X2 vs Xenpak
6rlopez_2
Hi, I have to connect 2 switches with 10 G fiber. One of the switches only supports X2 transceiver and the other end switch only support Xenpak connector. Is there any problem to do this connection?
francisco_1
Level 7
Level 7
X2 and XENPAK optics differ in form factor only. You can connect an X2 to a XENPAK as long as the optics are of the same transceiver type.
francisco_1
Level 7
Level 7
Francisco_1,
Thank you for your feedback, just let me add two links that might be helpful:
10 BASE XENPAK  Module
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps2797_Products_Data_Sheet.html
10 BASE X2 Module (Note that both XENPAK and X2 show in the figure 1)
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa_ps5251_Products_Data_Sheet.html
Abd Dandashi
