Audit - User Create/Delete events in TMS Provisioning Directory
dc-csa-chn
We need to find the user, who has Created/Deleted a user from TMS Provisioning Directory.
Is there any logs which can get us these details.
No luck with TMS Audit logs......
8 Replies 8
Kjetil Ree
Activities in the Legacy TMS Agent or TMS Provisioning Extension solutions aren't logged anywhere in TMS itself, so I think you're out of luck.
Kjetil
Would you know if this is this possible with the new provisioning extension version 1.1.0.27 ? I would like to find out when and which user was movr/jabber users were created or deleted recently. Thank you.
Magnus Ohm
Hi had a case on this once as well. Luckily the guilty one confessed
Do you have a limited numbers of admin users that have access to TMS? You can restrict access to these parts of TMS by arranging the user persmissions as this will prevent things like this to happen.
There is no logging on this as kjetil is saying.
/Magnus
dc-csa-chn
Hi Magnus/Kjetil,
Any chances that these ID's would have been deleted automatically.
Is it AD users or manually created users that has disappeared?
/Magnus
Magnus -> They are Manual Users
Magnus Ohm
I dont see how those users could be removed automatically under normal conditions.
Did someone recently restore a tmsagent backup which might not have contained the users that are now missing?
/Magnus
Alok Jaiswal
What is the TMS & VCS software version you are running??? can you confirm
Alok
