SNMP monitoring
Hi ,
I'm working on IP SLA  icmp- jitter .. I need to monitors it parameters like packet loss .. So is there any SNMP software can using for monitoring other than the PRTG  .. Cuz i tested the PRTG but i can't bring the parameters ... Thanks in advance
Any update ? Thanks
Hello Tareq,
Have you found a solution here?
If you're having trouble with the PRTG IP SLA sensor, please let me know and I'll try to help.
All the best,
Kimberley (from Paessler)
