WS-C4510R failed to boot after power outage
Ruslan.D98995
We faced a problem with power on Catalyst 4510R switch - after power outage it failed to boot. The swicth has two PSUs PWR-C45-2800AC installed, both of them was without any indication after power outage. It powered on only when we switched PSUs off/on manualy, and then the switch started to boot.
Could anyone help with this behaviour? Does PSU have any protetction of voltage spikes or somthing like that? Is it normal behaviour?
8 Replies 8
balaji.bandi
We need to look at the logs and crash logs if any ?  Look at the Load of PSU ? is this N+1 ? or redundant ? is the both PSU same size ?
what is the version of the code ? what is power status of PSU ?
BB
There are no logs or crashinfo, PSUs are in redundant mode, right now everything seems fine:
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-2800AC AC 2800W good good good
PS2 PWR-C45-2800AC AC 2800W good good good
Power supplies needed by system : 1
Power supplies currently available : 2
Power Summary Maximum
(in Watts) Used Available
System Power (12V) 500 1360
Inline Power (-50V) 17 1400
Backplane Power (3.3V) 40 40
Total 557 2800
strange can you post show version.
BB
Here is:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 15.0(2)SG10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 07-Apr-15 09:46 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x123AE824
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 34
xxxxxx uptime is 2 days, 1 hour, 32 minutes
Uptime for this control processor is 2 days, 1 hour, 32 minutes
System restarted at 14:35:05 URAL Wed May 26 2021
System image file is "bootflash:cat4500-entservicesk9-mz.150-2.SG10.bin"
cisco WS-C4510R (MPC8245) processor (revision 4) with 524288K bytes of memory.
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from PowerUp
33 Virtual Ethernet interfaces
80 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Mark Elsen
 - Instability in the outage-syndrome may result in such behavior, have a console connected at all times , if you expect these troublesome times to happen again, in those cases only console output can tell what is going on, if possible have it logged by an  tty-operator tool such as putty which can log and keep sessions.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for suggestion, will try it.
Can the switch logs such type of event? I mean it looks like purely PSU behaviour.
                >....Can the switch logs such type of event? I mean it looks like purely PSU behavior.
 Not really in those peculiar circumstances you are dependent on the console for info's , however using a syslog server may be advisable at all times, 'surrounding logs' can then also be examine and or may give further insights
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
Single event upset
