WS-C3750G-12S Temperature Value: Not Supported Temperature State: Not Supported
gasparmenendez
Level 3
Level 3
Hi, I have a WS-C3750G-12S Switch and I want to monitor temperature (exact values) but when I do: show env temp staus the switch returns: Temperature Value: Not Supported Temperature State: Not Supported
The switch is running 12.2(55)SE3 and C3750-IPBASEK9.
Can I get exact values in this Switch??? Thanks in advance.
BR.
Hi, yes it could be, I found this link:
https://supportforums.cisco.com/discussion/11159571/cisco-3750-12s-unable-get-exact-temperature-not-supported
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
9 Replies 9
Julio E. Moisa
Try with
show env all
What image are you using?
System image file is "flash:/c3750-ipservicesk9-mz.122-53.SE2.bin"
3750-Blass#sho env all
FAN is OK
TEMPERATURE is OK
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
 1  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
Also could you please try with show env temp
I think there are different command lines per image version.
Please rate the comment if it is useful
3750-Blass#sh env temperature
TEMPERATURE is OK
3750-Blass#sh env temperature sta
I think these are the arguments available to combine with show env
sh env ?
all            Show all environment status
fan           Show fan status
power      Show power supply status
rps            Show RPS status
stack         Show Stack-wide all environment status
temperature       Show temperature status
I have this:
3750-Blass#show env temperature ?
  status  Show Temperature status and threshold values
  |       Output modifiers
  <cr>
do you think it could be a problem with the switch's image??
gasparmenendez
Level 3
Level 3
I saw that thread earlier...but I think it's not conclusive....or is it??
