03-22-2015 01:54 AM - edited 03-07-2019 11:12 PM
Hello Community,
I have a problem with my core switch (two WS-C6509-V-E in VSS). I tried installing new SFP "X2-10GB-SR" in port Te2/7/7 and the SFP not recognized. SFP not shown in the "show inventory" or "show idprom" and port keep showing "orange" even after shut down the port. I tried with two different New SPF and keep getting same result. Also, I tried same SFP on different chassis -I have in lab- and SFP recognized fine -so should have no problem on the SFP itself-.
I tried same SFP in the second switch (in the same VSS) and got same result. SFP not recognized and not showing in the "show inventory".
I already have SFP from the same model installed on the module and running fine as shown in the below show inventory below -so should have no compatibility issue- .
I am suspecting the problem from the module. I am not sure why observing the same behavior on two modules on two switches (but the same VSS).
Any one faced the same problem? How we can fix this?
------------------ show version ------------------
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9-M), Version 15.1(2)SY4, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 05-Nov-14 17:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9-M), Version 15.1(2)SY4, RELEASE SOFTWARE (fc5)
AB_Core_3_VSS uptime is 1 year, 41 weeks, 1 day, 5 hours, 54 minutes
Uptime for this control processor is 9 weeks, 2 days, 3 hours, 12 minutes
System returned to ROM by RPR Switchover at 04:00:33 utc Fri Jan 16 2015 (SP by reload)
System restarted at 04:05:30 UTC Fri Jan 16 2015
System image file is "sup-bootdisk:s72033-advipservicesk9-mz.151-2.SY4.bin"
Last reload reason: - From Active Switch. reload peer unit
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-V-E (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory.
Processor board ID FOX1238GQTR
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
62 Virtual Ethernet interfaces
114 Gigabit Ethernet interfaces
26 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
------------------ show inventory ------------------
NAME: "Chassis 1 WS-C6509-V-E", DESCR: "Chassis 1 Cisco Systems, Inc. Catalyst 6500 enhanced 9-slot Chassis System"
PID: WS-C6509-V-E , VID: V01, SN: FOX1238GQTR
NAME: "Chassis 1 1", DESCR: "Chassis 1 WS-X6748-SFP CEF720 48 port 1000mb SFP Rev. 2.4"
PID: WS-X6748-SFP , VID: V05, SN: SAL1434RJFS
NAME: "Chassis 1 WS-F6700-DFC3C Distributed Forwarding Card 3 EARL sub-module of 1", DESCR: "Chassis 1 WS-F6700-DFC3C Distributed Forwarding Card 3 Rev. 1.4"
PID: WS-F6700-DFC3C , VID: V03, SN: SAL15066ZYJ
NAME: "Chassis 1 4", DESCR: "Chassis 1 WS-SVC-ASA-SM1 3 ports ASA Service Module Rev. 2.0"
PID: WS-SVC-ASA-SM1 , VID: V02, SN: SAL1828WFS9
NAME: "Chassis 1 sub-module of 4", DESCR: "Chassis 1 SVC-APP-PROC-1 Trifecta SVC-APP-PROC-1 Daughter Card Rev. 1.0"
