgrd
  94   0        180        180       7052          0          0 HVLAN Mapped Vla
  95   0        180        180       7052          0          0 Vlan shutdown Pr
  96   0         68         68       7052          0          0 HRPC vlan reques
  97   0          0          0       7052          0          0 HULC VLAN REF Ba
  98   0        180        180       7052          0          0 hulc_xps_process
  99   0          0          0       7052          0          0 HRPC ilp request
100   0          0          0       7052          0          0 HULC PM Vector P
101   0          0          0       7052          0          0 HPM Msg Retry Pr
102   0       8812          0      33940          0          0 LICENSE AGENT
103   0      37496       1100      15080          0          0 hpm main process
104   0        180        180       7052          0          0 HPM Stack Sync P
105   0       5044          0      30096          0          0 HRPC pm request
106   0        180        180       7052          0          0 hpm counter proc
107   0          0          0       7052          0          0 HRPC pm-counters
108   0          0          0       7052          0          0 hpm vp events ca
109   0          0          0       7052          0          0 HRPC hcmp reques
110   0          0          0      13052          0          0 HCEF ADJ Refresh
111   0          0          0       7052          0          0 HRPC hl3mm reque
112   0          0          0       4052          0          0 hl3md_rpfq_thrl_
113   0       1152       1152       7052          0          0 hl3mm
114   0          0          0       7052          0          0 hl3mm_rp
115   0          0          0       7052          0          0 HACL Queue Proce
116   0          0          0       7052          0          0 HRPC acl request
117   0        180      11400      61052          0          0 HACL Acl Manager
118   0          0          0       7052          0          0 HRPC aim request
119   0          0          0       7052          0          0 HRPC backup inte
120   0     728312     649312      85028          0          0 OBFL TEMP obfl0
121   0          0          0       7052          0          0 HRPC cdp request
122   0          0          0       7052          0          0 HULC CISP Proces
123   0          0          0       7052          0          0 HRPC dot1x reque
124   0          0          0       7052          0          0 HULC DOT1X Proce
125   0          0          0       7052          0          0 HRPC lldp reques
126   0        180        180       7052          0          0 MACsec Process
127   0          0          0       7052          0          0 HRPC macsec requ
128   0          0          0       4052          0          0 HRPC system mtu
129   0          0          0       7052          0          0 HRPC rep request
130   0        180        180       7052          0          0 REP Helper Proc
131   0          0          0       7052          0          0 HRPC sdm request
132   0          0          0       7052          0          0 SMI MSG Retry Pr
133   0          0          0      10052          0          0 HRPC Smart Insta
134   0        180        180       7052          0          0 Hulc Storm Contr
135   0        180        180       7052          0          0 HSTP Sync Proces
136   0          0          0       7052          0          0 HRPC stp_cli req
137   0          0          0       7052          0          0 HRPC stp_state_s
138   0        180        180       7052          0          0 S/W Bridge Proce
139   0          0          0       7052          0          0 HRPC hudld reque
140   0          0          0       7052          0          0 HRPC vqpc reques
141   0          0          0       7052          0          0 HRPC iec_load_ba
142   0          0          0       7052          0          0 IEC Load balance
143   0          0          0       7052          0          0 HRPC l2pt qnq rp
144   0          0          0       7052          0          0 HRPC hled reques
145   0        180        180      10052          0          0 Hulc LED Process
146   0     223152     275240      17052          0          0 HL3U bkgrd proce
147   0          0          0       7052          0          0 HRPC hl3u reques
148   0          0          0      61052          0          0 HL3U PBR bkgrd p
149   0          0          0       7052          0          0 HL3U PBR n-h res
151   0          0          0       7052          0          0 HRPC dtp request
152   0          0          0       7052          0          0 HRPC show_forwar
153   0          0          0       7052          0          0 HRPC snmp reques
154   0          0          0       7052          0          0 HULC SNMP Proces
155   0 1101589920 1096580272      12660          0          0 HQM Stack Proces
156   0  611169180  611169180      61052          0          0 HRPC qos request
157   0          0          0       7052          0          0 HRPC span reques
158   0        988        988       7052          0          0 HRPC system post
159   0          0          0       7052          0          0 Hulc Reload Mana
160   0          0          0       7052          0          0 HRPC hrcli-event
161   0          0          0       7104          0          0 HCMP sync proces
162   0        180        180      10052          0          0 image mgr
163   0       7544       5996       7544          0          0 HL2MCM
164   0       7544       6004       7544          0          0 HL2MCM
165   0        180        180       7084          0          0 AAA Server
166   0          0          0       7052          0          0 AAA ACCT Proc
167   0          0          0       7052          0          0 ACCT Periodic Pr
168   0          0          0       7052          0          0 AAA System Acct
169   0          0          0       7052          0          0 AUTH POLICY Fram
170   0        180        180      13052          0          0 Auth Manager
171   0          0          0       7052          0          0 Auth-proxy AAA B
172   0          0          0       7052          0          0 IP Admin SM Proc
173   0   19280796   11284144      34324          0          0 CDP Protocol
174   0          0          0       7100          0          0 MDFS LC Download
175   0        180        180       7104          0          0 ENABLE AAA
176   0          0          0       7052          0          0 CMD HANDLER
177   0        204        204       7052          0          0 AAA Dictionary R
178   0       2084        180      14956          0          0 SXP CORE
179   0          0          0       7052          0          0 DHCP Snooping
180   0        180        180       7052          0          0 Dot1x Mgr Proces
181   0          0          0       7052          0          0 EAP Framework
182   0          0          0       7052          0          0 EAP Test
183   0        180        180      10052          0          0 EAPoUDP Process
184   0        396        180      13268          0          0 CEF switching ba
185   0      27868      19392      14512          0          0 IP Input
186   0          0          0       7052          0          0 ICMP event handl
187   0        180        180      10052          0          0 IP ARP Track
188   0          0          0      25052          0          0 fnvRootHubPortSt
189   0        180          0      25232          0          0 tHUB
190   0        180        180      13052          0          0 MDFS MFIB Proces
191   0    2294452        180      30004       7020          0 ADJ resolve proc
192   0        396        180       4268          0          0 ADJ NSF process
193   0          0          0       7052          0          0 IPv6 ping proces
194   0        180        180      13052          0          0 KRB5 AAA
195   0          0          0       7052          0          0 MAB Framework
196   0       7772        392      14432          0          0 MKA
197   0        584        368      13328          0          0 Collection proce
198   0        180        180       7052          0          0 REP Topology cha
199   0       8184          0      33236          0          0 SMI Director DB
200   0          0          0       7052          0          0 SMI CDP Update H
201   0        680          0      25732          0          0 SMI Backup Proce
202   0       4028        180      10900          0          0 SMI IBC server p
203   0        304          0      13356          0          0 SMI IBC client p
204   0       4832        180      17704          0          0 SMI IBC Download
205   0    2871508       2856       7316          0          0 Spanning Tree
206   0          0          0       7052          0          0 Spanning Tree St
207   0        180        180       7052          0          0 CDP Forward Proc
208   0          0       3076       7052          0          0 802.1x switch
209   0        180        180       7052          0          0 802.1x MDA Aging
210   0          0          0       7052          0          0 802.1x Webauth F
211   0     305516      16732     113608          0          0 DTP Protocol
212   0          0          0       7052          0          0 HRPC dai request
213   0          0          0       4052          0          0 HULC DAI Process
214   0          0          0       7052          0          0 HRPC power down
215   0          0          0       7052          0          0 HRPC ip device t
216   0          0          0       7052          0          0 HRPC ip source g
217   0          0          0       7052          0          0 HULC IP Source g
218   0        180        180       7052          0          0 PI MATM Aging Pr
219   0        472        180       7344          0          0 UDLD
220   0        216          0       7268          0          0 Port-Security
221   0      71308          0      78360          0          0 Switch Backup In
222   0        180        180      10052          0          0 IP Host Track Pr
223   0          0          0       7052          0          0 Link State Group
224   0          0          0       7052          0          0 MMN bkgrd proces
225   0        180        180       7052          0          0 Ethchnl
226   0      65580     142568      72632          0          0 VMATM Callback
227   0       1184       1268      13268          0          0 CEF background p
228   0          0          0      10052          0          0 IP IRDP
229   0          0          0       7052          0          0 CEF RF HULC Conv
230   0          0          0       7052          0          0 XDR mcast
231   0        180        180       7052          0          0 IP ACL XDR LC Ba
232   0          0          0       7052          0          0 IPC LC Message H
233   0          0          0       7052          0          0 XDR RP Ping Back
234   0          0          0       7052          0          0 XDR RP backgroun
235   0          0          0       7052          0          0 XDR RP Test Back
236   0       7512        180      13284          0          0 MDFS LC Process
237   0          0          0       7052          0          0 Critical Auth
238   0        180        180       7052          0          0 LINE AAA
239   0    1094252     232932     860972          0          0 IP RIB Update
240   0        304       4848      13052          0          0 TCP Timer
241   0     224132          0      13052          0          0 TCP Protocols
242   0          0          0       7052          0          0 Socket Timers
243   0      11520          0      21572          0          0 HTTP CORE
244   0        180        180       7052          0          0 Cluster L2
245   0          0          0       7052          0          0 Cluster RARP
246   0     568044     567352       7744          0          0 Cluster Base
247   0      52976        180      50876          0          0 DHCPD Receive
