WS-C4500X-32 fan error
Robert.Brand
Required number of fan trays with the same airflow type Front to Back, do not exist, replace or chassis will power down in 30sec,
All 5 fans is brand new,
Any idea how to initialize the switch to accept the new fans, I can go into rom mode, but not a lot of helpful commands, switch is just idling
7 Replies 7
Leo Laohoo
What is the IOS? I think this could be a bug.
Hi, one of the fire canisters went off in the the server room via dust particles, the gas released then crystalized on the fans which burnt out the 5 fans, bought exact new one but not liking it at all,
fans should just come on when its booted when connected correctly , I have never had to turn then on by cli , your canister could have done a lot more damage you cant see if it manages to break 5 fans at once , may need an RMA
thanks for input, the 3 out of 5 fans melted and the switch went off like in a safe mode,
got new ones but no luck, think the board got damaged.
what is RMA ?
when device is under support with your reseller through Cisco they will replace a hardware failure free of charge but it must be supported first , if not its going to be an expensive replacement
Return Material Authorization
thanks Mark