PID: SVC-APP-PROC-1 , VID: , SN: SAL1828WA7E
NAME: "Chassis 1 5", DESCR: "Chassis 1 VS-S720-10G 5 ports Supervisor Engine 720 10GE Rev. 2.3"
PID: VS-S720-10G , VID: V03, SN: SAL1216MDML
NAME: "Chassis 1 msfc sub-module of 5", DESCR: "Chassis 1 VS-F6K-MSFC3 MSFC3 Daughterboard Rev. 1.3"
PID: VS-F6K-MSFC3 , VID: V02, SN: SAL1215M6DA
NAME: "Chassis 1 VS-F6K-PFC3C Policy Feature Card 3 EARL sub-module of 5", DESCR: "Chassis 1 VS-F6K-PFC3C Policy Feature Card 3 Rev. 1.2"
PID: VS-F6K-PFC3C , VID: V02, SN: SAL1215MBGP
NAME: "Chassis 1 Transceiver Te1/5/4", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/5/4"
PID: X2-10GB-SR , VID: V04 , SN: FNS14290EFU
NAME: "Chassis 1 Transceiver Te1/5/5", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/5/5"
PID: X2-10GB-SR , VID: V04 , SN: FNS14290EFB
NAME: "Chassis 1 7", DESCR: "Chassis 1 WS-X6708-10GE CEF720 8 port 10GE with DFC Rev. 3.2"
PID: WS-X6708-10GE , VID: V10, SN: SAL1545UR9W
NAME: "Chassis 1 WS-F6700-DFC3C Distributed Forwarding Card 3 EARL sub-module of 7", DESCR: "Chassis 1 WS-F6700-DFC3C Distributed Forwarding Card 3 Rev. 1.5"
PID: WS-F6700-DFC3C , VID: V03, SN: SAL1545UVSE
NAME: "Chassis 1 Transceiver Te1/7/1", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/7/1"
PID: X2-10GB-SR , VID: V06 , SN: ONT183703EK
NAME: "Chassis 1 Transceiver Te1/7/3", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/7/3"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637X0PA
NAME: "Chassis 1 Transceiver Te1/7/4", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/7/4"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637X0W2
NAME: "Chassis 1 Transceiver Te1/7/5", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/7/5"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637X0PB
NAME: "Chassis 1 Transceiver Te1/7/6", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/7/6"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637X0W3
NAME: "Chassis 1 Transceiver Te1/7/7", DESCR: "Chassis 1 X2 Transceiver 10Gbase-SR Te1/7/7"
PID: X2-10GB-SR , VID: V06 , SN: AGJ1847X13G
NAME: "Chassis 1 9", DESCR: "Chassis 1 WS-SVC-FWM-1 6 ports Firewall Module Rev. 4.5"
PID: WS-SVC-FWM-1 , VID: , SN: SAL1514AL2H
NAME: "Chassis 1 PS 1 WS-CAC-4000W-INT", DESCR: "Chassis 1 220v AC power supply, 4000 watt 1"
PID: WS-CAC-4000W-INT , VID: V02, SN: SNI1431BM49
NAME: "Chassis 1 PS 2 WS-CAC-4000W-INT", DESCR: "Chassis 1 220v AC power supply, 4000 watt 2"
PID: WS-CAC-4000W-INT , VID: V02, SN: SNI1431BM5X
NAME: "Chassis 2 WS-C6509-V-E", DESCR: "Chassis 2 Cisco Systems, Inc. Catalyst 6500 enhanced 9-slot Chassis System"
PID: WS-C6509-V-E , VID: V01, SN: FOX1309GFPW
NAME: "Chassis 2 WS-C6K-VTT-E 1", DESCR: "Chassis 2 VTT-E FRU 1"
PID: WS-C6K-VTT-E , VID: , SN: SMT1240D738
NAME: "Chassis 2 WS-C6K-VTT-E 2", DESCR: "Chassis 2 VTT-E FRU 2"
PID: WS-C6K-VTT-E , VID: , SN: SMT1240D732
