You can hot plug a fiber module into an open SFP slot in a 3750 switch right?
keithsauer507
Level 5
Level 5
Just wanted to confirm, I have a 3750 switch stack and there are 4 SFP slots in our top switch, 1 is used.  I want to plug in another Cisco branded mm fiber module in there.  I can just plug it in there and not have to do a reload of the switch stack correct?
In the config the interface is defined Gi1/0/50 for example (its a 48 port gig switch on the top of the stack).  So once I plug it in I can put that port on the proper config I want without a reload?
Reza Sharifi
Correct, you can add another SFP to the switch and no need for reboot.
Once added, you should see the interface come up and than configure the port.