248   0        396        180       7268          0          0 Dot1x Supplicant
249   0        396        180       7268          0          0 Dot1x Supplicant
250   0        396        180       7268          0          0 Dot1x Supplicant
251   0          0          0       7052          0          0 RARP Input
252   0          0          0      18396          0          0
253   0        180        180       7052          0          0 REP LSL Proc
254   0      10224        180      17096          0          0 REP BPA/EPA Proc
255   0          0          0       7052          0          0 HRPC hwccp reque
256   0          0          0       7052          0          0 HULC_WCCP_BACKGR
257   0          0          0       7052          0          0 HRPC dhcp snoopi
258   0          0        328       7052          0          0 HULC DHCP Snoopi
259   0     511084        156       7052          0          0 HULC stack power
260   0          0          0       7052          0          0 HRPC stack power
261   0      61888    1763428      47340          0          0 IGMPSN L2MCM
262   0          0          0       7052          0          0 IGMPSN MRD
263   0          0          0       7052          0          0 IGMPSN
264   0          0          0       7052          0          0 IGMPQR
265   0       2848        180       9720          0          0 L2TRACE SERVER
266   0      62760    1596720      50860          0          0 MLDSN L2MCM
267   0          0          0       7052          0          0 MRD
268   0          0          0       7052          0          0 MLD_SNOOP
269   0          0          0       7052          0          0 HRPC hl2mcm igmp
270   0   68355252          0       7052          0          0 MDFS RP process
271   0          0          0       7052          0          0 HRPC hl2mcm mlds
272   0        180        180       7052          0          0 LOCAL AAA
273   0          0          0       7052          0          0 EPM MAIN PROCESS
274   0        216          0       7344          0          0 CEF RP IPC Backg
275   0       2060        180       8932          0          0 TPLUS
276   0    3203276    1556304    1653184          0          0 EIGRP-IPv4
277   0      31212       1864      27028          0          0 crypto engine pr
278   0     532048     525876      15224          0          0 Crypto CA
279   0          0          0       9052          0          0 Crypto PKI-CRL
280   0          0          0       9052          0          0 Crypto SSL
281   0          0          0       7052          0          0 encrypt proc
282   0          0          0       7052          0          0 HRPC x_setup req
283   0        180        180       7052          0          0 REP Switch Helpe
284   0          0          0      10052          0          0 Licensing MIB pr
285   0       4832       5156      11704          0          0 VTP Trap Process
286   0        216          0       7268          0          0 DATA Transfer Pr
287   0        216          0       7268          0          0 DATA Collector
288   0        180        180       7052          0          0 AAA SEND STOP EV
289   0        180        180       7052          0          0 DHCP Security He
290   0       5040          0      15092          0          0 EEM ED Routing
291   0     237524          0     247576      99792          0 EEM ED Syslog
292   0          0          0       7052          0          0 Syslog Traps
293   0    4778100    4771328      19824          0          0 OBFL UPTIME obfl
294   0        180        180       7052          0          0 VTPMIB EDIT BUFF
295   0          0          0       7052          0          0 HCD Process
296   0          0          0       7052          0          0 HRPC cable diagn
297   0         68        284       7052          0          0 DiagCard1/-1
298   0      27768      92740      12300          0          0 PM Callback
299   0     598796     200000      58720       2340          0 VLAN Manager
300   0          0          0       7072          0          0 EIGRP-IPv4 Hello
301   0        180        180       7052          0          0 dhcp snooping sw
302   0      41212      15044      17616          0          0 SpanTree Helper
303   0     170996          0     178048          0          0 EEM Server
304   0      11696       1668      17080          0          0 EEM Policy Direc
305   0      79604      77512      15144          0          0 OBFL MSG obfl0
306   0       4980          0      15032          0          0 EEM ED CLI
307   0       4904          0      14956          0          0 EEM ED Counter
308   0       4904          0      14956          0          0 EEM ED Interface
309   0       4904          0      14956          0          0 EEM ED IOSWD
310   0       4904          0      14956          0          0 EEM ED Ipsla
311   0       4904          0      14956          0          0 EEM ED None
312   0       4904          0      14956          0          0 EEM ED OIR
313   0      52032      40784      11356          0          0 SSH Event handle
314   0       4904          0      14956          0          0 EEM ED RPC
315   0       5056          0      15108          0          0 EEM ED SNMP
316   0       4904          0      14956          0          0 EEM ED SNMP Obje
317   0       4904          0      14956          0          0 EEM ED SNMP Noti
318   0       5208          0      15260          0          0 EEM ED Timer
319   0       7480       7480      13052          0          0 Syslog
320   0        600        384      13268          0          0 RBM CORE
321   0        180        180       4052          0          0 STP FAST TRANSIT
322   0        180        180       4052          0          0 CSRT RAPID TRANS
323   0     379928        984     371456          0          0 CEF: IPv4 proces
324   0        216          0       7268          0          0 ADJ background
325   0        144          0      10196          0          0 IP Background
326   0          0          0      13104          0          0 hulc cfg mgr mas
327   1   14742680   14698196      32120       4536          0 Virtual Exec
328   0          0          0       7052          0          0 SNMP Timers
329   0   19417644   19416408      13928          0          0 IP SNMP
330   0   14636812          0      13072          0          0 PDU DISPATCHER
331   0  521995460  536622360      23324          0          0 SNMP ENGINE
332   0       1092        216      13928          0          0 IP SNMPV6
333   0          0          0      13052          0          0 SNMP ConfCopyPro
334   0        152        152      13052          0          0 SNMP Traps
335   0    2871792    2855884      22988          0          0 hulc running con
336   0   20604456   20610840      10004          0          0 crypto sw pk pro
337   0      20068       9192      20928          0          0 OBFL ENV obfl0
338   0     624288     618672      18668          0          0 OBFL VOLT obfl0
339   0       6408       6408       7052          0          0 OBFL I/O Buffer
                                 36462980 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 11%/0%; one minute: 15%; five minutes: 13%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         7          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2        1168     28094         41  0.00%  0.00%  0.00%   0 Load Meter
   3           8      1213          6  0.00%  0.00%  0.00%   0 DHCPD Timer
   4     1804735     79848      22602  3.19%  1.04%  1.12%   0 Check heaps
   5           8         6       1333  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7           0         2          0  0.00%  0.00%  0.00%   0 License Client N
   8      324357      2342     138495  0.00%  0.13%  0.17%   0 Licensing Auto U
   9          50         3      16666  0.00%  0.00%  0.00%   0 Image License br
  10      199002    549674        362  0.00%  0.20%  0.20%   0 ARP Input
  11           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  12           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  13           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  14           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  15          59         5      11800  0.00%  0.00%  0.00%   0 Entity MIB API
  16           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  17          69      2342         29  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  18           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  19         511    139372          3  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  20           0         1          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  21         402    139372          2  0.00%  0.00%  0.00%   0 IPC Deferred Por
  22         338      9366         36  0.00%  0.00%  0.00%   0 IPC Seat Manager
  23           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  24          34         4       8500  0.00%  0.00%  0.00%   0 PrstVbl
  25           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  26       37561    139331        269  0.00%  0.00%  0.00%   0 GraphIt
  27           0         2          0  0.00%  0.00%  0.00%   0 SMART
  28           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  29           0         1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  30         808    139372          5  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  31           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  32        7750    156797         49  0.00%  0.00%  0.00%   0 Net Background
  33           0         1          0  0.00%  0.00%  0.00%   0 IDB Work
  34           0        39          0  0.00%  0.00%  0.00%   0 Logger
  35         562    139328          4  0.00%  0.00%  0.00%   0 TTY Background
  36       10255    139372         73  0.00%  0.00%  0.00%   0 Per-Second Jobs
  37       71167      2344      30361  0.00%  0.02%  0.00%   0 Per-minute Jobs
  38           8         6       1333  0.00%  0.00%  0.00%   0 IF-MGR control p
  39           0        13          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  40           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  41           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  42           0        22          0  0.00%  0.00%  0.00%   0 Transport Port A
  43        1855     38539         48  0.00%  0.00%  0.00%   0 HC Counter Timer
  44           0         1          0  0.00%  0.00%  0.00%   0 SFF8472
  45           0        41          0  0.00%  0.00%  0.00%   0 EEM ED Identity
  46           0        68          0  0.00%  0.00%  0.00%   0 EEM ED MAT
  47        1359      7105        191  0.00%  0.00%  0.00%   0 EEM ED ND
  48          66        76        868  0.00%  0.00%  0.00%   0 USB Startup
  49        1113   2763987          0  0.00%  0.00%  0.00%   0 DownWhenLooped
  50           0         1          0  0.00%  0.00%  0.00%   0 HULC PBR Tcam Me
  51           0         1          0  0.00%  0.00%  0.00%   0 HULC ACL Tcam Me
  52           0         1          0  0.00%  0.00%  0.00%   0 Hulc Warm Upgrad
  53           0         1          0  0.00%  0.00%  0.00%   0 HRPC lpip reques
  54           0         2          0  0.00%  0.00%  0.00%   0 HLPIP Sync Proce
  55           0         1          0  0.00%  0.00%  0.00%   0 HRPC EnergyWise
  56           0         1          0  0.00%  0.00%  0.00%   0 HRPC actual powe
  57        1252    556853          2  0.00%  0.00%  0.00%   0 HUSB Console
  58           0         2          0  0.00%  0.00%  0.00%   0 SM RBCP Monitor
  59           0         1          0  0.00%  0.00%  0.00%   0 HULC QM Tcam Mem
  60        4337        10     433700  0.00%  0.00%  0.00%   0 X2 HAMM detect p
  61           0         2          0  0.00%  0.00%  0.00%   0 Net Input
  62        3762     28094        133  0.00%  0.00%  0.00%   0 Compute load avg
  63           0         1          0  0.00%  0.00%  0.00%   0 Madmax Process