NAME: "Chassis 2 WS-C6K-VTT-E 3", DESCR: "Chassis 2 VTT-E FRU 3"
PID: WS-C6K-VTT-E , VID: , SN: SMT1241H282
NAME: "Chassis 2 CLK-7600 1", DESCR: "Chassis 2 OSR-7600 Clock FRU 1"
PID: CLK-7600 , VID: , SN: NWG130309HT
NAME: "Chassis 2 CLK-7600 2", DESCR: "Chassis 2 OSR-7600 Clock FRU 2"
NAME: "Chassis 2 1", DESCR: "Chassis 2 WS-X6748-SFP CEF720 48 port 1000mb SFP Rev. 2.4"
PID: WS-X6748-SFP , VID: V05, SN: SAL1434RJCU
NAME: "Chassis 2 WS-F6700-DFC3C Distributed Forwarding Card 3 EARL sub-module of 1", DESCR: "Chassis 2 WS-F6700-DFC3C Distributed Forwarding Card 3 Rev. 1.4"
PID: WS-F6700-DFC3C , VID: V03, SN: SAL15066ZZ3
NAME: "Chassis 2 4", DESCR: "Chassis 2 WS-SVC-ASA-SM1 3 ports ASA Service Module Rev. 2.0"
PID: WS-SVC-ASA-SM1 , VID: V02, SN: SAL1828WFR1
NAME: "Chassis 2 sub-module of 4", DESCR: "Chassis 2 SVC-APP-PROC-1 Trifecta SVC-APP-PROC-1 Daughter Card Rev. 1.0"
PID: SVC-APP-PROC-1 , VID: , SN: SAL1824UMB3
NAME: "Chassis 2 5", DESCR: "Chassis 2 VS-S720-10G 5 ports Supervisor Engine 720 10GE Rev. 3.4"
PID: VS-S720-10G , VID: V05, SN: SAL1446ZENC
NAME: "Chassis 2 msfc sub-module of 5", DESCR: "Chassis 2 VS-F6K-MSFC3 MSFC3 Daughterboard Rev. 5.1"
PID: VS-F6K-MSFC3 , VID: V06, SN: SAL14491PWV
NAME: "Chassis 2 VS-F6K-PFC3C Policy Feature Card 3 EARL sub-module of 5", DESCR: "Chassis 2 VS-F6K-PFC3C Policy Feature Card 3 Rev. 1.2"
PID: VS-F6K-PFC3C , VID: V02, SN: SAL145020YJ
NAME: "Chassis 2 Transceiver Te2/5/4", DESCR: "Chassis 2 X2 Transceiver 10Gbase-SR Te2/5/4"
PID: X2-10GB-SR , VID: V04 , SN: FNS14290EFN
NAME: "Chassis 2 Transceiver Te2/5/5", DESCR: "Chassis 2 X2 Transceiver 10Gbase-SR Te2/5/5"
PID: X2-10GB-SR , VID: V04 , SN: FNS14290EFH
NAME: "Chassis 2 7", DESCR: "Chassis 2 WS-X6708-10GE CEF720 8 port 10GE with DFC Rev. 3.2"
PID: WS-X6708-10GE , VID: V10, SN: SAL1545UUXR
NAME: "Chassis 2 WS-F6700-DFC3C Distributed Forwarding Card 3 EARL sub-module of 7", DESCR: "Chassis 2 WS-F6700-DFC3C Distributed Forwarding Card 3 Rev. 1.5"
PID: WS-F6700-DFC3C , VID: V03, SN: SAL1545UVS7
NAME: "Chassis 2 Transceiver Te2/7/1", DESCR: "Chassis 2 X2 Transceiver 10Gbase-SR Te2/7/1"
PID: X2-10GB-SR , VID: V06 , SN: ONT1838030V
NAME: "Chassis 2 Transceiver Te2/7/3", DESCR: "Chassis 2 X2 Transceiver 10Gbase-SR Te2/7/3"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637XZ80
NAME: "Chassis 2 Transceiver Te2/7/4", DESCR: "Chassis 2 X2 Transceiver 10Gbase-SR Te2/7/4"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637X0VN
NAME: "Chassis 2 Transceiver Te2/7/5", DESCR: "Chassis 2 X2 Transceiver 10Gbase-SR Te2/7/5"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637X2XF
NAME: "Chassis 2 Transceiver Te2/7/6", DESCR: "Chassis 2 X2 Transceiver 10Gbase-SR Te2/7/6"
PID: X2-10GB-SR , VID: V06 , SN: AGA1637X0PC
NAME: "Chassis 2 9", DESCR: "Chassis 2 WS-SVC-FWM-1 6 ports Firewall Module Rev. 4.5"
PID: WS-SVC-FWM-1 , VID: , SN: SAL1705XT8D
