WS-SUP720-3B and 10G compatibility
erisanchez
Im trying to find information on using sup720-3b and use 10g line cards.  Can anyone show me a link of a compatibility matrix for 3B versus 3C?
Jon Marshall
erisanchez@firstam.com
Not entirely sure what you are looking for ? Have a look at Table 2 in this doc and see if it answers your question(s) -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/qa_cisco_catalyst_6500_series_16port_10gigabit_ethernet_module.html
Jon
8 Replies 8
Jon Marshall
Jon
Overall, I am trying to find any information if I need to upgrade my sups to 720-3Cs or can I cost save and upgrade the IOS on my 720-3Bs.  Would a 6716-10G line card be compatibable with a 720-3B?
You will be fine with a Sup720-3B. From the same doc i sent a link to -
Q. Which supervisor engine supports the 16-port 10 Gigabit Ethernet module?
A. The 16-port 10 Gigabit Ethernet module works with any Virtual Switching Supervisor Engine 720-10G or Supervisor Engine 720, including VS-S720-10G-3C, VS-S720-10G-3CXL, WS-Sup720, WS-Sup720-3B, and WS-Sup720-3BXL.
Jon
Jon:
tyvm.  I appreciate your assistance with this.
sh version
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-IPSERVICESK9-M), Version 15.2(4)S3a, RELEASE SOFTWARE (fc1)
Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1407B6J0
Does it support for below line cards
WS-X6708-10G-3C=
C6K 8 port 10 Gigabit Ethernet module with DFC3C (req. X2)
WS-X6908-10G-2T=
C6K 8 port 10 Gigabit Ethernet module with DFC4 (Trustsec) S
Hi. Did you ever get the WS-X6708-10G-3C= working with a SUP720-3B.
I have a short term fix requirement for 10G into 6500 before refresh to 6708 Sup6T.
I believe we have 6708 line cards working with both sup720-3Bs and VS-S720s.  The 6708 will not work with a sup2T (and probably not a sup6T either.)
To work with a sup2T, and you need a CFC or DFC4 line card, and the 6708's DFC3C cannot be upgraded or removed.
Thanks Joseph,
Small typo above, I meant refresh to 6807 chassis with Sup6T so the 6708 cards would be traded in for 6800 16port 10G.