  64           0         1          0  0.00%  0.00%  0.00%   0 HRPC asic-stats
  65       88637    744307        119  0.00%  0.09%  0.06%   0 RedEarth I2C dri
  66     2930241    536838       5458  1.91%  2.03%  2.02%   0 RedEarth Tx Mana
  67       75722    372158        203  0.00%  0.04%  0.04%   0 RedEarth Rx Mana
  68         417     28094         14  0.00%  0.00%  0.00%   0 HULC Thermal Pro
  69           0         1          0  0.00%  0.00%  0.00%   0 HRPC hsm request
  70           0         7          0  0.00%  0.00%  0.00%   0 Stack Mgr
  71         167        10      16700  0.00%  0.00%  0.00%   0 Stack Mgr Notifi
  72     1484351     47452      31281  0.00%  0.92%  1.00%   0 Adjust Regions
  73        1011    139341          7  0.00%  0.00%  0.00%   0 hrpc -> response
  74         103     28116          3  0.00%  0.00%  0.00%   0 hrpc -> request
  75        1174     28113         41  0.00%  0.00%  0.00%   0 hrpc <- response
  76           0         1          0  0.00%  0.00%  0.00%   0 HRPC hcomp reque
  77        6180    695525          8  0.00%  0.00%  0.00%   0 yeti2_emac_proce
  78           0         3          0  0.00%  0.00%  0.00%   0 HULC Device Mana
  79           0         3          0  0.00%  0.00%  0.00%   0 HRPC hdm non blo
  80           0         2          0  0.00%  0.00%  0.00%   0 HRPC hdm blockin
  81         127     28094          4  0.00%  0.00%  0.00%   0 HIPC bkgrd proce
  82           0         8          0  0.00%  0.00%  0.00%   0 Hulc Port-Securi
  83           0         1          0  0.00%  0.00%  0.00%   0 HRPC hpsecure re
  84           0         1          0  0.00%  0.00%  0.00%   0 HRPC hfbm reques
  85          25      2347         10  0.00%  0.00%  0.00%   0 DHCPD Database
  86           0         1          0  0.00%  0.00%  0.00%   0 HRPC hlfm reques
  87       20696   4120439          5  0.00%  0.00%  0.00%   0 HLFM address lea
  88        3002    139333         21  0.00%  0.00%  0.00%   0 HLFM aging proce
  89       16004   4121226          3  0.00%  0.00%  0.00%   0 HLFM address ret
  90          17         8       2125  0.00%  0.00%  0.00%   0 HRPC emac reques
  91           0         1          0  0.00%  0.00%  0.00%   0 HRPC isis reques
  92           0         1          0  0.00%  0.00%  0.00%   0 HRPC hulc misc r
  93         872     46823         18  0.00%  0.00%  0.00%   0 HVLAN main bkgrd
  94           0         2          0  0.00%  0.00%  0.00%   0 HVLAN Mapped Vla
  95           0         2          0  0.00%  0.00%  0.00%   0 Vlan shutdown Pr
  96           0         3          0  0.00%  0.00%  0.00%   0 HRPC vlan reques
  97           0         1          0  0.00%  0.00%  0.00%   0 HULC VLAN REF Ba
  98          52      2343         22  0.00%  0.00%  0.00%   0 hulc_xps_process
  99           0         1          0  0.00%  0.00%  0.00%   0 HRPC ilp request
100           0         1          0  0.00%  0.00%  0.00%   0 HULC PM Vector P
101           0         1          0  0.00%  0.00%  0.00%   0 HPM Msg Retry Pr
102           0         1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
103       85470   1963188         43  0.00%  0.06%  0.05%   0 hpm main process
104           0        12          0  0.00%  0.00%  0.00%   0 HPM Stack Sync P
105           0         1          0  0.00%  0.00%  0.00%   0 HRPC pm request
106      342269    139332       2456  0.31%  0.28%  0.28%   0 hpm counter proc
107           0         1          0  0.00%  0.00%  0.00%   0 HRPC pm-counters
108           0         1          0  0.00%  0.00%  0.00%   0 hpm vp events ca
109           0         1          0  0.00%  0.00%  0.00%   0 HRPC hcmp reques
110           0        69          0  0.00%  0.00%  0.00%   0 HCEF ADJ Refresh
111           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl3mm reque
112           0         1          0  0.00%  0.00%  0.00%   0 hl3md_rpfq_thrl_
113        1343     98194         13  0.00%  0.00%  0.00%   0 hl3mm
114         398     70211          5  0.00%  0.00%  0.00%   0 hl3mm_rp
115           0         1          0  0.00%  0.00%  0.00%   0 HACL Queue Proce
116           0         1          0  0.00%  0.00%  0.00%   0 HRPC acl request
117           8        51        156  0.00%  0.00%  0.00%   0 HACL Acl Manager
118           0         1          0  0.00%  0.00%  0.00%   0 HRPC aim request
119           0         1          0  0.00%  0.00%  0.00%   0 HRPC backup inte
120         378       470        804  0.00%  0.00%  0.00%   0 OBFL TEMP obfl0
121           0         1          0  0.00%  0.00%  0.00%   0 HRPC cdp request
122           0         1          0  0.00%  0.00%  0.00%   0 HULC CISP Proces
123           0         1          0  0.00%  0.00%  0.00%   0 HRPC dot1x reque
124           0         3          0  0.00%  0.00%  0.00%   0 HULC DOT1X Proce
125           0         1          0  0.00%  0.00%  0.00%   0 HRPC lldp reques
126           0         2          0  0.00%  0.00%  0.00%   0 MACsec Process
127           0         1          0  0.00%  0.00%  0.00%   0 HRPC macsec requ
128           0         1          0  0.00%  0.00%  0.00%   0 HRPC system mtu
129           0         1          0  0.00%  0.00%  0.00%   0 HRPC rep request
130           0         3          0  0.00%  0.00%  0.00%   0 REP Helper Proc
131           0         1          0  0.00%  0.00%  0.00%   0 HRPC sdm request
132           0         1          0  0.00%  0.00%  0.00%   0 SMI MSG Retry Pr
133           0         1          0  0.00%  0.00%  0.00%   0 HRPC Smart Insta
134        5462    695533          7  0.00%  0.00%  0.00%   0 Hulc Storm Contr
135           0         2          0  0.00%  0.00%  0.00%   0 HSTP Sync Proces
136           0         1          0  0.00%  0.00%  0.00%   0 HRPC stp_cli req
137           0         1          0  0.00%  0.00%  0.00%   0 HRPC stp_state_s
138           0         2          0  0.00%  0.00%  0.00%   0 S/W Bridge Proce
139           0         1          0  0.00%  0.00%  0.00%   0 HRPC hudld reque
140           0         1          0  0.00%  0.00%  0.00%   0 HRPC vqpc reques
141           0         1          0  0.00%  0.00%  0.00%   0 HRPC iec_load_ba
142         521    139337          3  0.00%  0.00%  0.00%   0 IEC Load balance
143           0         1          0  0.00%  0.00%  0.00%   0 HRPC l2pt qnq rp
144           0         1          0  0.00%  0.00%  0.00%   0 HRPC hled reques
145      150320   3307586         45  0.31%  0.18%  0.12%   0 Hulc LED Process
146       10622    102961        103  0.15%  0.01%  0.00%   0 HL3U bkgrd proce
147           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl3u reques
148         193     32136          6  0.00%  0.00%  0.00%   0 HL3U PBR bkgrd p
149           0      1174          0  0.00%  0.00%  0.00%   0 HL3U PBR n-h res
151           0         1          0  0.00%  0.00%  0.00%   0 HRPC dtp request
152           0         1          0  0.00%  0.00%  0.00%   0 HRPC show_forwar
153           0         1          0  0.00%  0.00%  0.00%   0 HRPC snmp reques
154           0         1          0  0.00%  0.00%  0.00%   0 HULC SNMP Proces
155      231722     28109       8243  0.15%  0.15%  0.15%   0 HQM Stack Proces
156       32808     56199        583  0.00%  0.01%  0.00%   0 HRPC qos request
157           0         1          0  0.00%  0.00%  0.00%   0 HRPC span reques
158           0         3          0  0.00%  0.00%  0.00%   0 HRPC system post
159           0         1          0  0.00%  0.00%  0.00%   0 Hulc Reload Mana
160           0         1          0  0.00%  0.00%  0.00%   0 HRPC hrcli-event
161           0       783          0  0.00%  0.00%  0.00%   0 HCMP sync proces
162           0         2          0  0.00%  0.00%  0.00%   0 image mgr
163          24         4       6000  0.00%  0.00%  0.00%   0 HL2MCM
164          25         4       6250  0.00%  0.00%  0.00%   0 HL2MCM
165           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
166           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
167           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
168           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
169           0         1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
170           0         4          0  0.00%  0.00%  0.00%   0 Auth Manager
171           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
172           0       470          0  0.00%  0.00%  0.00%   0 IP Admin SM Proc
173       15692     21318        736  0.00%  0.00%  0.00%   0 CDP Protocol
174         612      9364         65  0.00%  0.00%  0.00%   0 MDFS LC Download
175           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
176           0         1          0  0.00%  0.00%  0.00%   0 CMD HANDLER
177           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
178           0         5          0  0.00%  0.00%  0.00%   0 SXP CORE
179           8      1174          6  0.00%  0.00%  0.00%   0 DHCP Snooping
180           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
181           0         1          0  0.00%  0.00%  0.00%   0 EAP Framework
182           0         1          0  0.00%  0.00%  0.00%   0 EAP Test
183           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
184           0         3          0  0.00%  0.00%  0.00%   0 CEF switching ba
185      388876   1514814        256  0.00%  0.39%  0.36%   0 IP Input
186           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
187         334    271519          1  0.00%  0.00%  0.00%   0 IP ARP Track
188         335    139751          2  0.00%  0.00%  0.00%   0 fnvRootHubPortSt
189           0         1          0  0.00%  0.00%  0.00%   0 tHUB
190        1334   1388203          0  0.00%  0.00%  0.00%   0 MDFS MFIB Proces
191       41435    178995        231  0.15%  0.08%  0.02%   0 ADJ resolve proc
192           0         2          0  0.00%  0.00%  0.00%   0 ADJ NSF process
193           0         1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
194           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
195           0         1          0  0.00%  0.00%  0.00%   0 MAB Framework
196           9         2       4500  0.00%  0.00%  0.00%   0 MKA
197           0         4          0  0.00%  0.00%  0.00%   0 Collection proce
198           0         2          0  0.00%  0.00%  0.00%   0 REP Topology cha
199           0         1          0  0.00%  0.00%  0.00%   0 SMI Director DB
200           0         1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
201           0         1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
202           0         2          0  0.00%  0.00%  0.00%   0 SMI IBC server p
203           0         1          0  0.00%  0.00%  0.00%   0 SMI IBC client p
204           0         2          0  0.00%  0.00%  0.00%   0 SMI IBC Download
205      438303   2556946        171  0.15%  0.26%  0.26%   0 Spanning Tree
206           0      2349          0  0.00%  0.00%  0.00%   0 Spanning Tree St
207           0         2          0  0.00%  0.00%  0.00%   0 CDP Forward Proc
208           8         4       2000  0.00%  0.00%  0.00%   0 802.1x switch
209          17      2343          7  0.00%  0.00%  0.00%   0 802.1x MDA Aging
210           0         1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
211        1710      9373        182  0.00%  0.00%  0.00%   0 DTP Protocol
212           0         1          0  0.00%  0.00%  0.00%   0 HRPC dai request
213           0         1          0  0.00%  0.00%  0.00%   0 HULC DAI Process
214           0         1          0  0.00%  0.00%  0.00%   0 HRPC power down
215           0         1          0  0.00%  0.00%  0.00%   0 HRPC ip device t
216           0         1          0  0.00%  0.00%  0.00%   0 HRPC ip source g
217           0         1          0  0.00%  0.00%  0.00%   0 HULC IP Source g
218      148380    139331       1064  0.31%  0.14%  0.11%   0 PI MATM Aging Pr
219         207    140795          1  0.00%  0.00%  0.00%   0 UDLD