NAME: "Chassis 2 WS-C6509-V-E-FAN 1", DESCR: "Chassis 2 Fan Tray for WS-C6509-V-E 1"
PID: WS-C6509-V-E-FAN , VID: V02, SN: DCH142700TB
NAME: "Chassis 2 WS-C6509-V-E-FAN 2", DESCR: "Chassis 2 Fan Tray for WS-C6509-V-E 2"
PID: WS-C6509-V-E-FAN , VID: V02, SN: DCH142700SE
NAME: "Chassis 2 PS 1 WS-CAC-4000W-INT", DESCR: "Chassis 2 220v AC power supply, 4000 watt 1"
PID: WS-CAC-4000W-INT , VID: V02, SN: SNI1431BM6B
NAME: "Chassis 2 PS 2 WS-CAC-4000W-INT", DESCR: "Chassis 2 220v AC power supply, 4000 watt 2"
PID: WS-CAC-4000W-INT , VID: V02, SN: SNI1431BM31
------------------ show module switch all ------------------
Switch Number: 1 Role: Virtual Switch Active
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL1434RJFS
4 3 ASA Service Module WS-SVC-ASA-SM1 SAL1828WFS9
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G SAL1216MDML
7 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1545UR9W
9 6 Firewall Module WS-SVC-FWM-1 SAL1514AL2H
Mod MAC addresses Hw Fw Sw Status
1 c84c.757c.7a4c to c84c.757c.7a7b 2.4 12.2(18r)S1 15.1(2)SY4 Ok
4 24e9.b3e7.e264 to 24e9.b3e7.e273 2.0 12.2(50r)SYL 15.1(2)SY4 Ok
5 001e.7a58.6540 to 001e.7a58.6547 2.3 8.5(4) 15.1(2)SY4 Ok
7 7081.055f.0990 to 7081.055f.0997 3.2 12.2(18r)S1 15.1(2)SY4 Ok
9 f866.f2b1.fb68 to f866.f2b1.fb6f 4.5 7.2(1) 4.1(6) Ok
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6700-DFC3C SAL15066ZYJ 1.4 Ok
4/0 ASA Application Processor SVC-APP-PROC-1 SAL1828WA7E 1.0 Ok
5 Policy Feature Card 3 VS-F6K-PFC3C SAL1215MBGP 1.2 Ok
5 MSFC3 Daughterboard VS-F6K-MSFC3 SAL1215M6DA 1.3 Ok
7 Distributed Forwarding Card WS-F6700-DFC3C SAL1545UVSE 1.5 Ok
Base PID:
Mod Model Serial No.
4 WS-SVC-APP-HW-1 SAL1828WFS9
Mod Online Diag Status
1 Pass
4 Pass
4/0 Pass
5 Pass
7 Pass
9 Pass
Switch Number: 2 Role: Virtual Switch Standby
1 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL1434RJCU
4 3 ASA Service Module WS-SVC-ASA-SM1 SAL1828WFR1
5 5 Supervisor Engine 720 10GE (Hot) VS-S720-10G SAL1446ZENC
7 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1545UUXR
9 6 Firewall Module WS-SVC-FWM-1 SAL1705XT8D
1 5475.d0cb.bb94 to 5475.d0cb.bbc3 2.4 12.2(18r)S1 15.1(2)SY4 Ok
4 24e9.b3e7.e374 to 24e9.b3e7.e383 2.0 12.2(50r)SYL 15.1(2)SY4 Ok
5 c47d.4ffe.5f38 to c47d.4ffe.5f3f 3.4 8.5(4) 15.1(2)SY4 Ok
7 7081.055f.0808 to 7081.055f.080f 3.2 12.2(18r)S1 15.1(2)SY4 Ok
9 f0f7.5569.5560 to f0f7.5569.5567 4.5 7.2(1) 4.1(6) Ok
1 Distributed Forwarding Card WS-F6700-DFC3C SAL15066ZZ3 1.4 Ok
4/0 ASA Application Processor SVC-APP-PROC-1 SAL1824UMB3 1.0 Ok
5 Policy Feature Card 3 VS-F6K-PFC3C SAL145020YJ 1.2 Ok
5 MSFC3 Daughterboard VS-F6K-MSFC3 SAL14491PWV 5.1 Ok
7 Distributed Forwarding Card WS-F6700-DFC3C SAL1545UVS7 1.5 Ok
Base PID:
4 WS-SVC-APP-HW-1 SAL1828WFR1
1 Pass
4 Pass
4/0 Pass
5 Pass
7 Pass
9 Pass
03-22-2015 04:09 AM
6708 line card could be faulty. Read THIS.
