WS-C3650-24TS and "errdisable recovery cause small-frame"
Kyle Lenderlof
I'm missing on the C3650-24 TS the command "errdisable recovery cause small-frame".
I'm using the Cisco IOS Software: IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.04SE RELEASE SOFTWARE (fc3)
(config)#errdisable recovery cause ?
  all                      Enable timer to recover from all error causes
  arp-inspection           Enable timer to recover from arp inspection error disable state
  bpduguard                Enable timer to recover from BPDU Guard error
  channel-misconfig (STP)  Enable timer to recover from channel misconfig error
  dhcp-rate-limit          Enable timer to recover from dhcp-rate-limit error
  dtp-flap                 Enable timer to recover from dtp-flap error
  gbic-invalid             Enable timer to recover from invalid GBIC error
  inline-power             Enable timer to recover from inline-power error
  l2ptguard                Enable timer to recover from l2protocol-tunnel error
  link-flap                Enable timer to recover from link-flap error
  loopback                 Enable timer to recover from loopback error
  mac-limit                Enable timer to recover from mac limit disable state
  pagp-flap                Enable timer to recover from pagp-flap error
  port-mode-failure        Enable timer to recover from port mode change failure
  pppoe-ia-rate-limit      Enable timer to recover from PPPoE IA rate-limit error
  psecure-violation        Enable timer to recover from psecure violation error
  psp                      Enable timer to recover from psp
  security-violation       Enable timer to recover from 802.1x violation error
  sfp-config-mismatch      Enable timer to recover from SFP config mismatch error
  storm-control            Enable timer to recover from storm-control error
  udld                     Enable timer to recover from udld error
  vmps                     Enable timer to recover from vmps shutdown error
The Security Configuration Guide, Cisco IOS XE Release 3E (Catalyst 3650 Switches) shows this command, but I'm not able to use it.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3e/security/configuration_guide/b_sec_3e_3650_cg/b_sec_3e_3650_cg_chapter_010001.html
Can you help me?
Kind Regards,
Kyle
7 Replies 7
Hi Kyle,
Please send me a show version output
M
Hi Madhukrishnan,
the show version output is:
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.04SE RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 29-Aug-14 22:22 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
XXX uptime is 1 minute
Uptime for this control processor is 3 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3650-24TS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO------
3 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : a0:ec:f9:db:98:00
Motherboard Assembly Number        : 73-15127-05
Motherboard Serial Number          : FDO----------
Model Revision Number              : D0
Motherboard Revision Number        : A0
Model Number                       : WS-C3650-24TS
System Serial Number               : FDO--------
Switch Ports Model              SW Version        SW Image              Mode
*    1 28    WS-C3650-24TS      03.03.04SE        cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
Can you try other IOS-XE versions, like 3.6.X or 3.7.X?
Hi Leo Laohoo,
even with 03.07.00E  there is no "errdisable recovery cause small-frame" possible.
Please help.
I think you are looking at config guide for 3.6 and on switch you are not running it on switch.
Deat Kyle,
Would like to know whether the above helped you.
if it helped, request  you  to accept as solution.
Madhu
acalderone
Kyle,
Errdisable detection is turned on by default for all causes with the exception of small-frames.  You'll first need to enable the feature with the global errdisable detect cause small-frame command.  Have you done that?
Please rate helpful posts.
Thank You,
Andy