220           9      4694          1  0.00%  0.00%  0.00%   0 Port-Security
221           0         2          0  0.00%  0.00%  0.00%   0 Switch Backup In
222           0         2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
223           0         1          0  0.00%  0.00%  0.00%   0 Link State Group
224          49      2342         20  0.00%  0.00%  0.00%   0 MMN bkgrd proces
225          82     14048          5  0.00%  0.00%  0.00%   0 Ethchnl
226          49       608         80  0.00%  0.00%  0.00%   0 VMATM Callback
227         211      2812         75  0.00%  0.00%  0.00%   0 CEF background p
228           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
229           0         1          0  0.00%  0.00%  0.00%   0 CEF RF HULC Conv
230           0         3          0  0.00%  0.00%  0.00%   0 XDR mcast
231         157     14047         11  0.00%  0.00%  0.00%   0 IP ACL XDR LC Ba
232           0         1          0  0.00%  0.00%  0.00%   0 IPC LC Message H
233           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
234           0      1174          0  0.00%  0.00%  0.00%   0 XDR RP backgroun
235           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
236           0         3          0  0.00%  0.00%  0.00%   0 MDFS LC Process
237           0         1          0  0.00%  0.00%  0.00%   0 Critical Auth
238           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
239        9924      5772       1719  0.00%  0.00%  0.00%   0 IP RIB Update
240           8       370         21  0.00%  0.00%  0.00%   0 TCP Timer
241           0        12          0  0.00%  0.00%  0.00%   0 TCP Protocols
242        1284    161359          7  0.00%  0.00%  0.00%   0 Socket Timers
243           0       472          0  0.00%  0.00%  0.00%   0 HTTP CORE
244           0      1762          0  0.00%  0.00%  0.00%   0 Cluster L2
245         225     14047         16  0.00%  0.00%  0.00%   0 Cluster RARP
246         773     19943         38  0.00%  0.00%  0.00%   0 Cluster Base
247       38437    346973        110  0.00%  0.00%  0.00%   0 DHCPD Receive
248           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
249           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
250           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
251           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
252          16      1028         15  0.00%  0.00%  0.00%   0
253           0         2          0  0.00%  0.00%  0.00%   0 REP LSL Proc
254           0         2          0  0.00%  0.00%  0.00%   0 REP BPA/EPA Proc
255           0         1          0  0.00%  0.00%  0.00%   0 HRPC hwccp reque
256           0         1          0  0.00%  0.00%  0.00%   0 HULC_WCCP_BACKGR
257           0         1          0  0.00%  0.00%  0.00%   0 HRPC dhcp snoopi
258           8         4       2000  0.00%  0.00%  0.00%   0 HULC DHCP Snoopi
259         515      7025         73  0.00%  0.00%  0.00%   0 HULC stack power
260           0         1          0  0.00%  0.00%  0.00%   0 HRPC stack power
261         127       295        430  0.00%  0.00%  0.00%   0 IGMPSN L2MCM
262           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN MRD
263           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN
264           0         1          0  0.00%  0.00%  0.00%   0 IGMPQR
265           0         2          0  0.00%  0.00%  0.00%   0 L2TRACE SERVER
266          82       294        278  0.00%  0.00%  0.00%   0 MLDSN L2MCM
267           0         1          0  0.00%  0.00%  0.00%   0 MRD
268           0         1          0  0.00%  0.00%  0.00%   0 MLD_SNOOP
269           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl2mcm igmp
270        6462   1394429          4  0.00%  0.00%  0.00%   0 MDFS RP process
271           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl2mcm mlds
272           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
273           0         1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
274           0         1          0  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
275           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
276       10441     86937        120  0.00%  0.00%  0.00%   0 EIGRP-IPv4
277          16        12       1333  0.00%  0.00%  0.00%   0 crypto engine pr
278          25         4       6250  0.00%  0.00%  0.00%   0 Crypto CA
279           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
280           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
281           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
282           0         1          0  0.00%  0.00%  0.00%   0 HRPC x_setup req
283           0         2          0  0.00%  0.00%  0.00%   0 REP Switch Helpe
284           0         1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
285           0        46          0  0.00%  0.00%  0.00%   0 VTP Trap Process
286           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
287           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
288           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
289           0         2          0  0.00%  0.00%  0.00%   0 DHCP Security He
290           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Routing
291           8        31        258  0.00%  0.00%  0.00%   0 EEM ED Syslog
292           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
293        2066        63      32793  0.00%  0.00%  0.00%   0 OBFL UPTIME obfl
294           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
295           0         1          0  0.00%  0.00%  0.00%   0 HCD Process
296           0         1          0  0.00%  0.00%  0.00%   0 HRPC cable diagn
297           9         2       4500  0.00%  0.00%  0.00%   0 DiagCard1/-1
298        3212    366734          8  0.00%  0.01%  0.00%   0 PM Callback
299         143       469        304  0.00%  0.00%  0.00%   0 VLAN Manager
300       10073    157763         63  0.00%  0.02%  0.00%   0 EIGRP-IPv4 Hello
301          27     11258          2  0.00%  0.00%  0.00%   0 dhcp snooping sw
302          34         7       4857  0.00%  0.00%  0.00%   0 SpanTree Helper
303           0        44          0  0.00%  0.00%  0.00%   0 EEM Server
304           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
305          50         3      16666  0.00%  0.00%  0.00%   0 OBFL MSG obfl0
306           0         2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
307           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
308           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
309           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
310           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
311           8         3       2666  0.00%  0.00%  0.00%   0 EEM ED None
312           0         3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
313           0        81          0  0.00%  0.00%  0.00%   0 SSH Event handle
314           0         3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
315           0         3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
316           8         3       2666  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
317           0         2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
318          60      3871         15  0.00%  0.00%  0.00%   0 EEM ED Timer
319           0        20          0  0.00%  0.00%  0.00%   0 Syslog
320           0         3          0  0.00%  0.00%  0.00%   0 RBM CORE
321           0         2          0  0.00%  0.00%  0.00%   0 STP FAST TRANSIT
322           0         2          0  0.00%  0.00%  0.00%   0 CSRT RAPID TRANS
323       17897    215452         83  0.00%  0.01%  0.00%   0 CEF: IPv4 proces
324           0         3          0  0.00%  0.00%  0.00%   0 ADJ background
325        1990      2422        821  0.00%  0.00%  0.00%   0 IP Background
326           0         2          0  0.00%  0.00%  0.00%   0 hulc cfg mgr mas
327        5739       217      26447  0.00%  3.36%  1.21%   1 Virtual Exec
328           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
329       32689    105287        310  0.00%  0.02%  0.00%   0 IP SNMP
330       11521     52936        217  0.00%  0.01%  0.00%   0 PDU DISPATCHER
331      436206     52936       8240  0.00%  0.08%  0.05%   0 SNMP ENGINE
332           0         2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
333           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
334           0         2          0  0.00%  0.00%  0.00%   0 SNMP Traps
335        1335        10     133500  0.00%  0.00%  0.00%   0 hulc running con
336       69589      3878      17944  0.00%  0.00%  0.08%   0 crypto sw pk pro
337          51         5      10200  0.00%  0.00%  0.00%   0 OBFL ENV obfl0
338       69317      2342      29597  0.00%  0.01%  0.00%   0 OBFL VOLT obfl0
339         378      9344         40  0.00%  0.00%  0.00%   0 OBFL I/O Buffer
------------------ show process cpu history ------------------
    11144444     111111111111111          11111111111111111111
    1119999999999000000000011111999998888800000555558888833333
100
90
80
70
60
50    *****
40    *****
30    *****
20    *****                                   **********
10 **********************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    1421222212212222111223212222222221112121211221122233122111
    8948770090070111979204374031431135841807279026910103913847
100
90
80
70
60
50  *
40  *
30  *  **               *                            **
20 *#*******************#************* ***************#**** *
10 ##########################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    43654954365554443545543544443444445449
    97209596641997896681448135517538705759
100      *                               *
90      *                               *
80      *                               *
70      *                               *
60   *  **  * **    *                *  *
50 * ****** ******* ****  * **  * ** ****
40 **************************************
30 **************************************
20 **************************************
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show logging ------------------
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 38 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 38 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 41 message lines logged
Log Buffer (4096 bytes):
SE_BOOT_LEVEL =
*Mar  1 00:00:07.012: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3560x Next reboot level = ipservices and License = ipservices
*Mar  1 00:00:52.638: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:00:54.442: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
000005: *Mar  1 00:00:58.300: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan40, changed state to down
000006: *Mar  1 00:00:58.300: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
000007: *Mar  1 00:00:58.435: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan244, changed state to down
000008: *Mar  1 00:00:58.527: %SYS-5-CONFIG_I: Configured from memory by console
000009: *Mar  1 00:00:59.911: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:57 by prod_rel_team
000010: *Mar  1 00:00:59.936: %SSH-5-ENABLED: SSH 1.99 has been enabled
000011: *Mar  1 00:01:01.387: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
000012: *Mar  1 00:01:01.933: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
000013: *Mar  1 00:01:02.553: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
000014: *Mar  1 00:01:02.553: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
000015: *Mar  1 00:01:03.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
000016: *Mar  1 00:01:04.256: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
000017: *Mar  1 00:01:04.256: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
000018: *Mar  1 00:01:04.776: %PLATFORM-6-FRULINK_INSERTED: FRULink 1G module inserted.
