WS-C4948 IOS upgrade from12.2(25)EWA14 to 15x
shaun barrs
Hi all,
I have been asked if we can upgrade our 4948 from 12.2(25)EWA14 to 15x. I have looked at the release notes but finding it hard to determine if we are able to jump straight from 12.2(25)EWA14 to 15x as the naming convention changes greatly and unsure if we could say go to 15.0.2-SG10.
Below is a show version.  Any help or if there is a tool I can use would be much appreciated.
#show version
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(25)EWA14, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Tue 20-Jun-08 19:18 by Ddeb
Image text-base: 0x10000000, data-base: 0x115CE0AC
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 5
 uptime is 1 years, 3 days, 12 hours, 10 minutes
System returned to ROM by reload
System restarted at 08:47:08 UTC Mon Nov 18 2014
System image file is "bootflash:cat4000-i5k91s-mz.122-25.EWA14.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4948 (MPC8245) processor (revision 0) with 262144K bytes of memory.
Processor board ID **********
MPC8245 CPU at 266Mhz, Fixed Module
Last reset from Reload
2 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Shaun
acampbell
Your existing IOS
BASIC L3 3DES (RIP,ST.ROUTERS,IPX,AT)
cat4000-i9k91s-mz.122-25.EWA14.bin
You can upgrade to
IP BASE SSH
cat4500-ipbasek9-mz.150-2.SG10.bin
It would also be advisable to upgrade your ROMMON software before you upgrade the IOS
Rommon upgrade for cat4500 K2 platforms. Resolves CSCtr65301
cat4500-ios-promupgrade-122_31r_SGA7
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_18983.html
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
Do you know where i can get this 15 ios? because i can't find it in support downloads.
The switch i have is a WS-C4510R Version 12.2(25)EWA10 that does not support SLA Tracking, and in the version 15 it's supported and i need it.
Any advice?
Thankyou very much.
Regards.
You mention that your switch is a WS-4510R but you did not state your supervisor engine model like sup-2 etc.
So try this link (you need to sign in with your CCO account):-
https://software.cisco.com/download/navigator.html?mdfid=278748183&flowid=61301
Then choose your supervisor from the right hand side, then IOS software
Hope this helps
Alex
Thank you very much!
