WS-C3750G-12S-E and WS-C3750G-12S-S V04
I have WS-C3750G-12S-E switch, and i am planning to replace it. Available model is WS-C3750G-12S-S V04 , is it a suitable option for my replacement ???
Hi Preeth,
yes , you can use it.
There is no hardware difference. Between this two models there is only a software difference, when you buy them from Cisco / Reseller.
WS-C3750G-24T-E - Enhanced Image
WS-C3750G-24T-S - Standard Image
The main difference is that WS-C3750G-24T-E comes with IP Services Image installed and WS-C3750G-24T-S comes with IP Base Image installed
And we can run dymanic IP routing in WS-C3750G-24T-E but cant run in WS-C3750G-24T-S
WS-C3750G-24T-S upgradeable to full dynamic IP routing.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/product_data_sheet0900aecd80371991.html
WS-C3750G-12S-E
  12 SFP-based Gigabit Ethernet ports
  32-Gbps, high-speed stacking bus
  Innovative stacking technology
  1 RU stackable multilayer switch
  Enterprise-class intelligent services delivered to the network edge
  IP Services software feature set (IPS)
  Provides full IPv6 dynamic routing
WS-C3750G-12S-S
  IP Base software feature set (IPB)
VS.Suresh.
*Plz rate the usefull posts.
Hi Preeth,
WS-C3750G-12S-E
WS-C3750G-12S-S
VS.Suresh.
Thanks Suresh.. :)