000019: *Mar  1 00:01:06.739: %LINK-3-UPDOWN: Interface GigabitEthernet1/1, changed state to up
000020: *Mar  1 00:01:09.658: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1, changed state to up
000021: *Mar  1 00:01:38.666: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
000022: *Mar  1 00:01:38.775: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan40, changed state to up
000023: *Mar  1 00:01:38.775: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan244, changed state to up
000024: *Mar  1 00:01:44.127: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.101.
000025: *Mar  1 00:01:51.425: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.103.
000026: *Mar  1 00:01:52.432: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.104.
000027: *Mar  1 00:02:01.517: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.108.
000028: *Mar  1 00:02:02.532: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.109.
000029: *Mar  1 00:02:17.103: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.111.
000030: *Mar  1 00:02:18.110: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.112.
000031: *Mar  1 00:02:19.116: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.113.
000032: *Mar  1 02:18:36.096: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.116.
000033: *Mar  1 02:18:37.103: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.117.
000034: *Mar  1 02:37:20.807: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.119.
000035: *Mar  1 02:37:21.814: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 105.103.95.120.
000036: *Mar  1 23:21:27.177: %IP-4-DUPADDR: Duplicate address 105.103.40.1 on Vlan40, sourced by 0010.f324.e7d7
000037: *Mar  1 23:23:58.256: %IP-4-DUPADDR: Duplicate address 105.103.40.1 on Vlan40, sourced by 0010.f324.e7d7
000038: *Mar  1 23:26:50.072: %IP-4-DUPADDR: Duplicate address 105.103.40.1 on Vlan40, sourced by 0010.f324.e7d7
------------------ show env all ------------------
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
TEMPERATURE is OK
Temperature Value: 24 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     DTN1612L0KV  OK              Good     Good     350/0
1B  Not Present
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
------------------ show interfaces status ------------------
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/1     [ * L3#1 Uplink *  connected    routed     a-full a-1000 10/100/1000BaseTX
Gi0/2     [ * L3#2 Uplink *  connected    routed     a-full a-1000 10/100/1000BaseTX
Gi0/3                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/4                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/5                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/6                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/7                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/8                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/9                        notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/10                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/11                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/12                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/13                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/14                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/15                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/16                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/17                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/18                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/19                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/20                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/21                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/22                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/23                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/24                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi1/1                        connected    trunk      a-full a-1000 1000BaseSX SFP
Gi1/2                        notconnect   1            auto   auto Not Present
Gi1/3                        notconnect   1            auto   auto 1000BaseSX SFP
Gi1/4                        notconnect   1            auto   auto Not Present
Fa0                          notconnect   routed       auto   auto 10/100BaseTX
------------------ show interfaces status err-disabled ------------------
------------------ show interfaces switchport ------------------
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: down
Administrative Trunking Encapsulation: negotiate
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Switchport: Enabled
------------------ show interfaces trunk ------------------
Port        Mode             Encapsulation  Status        Native vlan
Gi1/1       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/1       1-4094
Port        Vlans allowed and active in management domain
Gi1/1       1-2,22,25,27,29-40,58,60,63,112,222-227,229-230,233-235,240,242-244,247-248
Port        Vlans in spanning tree forwarding state and not pruned
------------------ show vlan ------------------
VLAN Name                             Status    Ports
1    default                          active    Gi0/3, Gi0/4, Gi0/5, Gi0/6, Gi0/7, Gi0/8, Gi0/9, Gi0/10, Gi0/11, Gi0/12, Gi0/13
                                                Gi0/14, Gi0/15, Gi0/16, Gi0/17, Gi0/18, Gi0/19, Gi0/20, Gi0/21, Gi0/22, Gi0/23
                                                Gi0/24, Gi1/2, Gi1/3, Gi1/4
2    VLAN0002                         active
22   SERVER                           active
25   ADM                              active
27   WH                               active
29   DSC                              active
30   HHP                              active
31   SMD-OFC                          active
32   TOC                              active
33   LCM                              active
34   VD                               active
35   UTL                              active
36   AC                               active
37   QC                               active
38   ENG                              active
39   PBA                              active
40   AIM                              active
58   FDC                              active
60   SMD                              active
63   HDD                              active
112  VLAN0112                         active
222  uReady_setup                     active
223  VLAN0223                         active
224  uReady_guest                     active
225  uReady_device                    active
226  uReadyintranet                   active
227  uReadyintranet_setup             active
229  uReady_uReady                    active
230  uReady_roam                      active
233  VLAN0233                         active
234  VLAN0234                         active
235  WLAN-SDS-WH                      active
240  VLAN0240                         active
242  VLAN0242                         active
243  VLAN0243                         active
244  VLAN0244                         active
247  VLAN0247                         active
248  VLAN0248                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
22   enet  100022     1500  -      -      -        -    -        0      0
25   enet  100025     1500  -      -      -        -    -        0      0
27   enet  100027     1500  -      -      -        -    -        0      0
29   enet  100029     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
31   enet  100031     1500  -      -      -        -    -        0      0
32   enet  100032     1500  -      -      -        -    -        0      0
33   enet  100033     1500  -      -      -        -    -        0      0
34   enet  100034     1500  -      -      -        -    -        0      0
35   enet  100035     1500  -      -      -        -    -        0      0
36   enet  100036     1500  -      -      -        -    -        0      0
37   enet  100037     1500  -      -      -        -    -        0      0
38   enet  100038     1500  -      -      -        -    -        0      0
39   enet  100039     1500  -      -      -        -    -        0      0
40   enet  100040     1500  -      -      -        -    -        0      0
58   enet  100058     1500  -      -      -        -    -        0      0
60   enet  100060     1500  -      -      -        -    -        0      0
63   enet  100063     1500  -      -      -        -    -        0      0
112  enet  100112     1500  -      -      -        -    -        0      0
222  enet  100222     1500  -      -      -        -    -        0      0
223  enet  100223     1500  -      -      -        -    -        0      0
224  enet  100224     1500  -      -      -        -    -        0      0
225  enet  100225     1500  -      -      -        -    -        0      0
226  enet  100226     1500  -      -      -        -    -        0      0
227  enet  100227     1500  -      -      -        -    -        0      0
229  enet  100229     1500  -      -      -        -    -        0      0
230  enet  100230     1500  -      -      -        -    -        0      0
233  enet  100233     1500  -      -      -        -    -        0      0
234  enet  100234     1500  -      -      -        -    -        0      0
235  enet  100235     1500  -      -      -        -    -        0      0
240  enet  100240     1500  -      -      -        -    -        0      0
242  enet  100242     1500  -      -      -        -    -        0      0
243  enet  100243     1500  -      -      -        -    -        0      0
244  enet  100244     1500  -      -      -        -    -        0      0
247  enet  100247     1500  -      -      -        -    -        0      0
248  enet  100248     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    srb      0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
------------------ show mac-address-table ------------------
------------------ show spanning-tree ------------------
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     0019.305c.8a00
             Cost        23
             Port        25 (GigabitEthernet1/1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     a493.4cf6.3800
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/1               Root FWD 4         128.25   P2p
VLAN0002
  Root ID    Priority    32770
             Cost        23
  Bridge ID  Priority    32770  (priority 32768 sys-id-ext 2)
             Aging Time  300 sec
VLAN0022
  Root ID    Priority    32790
             Cost        23
  Bridge ID  Priority    32790  (priority 32768 sys-id-ext 22)
             Aging Time  300 sec
VLAN0025
  Root ID    Priority    32793
             Cost        23
  Bridge ID  Priority    32793  (priority 32768 sys-id-ext 25)
             Aging Time  300 sec
VLAN0027
  Root ID    Priority    32795
             Cost        23
  Bridge ID  Priority    32795  (priority 32768 sys-id-ext 27)
             Aging Time  300 sec
VLAN0029
  Root ID    Priority    32797
             Cost        23
  Bridge ID  Priority    32797  (priority 32768 sys-id-ext 29)
             Aging Time  300 sec
VLAN0030
  Root ID    Priority    32798
             Cost        23
  Bridge ID  Priority    32798  (priority 32768 sys-id-ext 30)
             Aging Time  300 sec
VLAN0031
  Root ID    Priority    32799
             Cost        23
  Bridge ID  Priority    32799  (priority 32768 sys-id-ext 31)
             Aging Time  300 sec
VLAN0032
  Root ID    Priority    32800
             Cost        23
  Bridge ID  Priority    32800  (priority 32768 sys-id-ext 32)
             Aging Time  300 sec
VLAN0033
  Root ID    Priority    32801
             Cost        23
  Bridge ID  Priority    32801  (priority 32768 sys-id-ext 33)
             Aging Time  300 sec
VLAN0034
  Root ID    Priority    32802
             Cost        23
  Bridge ID  Priority    32802  (priority 32768 sys-id-ext 34)
             Aging Time  300 sec
VLAN0035
  Root ID    Priority    32803
             Cost        23
  Bridge ID  Priority    32803  (priority 32768 sys-id-ext 35)
             Aging Time  300 sec
VLAN0036
  Root ID    Priority    32804
             Cost        23
  Bridge ID  Priority    32804  (priority 32768 sys-id-ext 36)
             Aging Time  300 sec
VLAN0037
  Root ID    Priority    32805
             Cost        23
  Bridge ID  Priority    32805  (priority 32768 sys-id-ext 37)
             Aging Time  300 sec
VLAN0038
  Root ID    Priority    32806
             Cost        23
  Bridge ID  Priority    32806  (priority 32768 sys-id-ext 38)
             Aging Time  300 sec
VLAN0039
  Root ID    Priority    32807
             Cost        23
  Bridge ID  Priority    32807  (priority 32768 sys-id-ext 39)
             Aging Time  300 sec
VLAN0040
  Root ID    Priority    24616
             This bridge is the root
  Bridge ID  Priority    24616  (priority 24576 sys-id-ext 40)
             Aging Time  300 sec
Gi1/1               Desg FWD 4         128.25   P2p
VLAN0058
  Root ID    Priority    32826
             Cost        23
  Bridge ID  Priority    32826  (priority 32768 sys-id-ext 58)
             Aging Time  300 sec
VLAN0060
  Root ID    Priority    32828
             Cost        23
  Bridge ID  Priority    32828  (priority 32768 sys-id-ext 60)
             Aging Time  300 sec
VLAN0063
  Root ID    Priority    32831
             Cost        23
  Bridge ID  Priority    32831  (priority 32768 sys-id-ext 63)
             Aging Time  300 sec
VLAN0112
  Root ID    Priority    32880
             Cost        23
  Bridge ID  Priority    32880  (priority 32768 sys-id-ext 112)
             Aging Time  300 sec
VLAN0222
  Root ID    Priority    32990
             Cost        23
  Bridge ID  Priority    32990  (priority 32768 sys-id-ext 222)
             Aging Time  300 sec
VLAN0223
  Root ID    Priority    32991
             Cost        23
  Bridge ID  Priority    32991  (priority 32768 sys-id-ext 223)
             Aging Time  300 sec
VLAN0224
  Root ID    Priority    32992
             Cost        23
  Bridge ID  Priority    32992  (priority 32768 sys-id-ext 224)
             Aging Time  300 sec
VLAN0225
  Root ID    Priority    32993
             Cost        23
  Bridge ID  Priority    32993  (priority 32768 sys-id-ext 225)
             Aging Time  15  sec
VLAN0226
  Root ID    Priority    32994
             Cost        23
  Bridge ID  Priority    32994  (priority 32768 sys-id-ext 226)
             Aging Time  300 sec
VLAN0227
  Root ID    Priority    32995
             Cost        23
  Bridge ID  Priority    32995  (priority 32768 sys-id-ext 227)
             Aging Time  300 sec
VLAN0229
  Root ID    Priority    32997
             Cost        23
  Bridge ID  Priority    32997  (priority 32768 sys-id-ext 229)
             Aging Time  300 sec
VLAN0230
  Root ID    Priority    32998
             Cost        23
  Bridge ID  Priority    32998  (priority 32768 sys-id-ext 230)
             Aging Time  300 sec
VLAN0233
  Root ID    Priority    33001
             Cost        23
  Bridge ID  Priority    33001  (priority 32768 sys-id-ext 233)
             Aging Time  300 sec
VLAN0234
  Root ID    Priority    33002
             Cost        23
  Bridge ID  Priority    33002  (priority 32768 sys-id-ext 234)
             Aging Time  300 sec
VLAN0235
  Root ID    Priority    33003
             Cost        23
  Bridge ID  Priority    33003  (priority 32768 sys-id-ext 235)
             Aging Time  300 sec
VLAN0240
  Root ID    Priority    33008
             Cost        23
  Bridge ID  Priority    33008  (priority 32768 sys-id-ext 240)
             Aging Time  300 sec
VLAN0242
  Root ID    Priority    33010
             Cost        23
  Bridge ID  Priority    33010  (priority 32768 sys-id-ext 242)
             Aging Time  300 sec
VLAN0243
  Root ID    Priority    33011
             Cost        23
  Bridge ID  Priority    33011  (priority 32768 sys-id-ext 243)
             Aging Time  300 sec
VLAN0244
  Root ID    Priority    24820
  Bridge ID  Priority    24820  (priority 24576 sys-id-ext 244)
             Aging Time  300 sec
VLAN0247
  Root ID    Priority    33015
             Cost        23
  Bridge ID  Priority    33015  (priority 32768 sys-id-ext 247)
             Aging Time  300 sec
VLAN0248
  Root ID    Priority    33016
             Cost        23
  Bridge ID  Priority    33016  (priority 32768 sys-id-ext 248)
             Aging Time  300 sec
------------------ show etherchannel summary ------------------
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 0
Number of aggregators:           0
Group  Port-channel  Protocol    Ports
------------------ show ipc nodes ------------------
There is 1 node in this IPC realm.
   ID       Type               Name                             Last   Last
        Sent   Heard
0.10000    Local      IPC Master                               0      0
------------------ show ipc ports ------------------
There are 9 ports defined.
Port ID        Type       Name                    (current/peak/total)
   10000.1     unicast    IPC Master:Zone
   10000.2     unicast    IPC Master:Echo
   10000.3     unicast    IPC Master:Control
   10000.4     unicast    IPC Master:Init
   10000.5     unicast    FIB Master: DFS.process_level.msgs
   10000.6     unicast    FIB Master: DFS.interrupt.msgs
   10000.7     unicast    MDFS RP: Statistics
     port_index = 0  seat_id = 0x10000    last sent = 0     last heard = 0
     rcv pending/peak/total       = 0/2/9366
   10000.8     unicast    Slot 1 : MDFS.control.RIL
     rcv pending/peak/total       = 0/0/0
   10000.9     unicast    OBFL Master Port
RPC packets: current/peak/total
------------------ show ipc status ------------------
                            IPC System Status
Time last IPC stat cleared : never
This processor is the IPC master server.
Do not drop output of IPC frames for test purposes.
1000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
Total Frames                                             9366       18732
Total from Local Ports                                  18732       18732
Total Protocol Control Frames                               0           0
Total Frames Dropped                                        0           0
                             Service Usage
Total via Unreliable Connection-Less Service             9366        9366
Total via Unreliable Sequenced Connection-Less Svc          0           0
Total via Reliable Connection-Oriented Service              0           0
                      IPC Protocol Version 0
Total Acknowledgements                                      0           0
Total Negative Acknowledgements                             0           0
                             Device Drivers
Total via Local Driver                                   9366        9366
Total via Platform Driver                                   0           0
Total Frames Dropped by Platform Drivers                    0           0
Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
Re-Transmission                                                         0
Re-Tx Timeout                                                           0
          Rx Errors                              Tx Errors
Unsupp IPC Proto Version          0  Tx Session Error                  0
Corrupt Frame                     0  Tx Seat Error                     0
Duplicate Frame                   0  Destination Unreachable           0
Rel Out-of-Seq Frame              0  Unrel Out-of-Seq Frame            0
Dest Port does Not Exist          0  Tx Driver Failed                  0
Rx IPC Msg Alloc Failed           0  Rx IPC Frag Dropped               0
Rx IPC Transform Errors           0  Tx IPC Transform Errors           0
Unable to Deliver Msg             0  Tx Test Drop                      0
Ctrl Frm Alloc Failed             0  Rx Msg Callback Hog               0
          Buffer Errors                          Misc Errors
IPC Msg Alloc                     0  IPC Open Port                     0
Emer IPC Msg Alloc                0  No HWQ                            0
IPC Frame PakType Alloc           0  Hardware Error                    0
IPC Frame MemD Alloc              0  Invalid Messages                  0
          Tx Driver Errors
No Transport                      0
MTU Failure                       0
Dest does not Exist               0
------------------ show cef linecard ------------------
Slot   Flags
------------------ show ip mds stats linecard ------------------
Slot      Status    IPC(seq/max/window) Q(high/route)  Reloads
1        active    0    /256  /256        0/0            9364
------------------ show sdm prefer ------------------
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:                  6K
  number of IPv4 IGMP groups + multicast routes:    1K
  number of IPv4 unicast routes:                    8K
    number of directly-connected IPv4 hosts:        6K
    number of indirect IPv4 routes:                 2K
  number of IPv4 policy based routing aces:         0
  number of IPv4/MAC qos aces:                      0.5K
  number of IPv4/MAC security aces:                 1K
------------------ show vtp status ------------------
VTP Version capable             : 1 to 3
VTP version running             : 1
VTP Domain Name                 : M_S2
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : a493.4cf6.3800
Configuration last modified by 105.103.2.2 at 7-27-12 07:48:37
Local updater ID is 105.103.40.1 on interface Vl40 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 42
Configuration Revision            : 57
MD5 digest                        : 0x7A 0xCA 0xB4 0x77 0x1A 0xD8 0x7F 0x91
                                    0x81 0x40 0xDB 0x97 0x9B 0xF7 0xD4 0x6B
------------------ show mac-address-table count ------------------
------------------ show platform port-asic mvid ------------------
Mapped Vlan Id Table (port-asic: 0)
Index V4 Labels V6 Labels Fwd-lbl ttl st vlan   mtu bg df m6m4u6u4a svi
                       untagged  blk-lrn blk-fwd vp-errd  s-id o-id a-id l-id
1      00000000  00000000   000    2   0  1     1518 0  0  0 0 0 0 0 40
                        FFFFFFF  FFFFFBF FFFFFBF 0000000  0    0    0    0
2      00000000  00000000   000    2   0  22    1518 0  0  0 0 0 0 0 0
                        FFFFFBF  FFFFFBF FFFFFBF 0000000  0    0    0    0
3      00000000  00000000   000    2   0  25    1518 0  0  0 0 0 0 0 0
4      00000000  00000000   000    2   0  27    1518 0  0  0 0 0 0 0 0
5      00000000  00000000   000    2   0  29    1518 0  0  0 0 0 0 0 0
6      00000000  00000000   000    2   0  30    1518 0  0  0 0 0 0 0 0
7      00000000  00000000   000    2   0  31    1518 0  0  0 0 0 0 0 0
8      00000000  00000000   000    2   0  32    1518 0  0  0 0 0 0 0 0
9      00000000  00000000   000    2   0  33    1518 0  0  0 0 0 0 0 0
10     00000000  00000000   000    2   0  34    1518 0  0  0 0 0 0 0 0
11     00000000  00000000   000    2   0  35    1518 0  0  0 0 0 0 0 0
12     00000000  00000000   000    2   0  36    1518 0  0  0 0 0 0 0 0
13     00000000  00000000   000    2   0  37    1518 0  0  0 0 0 0 0 0
14     00000000  00000000   000    2   0  38    1518 0  0  0 0 0 0 0 0
15     00000000  00000000   000    2   0  39    1518 0  0  0 0 0 0 0 0
16     00000000  00000000   000    2   0  40    1518 0  0  0 0 0 1 0 43
17     00000000  00000000   000    2   0  58    1518 0  0  0 0 0 0 0 0
18     00000000  00000000   000    2   0  60    1518 0  0  0 0 0 0 0 0
19     00000000  00000000   000    2   0  63    1518 0  0  0 0 0 0 0 0
20     00000000  00000000   000    2   0  222   1518 0  0  0 0 0 0 0 0
21     00000000  00000000   000    2   0  224   1518 0  0  0 0 0 0 0 0
22     00000000  00000000   000    2   0  225   1518 0  0  0 0 0 0 0 0
23     00000000  00000000   000    2   0  226   1518 0  0  0 0 0 0 0 0
24     00000000  00000000   000    2   0  227   1518 0  0  0 0 0 0 0 0
25     00000000  00000000   000    2   0  229   1518 0  0  0 0 0 0 0 0
26     00000000  00000000   000    2   0  230   1518 0  0  0 0 0 0 0 0
27     00000000  00000000   000    2   0  235   1518 0  0  0 0 0 0 0 0
28     00000000  00000000   000    2   0  2     1518 0  0  0 0 0 0 0 0
29     00000000  00000000   000    2   0  112   1518 0  0  0 0 0 0 0 0
30     00000000  00000000   000    2   0  223   1518 0  0  0 0 0 0 0 0
31     00000000  00000000   000    2   0  233   1518 0  0  0 0 0 0 0 0
32     00000000  00000000   000    2   0  234   1518 0  0  0 0 0 0 0 0
33     00000000  00000000   000    2   0  240   1518 0  0  0 0 0 0 0 0
34     00000000  00000000   000    2   0  242   1518 0  0  0 0 0 0 0 0
35     00000000  00000000   000    2   0  243   1518 0  0  0 0 0 0 0 0
36     00000000  00000000   000    2   0  244   1518 0  0  0 0 0 1 0 44
37     00000000  00000000   000    2   0  247   1518 0  0  0 0 0 0 0 0
38     00000000  00000000   000    2   0  248   1518 0  0  0 0 0 0 0 0
39     00000000  00000000   000    2   0  1006  1518 0  0  0 0 0 1 0 41
                        FFFFFFF  FFFFFFF FFFFFFF 0000000  0    0    0    0
40     00000000  00000000   000    2   0  1007  1518 0  0  0 0 0 1 0 42
Mapped Vlan Id Table (port-asic: 1)
                        FFFFFFF  FFFFFFF FFFFFFD 0000000  0    0    0    0
                        FFFFFFF  FFFFFFF FFFFFFE 0000000  0    0    0    0
------------------ show platform messaging application summary ------------------
Incoming request summary:
Request Class              Outstanding   Min Seq    Max Seq
Outgoing request summary:
Request Class              Outstanding   Min Seq    Max Seq   Throttled
  (0x00)test                   0             0          0           0
  (0x01)rfs                    0             0          0           0
  (0x02)cfg_backup             0             0          0           0
  (0x03)pm                     0             0          0           0
  (0x04)pm-counters            0             0          0           0
  (0x05)vqpc                   0             0          0           0
  (0x06)vlan                   0             0          0           0
  (0x07)hlfm                   0             0          0           0
  (0x08)hl3u                   0             0          0           0
  (0x09)hl2mcm igmpsn          0             0          0           0
  (0x0A)stp_state_sync         0             0          0           0
  (0x0B)stp_cli                0             0          0           0
  (0x0C)hfbm                   0             0          0           0
  (0x0D)acl                    0             0          0           0
  (0x0E)qos                    0             0          0           0
  (0x0F)sdm                    0             0          0           0
  (0x10)span                   0             0          0           0
  (0x11)hsm                    0             0          0           0
  (0x12)asic-stats             0             0          0           0
  (0x13)hdm non blocking       0             0          0           0
  (0x14)hled                   0             0          0           0
  (0x15)hcmp                   0             0          0           0
  (0x16)hudld                  0             0          0           0
  (0x17)hpsecure               0             0          0           0
  (0x18)dot1x                  0             0          0           0
  (0x19)hl3mm                  0             0          0           0
  (0x1A)show_forward           0             0          0           0
  (0x1B)hrcli-events           0             0          0           0
  (0x1C)test_hhprpc            0             0          0           0
  (0x1D)test_hrpc_notreg       0             0          0           0
  (0x1E)system mtu             0             0          0           0
  (0x1F)snmp                   0             0          0           0
  (0x20)hdm blocking           0             0          0           0
  (0x21)hrcmd                  0             0          0           0
  (0x22)system post            0             0          0           0
  (0x23)dtp                    0             0          0           0
  (0x24)cdp                    0             0          0           0
  (0x25)hulc misc rpc          0             0          0           0
  (0x26)ilp                    0             0          0           0
  (0x27)x_setup                0             0          0           0
  (0x28)cable diagnostics      0             0          0           0
  (0x29)dhcp snooping          0             0          0           0
  (0x2A)iec_load_balance       0             0          0           0
  (0x2B)backup interface       0             0          0           0
  (0x2C)ip source guard        0             0          0           0
  (0x2D)dai                    0             0          0           0
  (0x2E)IPv6 Host              0             0          0           0
  (0x2F)IPv6 Unicast Rt        0             0          0           0
  (0x30)hssp                   0             0          0           0
  (0x31)l2pt qnq rpc           0             0          0           0
  (0x32)Multi-FS Sync          0             0          0           0
  (0x33)lpip                   0             0          0           0
  (0x34)hl2mcm mldsn           0             0          0           0
  (0x35)hcomp                  0             0          0           0
  (0x36)emac                   0             0          0           0
  (0x37)hdwl                   0             0          0           0
  (0x38)obfl                   0             0          0           0
  (0x39)foxhound               0             0          0           0
  (0x3A)hwccp                  0             0          0           0
  (0x3B)lldp                   0             0          0           0
  (0x3C)ip device track        0             0          0           0
  (0x3D)IPe                    0             0          0           0
  (0x3E)rep                    0             0          0           0
  (0x3F)hnetwpol               0             0          0           0
  (0x40)isis                   0             0          0           0
  (0x41)aim                    0             0          0           0
  (0x42)EnergyWise             0             0          0           0
  (0x43)ipadm                  0             0          0           0
  (0x44)Smart Install          0             0          0           0
  (0x45)stack power            0             0          0           0
  (0x46)macsec                 0             0          0           0
  (0x47)power down             0             0          0           0
  (0x48)actual power           0             0          0           0
------------------ show platform vlan refcount ------------------
VLAN MVID L3U    L2U    L3M    L2M    PM     SPAN   ACL    QOS    FBM    IPV6   V6L2M
1    1    0      0      0      0      1      0      0      0      0      0      0
2    28   0      0      0      0      1      0      0      0      0      0      0
22   2    0      0      0      0      1      0      0      0      0      0      0
25   3    0      0      0      0      1      0      0      0      0      0      0
27   4    0      0      0      0      1      0      0      0      0      0      0
29   5    0      0      0      0      1      0      0      0      0      0      0
30   6    0      0      0      0      1      0      0      0      0      0      0
31   7    0      0      0      0      1      0      0      0      0      0      0
32   8    0      0      0      0      1      0      0      0      0      0      0
33   9    0      0      0      0      1      0      0      0      0      0      0
34   10   0      0      0      0      1      0      0      0      0      0      0
35   11   0      0      0      0      1      0      0      0      0      0      0
36   12   0      0      0      0      1      0      0      0      0      0      0
37   13   0      0      0      0      1      0      0      0      0      0      0
38   14   0      0      0      0      1      0      0      0      0      0      0
39   15   0      0      0      0      1      0      0      0      0      0      0
40   16   12D    0      0      0      1      0      0      0      0      0      0
58   17   0      0      0      0      1      0      0      0      0      0      0
60   18   0      0      0      0      1      0      0      0      0      0      0
63   19   0      0      0      0      1      0      0      0      0      0      0
112  29   0      0      0      0      1      0      0      0      0      0      0
222  20   0      0      0      0      1      0      0      0      0      0      0
223  30   0      0      0      0      1      0      0      0      0      0      0
224  21   0      0      0      0      1      0      0      0      0      0      0
225  22   0      0      0      0      1      0      0      0      0      0      0
226  23   0      0      0      0      1      0      0      0      0      0      0
227  24   0      0      0      0      1      0      0      0      0      0      0
229  25   0      0      0      0      1      0      0      0      0      0      0
230  26   0      0      0      0      1      0      0      0      0      0      0
233  31   0      0      0      0      1      0      0      0      0      0      0
234  32   0      0      0      0      1      0      0      0      0      0      0
235  27   0      0      0      0      1      0      0      0      0      0      0
240  33   0      0      0      0      1      0      0      0      0      0      0
242  34   0      0      0      0      1      0      0      0      0      0      0
243  35   0      0      0      0      1      0      0      0      0      0      0
244  36   35     0      0      0      1      0      0      0      0      0      0
247  37   0      0      0      0      1      0      0      0      0      0      0
248  38   0      0      0      0      1      0      0      0      0      0      0
1006 39   2      0      0      0      1      0      0      0      0      0      0
1007 40   2      0      0      0      1      0      0      0      0      0      0
------------------ show platform pm stack-view ------------------
A - Switch Present
P - Interfaces Ready Event
R - Switch Ready
S - Switch Ready Event
V - Bulk VLANs
                Switch Interface Ready Table
              if-1
*sw-1  AP    RSV
------------------ show platform port-asic version ------------------
Port-Asic Version Info:
ASIC-0: Version:4 DeviceType:0x30A
ASIC-1: Version:4 DeviceType:0x30A
------------------ show platform port-asic receive port-lockup ------------------
------------------ show platform tcam util asic all ------------------
CAM Utilization for ASIC# 0                      Max            Used
                                             Masks/Values    Masks/values
Unicast mac addresses:                       6364/6364        387/387
IPv4 IGMP groups + multicast routes:         1120/1120          1/1
IPv4 unicast directly-connected routes:      6144/6144        356/356
IPv4 unicast indirectly-connected routes:    2048/2048       1839/1839
IPv4 policy based routing aces:               452/452          12/12
IPv4 qos aces:                                512/512           6/6
IPv4 security aces:                           964/964          34/34
Note: Allocation of TCAM entries per feature uses
a complex algorithm. The above information is meant
to provide an abstract view of the current TCAM utilization
CAM Utilization for ASIC# 1                      Max            Used
IPv4 policy based routing aces:               452/452           0/0
------------------ show platform dl detail ------------------
DLPD version base:      INFO: 1.0 XAPI: 1.2 IMPORT: 1.1
        Name:dlpd_img_bipd type: DLPD
        Status: Active
                Bound to ports:
                Gi0/1 Gi0/2 Gi0/3 Gi0/4
                Gi0/5 Gi0/6 Gi0/7 Gi0/8
                Gi0/9 Gi0/10 Gi0/11 Gi0/12
                Gi0/13 Gi0/14 Gi0/15 Gi0/16
                Gi0/17 Gi0/18 Gi0/19 Gi0/20
                Gi0/21 Gi0/22 Gi0/23 Gi0/24
                Gi1/1 Gi1/2 Gi1/3 Gi1/4
                Te1/1 Te1/2
DLPCS version base:     184.00.00
------------------ show controllers power inline ------------------
------------------ show diagnostic switch ------------------
:   SerialNo : FDO1621P0XZ
  Overall diagnostic result: UNTESTED
  Test results: (. = Pass, F = Fail, U = Untested)
    1) TestPortAsicStackPortLoopback ---> U
    2) TestPortAsicLoopback ------------> U
    3) TestPortAsicCam -----------------> U
    4) TestPortAsicRingLoopback --------> U
    5) TestMicRingLoopback -------------> U
    6) TestPortAsicMem -----------------> U
------------------ show diagnostic post ------------------
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
------------------ show platform ip unicast failed route ------------------
Total of 0 covering fib entries
------------------ show platform ip unicast failed adjacency ------------------
Dumping Fibs with Adj fails info(0 entries:0)
------------------ show platform ip unicast failed arp ------------------
Total of 2 arp entries waiting on ARP-HRPC ThrottleQ
ARP throttled IP Address
         105.103.103.101/32 Table:0
         105.103.103.74/32 Table:0
------------------ show stack-power ------------------
------------------ show crypto key mypubkey rsa ------------------
% Key pair was generated at: 00:01:27 UTC Mar 1 1993
Key name: TP-self-signed-1291204608
Storage Device: private-config
Usage: General Purpose Key
Key is not exportable.
Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00A3A8B7
  2D25DB04 788483A4 078BF06E 4051BCB8 95B2F5ED D6A6E95B BCE7516F 365A28EA
  83946F83 9E6B294A 1E373674 924B01A7 F28B23B8 A7019B08 9E8313A4 B1B747F8
  AEC6EF9F A8494E77 94FC876E BB015D6C 2BA8EA1F 8D1B6258 6D41FD32 D6AE98D1
  EE19CC67 9328F28B 3088879B DF58E84F 8C2784D5 5703F564 D77DCBDA 35020301 0001
% Key pair was generated at: 15:02:18 UTC Mar 2 1993
Key name: TP-self-signed-1291204608.server
Temporary key
Usage: Encryption Key
Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00A69A52 9CB2CEA1
  408B207B 56025D43 C098E9CE 8604F589 6788B0BC 40D5EC6C 44B692C6 2BFF9FF1
  B9705532 74C6CBB8 427C5F61 0BD3BE56 E43550C6 8C5153B9 F2CA09EC 58A4E9B5
  20C9F882 643B483F A31F6DA9 DBD5EF70 43610598 DEC40366 67020301 0001
------------------ remote command all show license file ------------------
------------------ remote command all show license detail ------------------
------------------ remote command all show license status ------------------
------------------ show inventory ------------------
NAME: "1", DESCR: "WS-C3560X-24"
PID: WS-C3560X-24T-S   , VID: V02  , SN: FDO1621P0XZ
NAME: "Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-350WAC   , VID: V02  , SN: DTN1612L0KV
NAME: "FRULink Slot 1 - FRULink Module", DESCR: "FRULink 1G Module"
PID: C3KX-NM-1G        , VID: V01  , SN: FDO16232BYW
NAME: "GigabitEthernet1/1", DESCR: "1000BaseSX SFP"
PID: Unspecified       , VID:      , SN: FNS152717UA
NAME: "GigabitEthernet1/3", DESCR: "1000BaseSX SFP"
PID: Unspecified       , VID:      , SN: FNS14290BLH
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x00000000  0x0FFFFFFF   268435456  Local  R/W    main
0x00000020  0x0FFFFFFF   268435424  Local  R/W    main:coredump
0x00003000  0x0207D21F    34054688  IText  R/W    coredump:text
0x02400000  0x027FFFFF     4194304  IText  R/W    coredump:dltext
0x02800000  0x033C4347    12337992  IData  R/W    coredump:data
0x0313B660  0x031BB65F      524288  Local  R/W    data:reclaimed_heap
0x031EF42C  0x03322C2B     1259520  Local  R/W    data:reclaimed_heap
0x033C4348  0x03C60773     9028652  IBss   R/W    coredump:bss
0x03C60778  0x0DFFFFFF   171571336  Local  R/W    coredump:heap
0x0E000000  0x0EFFFFFF    16777216  Iomem  R/W    coredump:iomem
Free Region Manager:
0x0F000054  0x0FFFDFFF    16768940  Local  R/W    heap
------------------ show buffers ------------------
Buffer elements:
     1056 in free list (500 max allowed)
     1567738 hits, 0 misses, 1024 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 116 @ 1d15h):
     47 in free list (20 min, 150 max allowed)
     480437 hits, 35 misses, 94 trims, 94 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 31, permanent 25, peak 46 @ 1d15h):
     23 in free list (10 min, 150 max allowed)
     60504 hits, 9 misses, 21 trims, 27 created
Big buffers, 1536 bytes (total 50, permanent 50):
     50 in free list (5 min, 150 max allowed)
     491114 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 14, permanent 10, peak 14 @ 1d15h):
     0 in free list (0 min, 100 max allowed)
     58 hits, 2 misses, 0 trims, 4 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 10 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 0, permanent 0):
     0 in free list (0 min, 4 max allowed)
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 132, permanent 132):
     100 in free list (132 min, 132 max allowed)
     34 hits, 0 misses
FastEthernet0-Physical buffers, 1524 bytes (total 32, permanent 32):
     8 in free list (0 min, 32 max allowed)
     24 hits, 0 fallbacks
     8 max cache size, 8 in cache
     0 hits in cache, 0 misses in cache
RxQFB buffers, 2040 bytes (total 300, permanent 300):
     285 in free list (0 min, 300 max allowed)
     98974 hits, 0 misses
RxQ1 buffers, 2040 bytes (total 128, permanent 128):
     12 in free list (0 min, 128 max allowed)
     2523063 hits, 74920 fallbacks
RxQ2 buffers, 2040 bytes (total 12, permanent 12):
     0 in free list (0 min, 12 max allowed)
     12 hits, 0 fallbacks, 0 trims, 0 created
RxQ3 buffers, 2040 bytes (total 128, permanent 128):
     873235 hits, 21194 fallbacks
RxQ4 buffers, 2040 bytes (total 64, permanent 64):
     0 in free list (0 min, 64 max allowed)
     12036 hits, 21010 misses
RxQ5 buffers, 2040 bytes (total 0, permanent 0):
     0 in free list (0 min, 0 max allowed)
     0 hits, 0 misses
RxQ6 buffers, 2040 bytes (total 128, permanent 128):
     0 in free list (0 min, 128 max allowed)
     198600 hits, 198472 misses
RxQ7 buffers, 2040 bytes (total 192, permanent 192):
     61 in free list (0 min, 192 max allowed)
     356073 hits, 0 misses
RxQ8 buffers, 2040 bytes (total 64, permanent 64):
     1881178 hits, 2315910 misses
RxQ9 buffers, 2040 bytes (total 1, permanent 1):
     0 in free list (0 min, 1 max allowed)
     1 hits, 0 misses
RxQ10 buffers, 2040 bytes (total 64, permanent 64):
     1 in free list (0 min, 64 max allowed)
     183077 hits, 2860 fallbacks
RxQ11 buffers, 2040 bytes (total 16, permanent 16):
     0 in free list (0 min, 16 max allowed)
     615846 hits, 615830 misses
RxQ12 buffers, 2040 bytes (total 16, permanent 16):
     16 hits, 0 misses
RxQ13 buffers, 2040 bytes (total 16, permanent 16):
     16 hits, 0 misses
RxQ15 buffers, 2040 bytes (total 4, permanent 4):
     2796056 hits, 2796052 misses
IPC buffers, 2048 bytes (total 300, permanent 300):
     296 in free list (150 min, 500 max allowed)
     18738 hits, 0 fallbacks, 0 trims, 0 created
Jumbo buffers, 9240 bytes (total 200, permanent 200):
     200 in free list (0 min, 200 max allowed)
     0 hits, 0 misses
Header pools:
------------------ show platform frontend-controller ver 0 ------------------
Software Version   0.67
Hardware Version   38
Bootloader Version 14
System Type        5
Device Id          1
Device Revision    0
------------------ show platform mcu snapshot ------------------
Leo Laohoo
3560X?  Do you have dual power supplies?  If you do, is the second power supply connected to a UPS or a GPO from a different circuit?
As what Inayath is requesting, can you post the "sh tech"?   Also post the output to the command "dir"?
